  2. Routes & Tracks
  3. Move routes of position
23 Posts 11 Posters 12.5k Views 3 Watching
  • fbarr47gmail.com fbarr47gmail.com
    I don't know how to move a route position. I have a folder with several routes in a country and they are not in order. How do I order them?
    thanks!
    @FRANCISCO-BARRENA Click the title of the column in your library to change the order. Name, Type, Change etc click it again to reverse the order.
    fbarr47gmail.com 1 Reply Last reply
    • Rob Veerman
      Rob Veerman
      Rob Veerman
      Renaming your routes by giving them a letter, number (by date or whatever). They will then be sorted in that new order.
        fbarr47gmail.com
        fbarr47gmail.com
        fbarr47gmail.com
        @Nick-Carthew sorry but that not work like this. If CLICK the title , OPEN the file... I want place in order. I want go down 2 places more down. I can't mark the file and drag it to another position?? that would be simple.
        Rob Veerman Marinus van Deudekom 2 Replies Last reply
          Rob Veerman
          Rob Veerman
          Rob Veerman
          @FRANCISCO-BARRENA As I wrote, rename the files. Something like 240601, 240602, 240603 and your files will be sorted that way.
          • Rob Veerman Rob Veerman
            fbarr47gmail.com
            fbarr47gmail.com
            fbarr47gmail.com
            @Rob-Veerman but I don,t want rename the files... I prefer the files with the name of the route.. Not is possible to drag the files to another position????
              @FRANCISCO-BARRENA what you want is impossible. You like Nick said you can sort them by clicking on the column's title. By name date etc. Changing the order in witch they appear can't be done without changing the titles like Rob said
                thanks!
                @FRANCISCO-BARRENA said in Move routes of position:
                thanks!
                You can add a number at first as beginning of the route name.
                Kindly regards
                Reinhard
                Montana 700i and Mac
                TomOnTour fbarr47gmail.com 2 Replies Last reply
                • Reinhard-32 Reinhard-32
                  thanks!
                  TomOnTour
                  TomOnTour
                  TomOnTour
                  @Reinhard-32 said in Move routes of position:
                  thanks!
                  That is exactly how I do it with my routes. 🙂
                  Works perfect for me.
                  Greetings
                  Thomas
                  MyRoute-APP Navigation Next (V6.0.0 - 489) on DMD T781
                  MRA Navigation Next (Lifetime Gold)
                  MRA Routeplanner NEXT beta (Lifetime early access)
                  Erdna 1 Reply Last reply
                  • TomOnTour TomOnTour
                    thanks!
                    Greetings
                    Thomas
                    Erdna
                    Erdna
                    Erdna
                    @TomOnTour said in Move routes of position:
                    thanks!
                    Greetings
                    Thomas
                    Same here.
                      thanks!
                      fbarr47gmail.com
                      fbarr47gmail.com
                      fbarr47gmail.com
                      @Reinhard-32 yes, like this I have done in my routes and not work properly. The route num 3 not in position
                        @FRANCISCO-BARRENA That is strange. I can see there are dots in your route names and after the route numbers. Remove them could be helpful. It is often not a good idea use special characters in file names.
                        Kindly regards
                        Reinhard
                        GT JWR 1 Reply Last reply
                          @Reinhard-32 the dots are because the name is longer than the space it's in...if that section was resized to show the entire name, the dots would not be there.
                          • GT JWR GT JWR
                            #14
                            @GT-JWR I know that behavior. I was referring to the dots marked in the screenshot.
                            Kindly regards
                            Reinhard
                              fbarr47gmail.com
                              fbarr47gmail.com
                              fbarr47gmail.com
                              I removed the points and it's still the same. This cannot be a mistake, it is very basic. I don't understand
                                @FRANCISCO-BARRENA
                                No. 3 sticks out, that‘s weird. When you close your browser and restart it, does it help?
                                You could temporarily rename route no. 3 to something like 15 or so.
                                BTW: The sort order goes from left to right and from numbers to letters.
                                If you have more than 9 routes it is recommended to use 2 digits like this:
                                01
                                02
                                09
                                Otherwise you will get:
                                21
                                Kindly regards
                                Reinhard
                                  @FRANCISCO-BARRENA
                                  01
                                  02
                                  09
                                  21
                                  @Reinhard-32 not the colum with the names is selected but it seems like the colum date is selected
                                  Herko ter Horst MotoCon 2 Replies Last reply
                                    @Marinus-van-Deudekom Where do you see that? The name column has the "sorting" arrow on it, which as far as I know, means it's selected. Plus it's light blue, so it's definitely selected.
                                      @Herko-ter-Horst My bad. I let myself being confused by the order of the date time colum.
                                        @Marinus-van-Deudekom said in Move routes of position:
                                        In that case Route 8 would be sticking out 😉
                                        But no, the name column is selected.
                                          thanks!
                                          thanks!
                                          Is your problem solved now or does it still exist?
                                          Kindly regards
                                          Reinhard
                                          Rob Veerman
                                          Rob Veerman
                                          TomOnTour
                                          TomOnTour
                                          Erdna
                                          Erdna
                                          BFG
                                          BFG
                                          fbarr47gmail.com
                                          fbarr47gmail.com
                                            Jacob Waterweg
                                            Jacob Waterweg
                                            96
                                            Edwin van Klink 6
                                            Edwin van Klink 6
                                          • Startpunt wijzigen
                                            Ad V
                                            Ad V
                                            Giancarlo e
                                            Giancarlo e
                                          • Route exporteren uit beta
                                            Johan 5q
                                            Johan 5q
                                          • PDF export: suggested additional options
                                            Emanuele 5
                                            Emanuele 5
