  2. Routes & Tracks
  3. Move routes of position
23 Posts 11 Posters 11.3k Views 3 Watching
  • GT JWR GT JWR
    @Reinhard-32 the dots are because the name is longer than the space it's in...if that section was resized to show the entire name, the dots would not be there.
    Reinhard-32 Offline
    Reinhard-32 Offline
    #14
    @GT-JWR I know that behavior. I was referring to the dots marked in the screenshot.
    Kindly regards
    Reinhard
    Montana 700i and Mac
    fbarr47gmail.com 1 Reply Last reply
    • Reinhard-32 Reinhard-32
      fbarr47gmail.com Offline
      fbarr47gmail.com
      @Reinhard-32 said in Move routes of position:
      I removed the points and it's still the same. This cannot be a mistake, it is very basic. I don't understand
      • fbarr47gmail.com fbarr47gmail.com
        Reinhard-32 Offline
        Reinhard-32 Offline
        @FRANCISCO-BARRENA
        No. 3 sticks out, that‘s weird. When you close your browser and restart it, does it help?
        You could temporarily rename route no. 3 to something like 15 or so.
        BTW: The sort order goes from left to right and from numbers to letters.
        If you have more than 9 routes it is recommended to use 2 digits like this:
        01
        02
        09
        Otherwise you will get:
        21
        Kindly regards
        Reinhard
          @FRANCISCO-BARRENA
          01
          02
          09
          21
          Marinus van Deudekom Offline
          @Reinhard-32 not the colum with the names is selected but it seems like the colum date is selected
          Herko ter Horst Con Hennekens 2 Replies Last reply
            Herko ter Horst Offline
            @Marinus-van-Deudekom Where do you see that? The name column has the "sorting" arrow on it, which as far as I know, means it's selected. Plus it's light blue, so it's definitely selected.
              @Herko-ter-Horst My bad. I let myself being confused by the order of the date time colum.
                @Marinus-van-Deudekom said in Move routes of position:
                In that case Route 8 would be sticking out 😉
                But no, the name column is selected.
                  I don't know how to move a route position. I have a folder with several routes in a country and they are not in order. How do I order them?
                  thanks!
                  Reinhard-32 Offline
                  Reinhard-32 Offline
                  @FRANCISCO-BARRENA said in Move routes of position:
                  thanks!
                  Is your problem solved now or does it still exist?
                  Kindly regards
                  Reinhard
                  • BFG Offline
                    BFG Offline
                    BFG
                    wrote on last edited by BFG
                    #22
                    There is a space at the beginning of the route name. The interface ignores the space, so you can't see it in the listing, but if you edit you will see that it's there.
                    " "3. BISCARROSSE. Camping....
                    Remove the space and it will work
                    • BFG BFG
                      fbarr47gmail.com
                      @BFG said in Move routes of position:
                      OK, you´re right, there was a space in the 3 route. Solutioned!
                      thanks a lot!
                      TomOnTour
                      TomOnTour
                      Rob Veerman
                      Rob Veerman
                      BFG
                      BFG
                      Erdna
                      Erdna
                      fbarr47gmail.com
                      fbarr47gmail.com
                      • Elektrisch voertuig
                        jan rodeyns
                        jan rodeyns
                      • waar vind ik gedeelde routes bijvoorbeeld rond winterberg
                        willo 3 0
                        willo 3 0
                      • opslaan naar plantomtom
                      • Planned routes not available during lack of Internet connection
                        Montorsi Paolo 0
                        Montorsi Paolo 0
                        Ioan Dragulescu
                        Ioan Dragulescu
                        10.2k
                      • scherm bevrirzing
                      • Waypoint list for a long route ( ~50 t0 100 routing points) will not be show on the Android auto ridernav screen
                        Fridjof
                        Fridjof
                      • Welke instelling
                        240
