  3. [App] Announcements
  4. New update! (4.1.3)
New update! (4.1.3)
28 Posts 20 Posters 16.0k Views 2 Watching
    Hi everyone! ๐Ÿ˜ƒ
    It's time for a new release! ๐ŸŽ‰ It's packed with nice new features and improvements. We expect it to be available around Wednesday. Just as technicality, this is version 4.1.3 with build 311.
    CarPlay / Android Auto changes
    There are quite come nice changes for these platforms!
    Route library
    Finally! One of the most anticipated changes. Directly load any of your routes from CarPlay / Android Auto! ๐Ÿ’ฃ ๐Ÿ’ฅ
    Speeding
    When exceeding the speed limit - this will now be visible too ๐Ÿ˜‰
    Resume navigation & skip waypoint
    The resume navigation prompt has been improved and when skipping a waypoint, we ask you to confirm and we show the number of the waypoint that will be skipped!
    More settings!
    As you all enjoy settings, we added some more! ๐Ÿ˜
    You can change the displayed arrival time as you can do in the app too. Now you can toggle between displaying duration / distance to the end / next waypoint / next viapoint.
    You can also change the camera orientation between the available modes! ๐ŸŽ‰
    Common changes
    As we also changed some general things the app, these are listed below!
    North-up
    We already had the dynamic and topdown camera mode. Now we added a north-up mode where the camera is fixed north. This allows you to navigate using the orientation that matches that of a traditional map! ๐Ÿ™‚
    Simply tap the compass as you are used to in order to cycle through these modes. We remember the last choice you made so you never have to tap the button again once you selected the mode you like ๐Ÿ˜‰
    All modes are available in CarPlay / Android Auto too! (and you can cycle through them directly through the settings on those platforms, see screenshots above).
    Display search results on map home screen
    When searching for things we wouldn't display them on the map in the home screen. Now we do! ๐ŸŽ‰
    Short tap a displayed icon to display the name, long press it to navigate to that item.
    Configuration options auto zoom
    We would automatically zoom out when you were driving faster or when the next instruction was farther away. Most of you enjoyed this but some did not. We decided that it's up to you how it works! ๐Ÿ™‚
    • Off: we do nothing extra
    • Speed icon: based on speed slightly less zoom
    • Instruction icon: based on next instruction distance less zoom
    • On: we use both! This was default like it was
    The difference can be observed here:
    Major details
    • Solved white screen (map loading issue) + crash! ๐Ÿ’ฃ (rare issue)
    • Improved position delay on all Android devices! ๐Ÿ’ฅ
    Minor stuff
    • Improved waypoint skip algorithm and fixed an issue causing it to skip large sections unintended.
    • Improved algorithm that places stops (such as fuel stations) between your waypoints
    • Added extra Carpe Iter controller configuration option
    • More little tweaks
    • General stability
    Quite a long list! Hope you enjoy all of it! ๐Ÿ˜
    I'm heading to Scotland tomorrow to use this version properly! Excuse me for not responding within the usual timeframe you expect from me.
    What's next
    In my absence development will continue to support editing / creating routes directly in the app! โค
    Cheers,
    Corjan
    John Vandenhove
    John Vandenhove
    John Vandenhove
    Thanks a lot Corjan. Love driving with MRA. Enjoy Scotland. Groetjes John
    • Monty Schmieman
      Monty Schmieman
      Monty Schmieman
      Ik kan mijn app op de android wel openen maar dan blokkeert hij?
      MotoCon Monty Schmieman 2 Replies Last reply
      • Monty Schmieman Monty Schmieman
        @Monty-Schmieman, Android? Even geforceerd stoppen vanuit het systeem - Apps menu, of je telefoon even herstarten. De eerste app start na een update wil wel eens wat rommelig zijn.
          Monty Schmieman
          Monty Schmieman
          Monty Schmieman
          thxs Cor, ik heb dat gedaan maar zonder resultaat. Als ik MRA open en druk dan op drie balkjes links boven, krijg ik het start scherm. Vervolgens als ik dan links boven druk op het icoontje poppetje blokkeert het verder alles.
          MotoCon Marinus van Deudekom 2 Replies Last reply
            #20
            @Monty-Schmieman, vreemd. Ik zou proberen eens de cache te legen, ook weer in de Android systeem settings - Apps - Storage. Helpt dat ook niet, dan ook de gebruikersdata legen in datzelfde menu, maar dan moet je wel ook je offline maps opnieuw downloaden.
            Monty Schmieman 1 Reply Last reply
              Monty Schmieman
              Monty Schmieman
              Monty Schmieman
              @Con-Hennekens opgelost. App navigatie verwijderd en opnieuw ingesteld
                @Monty-Schmieman als je op het poppetje drukt kom je in het instellingen menu.
                Dat gaat sinds 2 updates erg langzaam, bij mij meer dan een minuut. Ik denk dat het door de offline kaarten komt. Heb daar eerder al wat over geschreven en bij @Corjan-Meijerink onder de aandacht gebracht
                Michel van Hagen MRA-Founder 1 Reply Last reply
                • Roberto 1f
                  Roberto 1f
                  Roberto 1f
                  Come mai sul telefono si vede la distanza alla prossima area di servizio mentre su android auto non si vede? Grazie
                  • Brian Martin
                    Brian Martin
                    Brian Martin
                    Information box still not working in Android auto!
                      Administrator
                      @Marinus-van-Deudekom Wij kunnen dat, tot nu toe, niet reproduceren, misschien kun je een keer langskomen in Zoetermeer, dan kunnen we kijken. Wel even melden van tevoren, want we werken niet altijd op kantoor. Kun je tevens een leuke goodiebag mee naar huis nemen.
                      โ€œPeople donโ€™t take trips, trips take people.โ€ โ€“ John Steinbeck
                        #26
                        @Michel-van-Hagen-MRA-Founder dat kan
                        Zijn jullie er morgen of vandaag
                          Administrator
                          @Marinus-van-Deudekom Zie PB.
                          • Jan 50
                            Jan 50
                            Jan 50
                            Indrukwekkend wat er nu allemaal is aangepast en verbeterd! Knap gedaan.
                            • Rob Verhoeff Rob Verhoeff referenced this topic on
                            Erik 35
                            Erik 35
                            Huibertus
                            Huibertus
                            Richard 18
                            Richard 18
                            Brian Martin
                            Brian Martin
                            Leo Klein
                            Leo Klein
                            Jan 50
                            Jan 50
                            Raf 7
                            Raf 7
                            Lynchy67
                            Lynchy67
                            Roberto 1f
                            Roberto 1f
                            Monty Schmieman
                            Monty Schmieman
                            John Vandenhove
                            John Vandenhove
                            SvenVH87
                            SvenVH87
                            nano
                            nano
                            Erik 2d
                            Erik 2d
                            • MRA Studio export speed
                            • A20 Edit tracklog โ€“ adjust the start or end point, and clean up zig-zag patterns.
                            • Map colours and side roads
                            • Control screen font size
                            • route bug
