  2. Routes & Tracks
  3. Incorrect mapversion of HERE in MRA
29 Posts 6 Posters 17.4k Views 2 Watching
  • Reinhard-32 Reinhard-32
    @Timo-Martosatiman-MRA
    Regarding to the Zumo XT. I own this model as well and I have checked the installed map (CN NTU 2020.30) and the road Segment is missing as well.
    But at the Zumo there is an additional map installed called TopoActive. This map is activated by default together with the CN 2020.30.
    The TopoActive Map is based on the OSM Maps and at this location the Road Segment is there. This could explain the calculation behavior at the Zumo XT.
    Rob Veerman
    Rob Veerman
    Rob Veerman
    @Reinhard-32
    Hello Reinhardt. That now explains why that part of the road is not present in Basecamp, because that TOPOActive map is not present in Basecamp.
    I have the Topo Active Map installed and active on my Zumo XT.
    I have now checked the situation again after having 'unticked' the TopoActive map and yes, that particular part then disappears on the map. Ticking the boxes again, the road is back. Thanks for letting me know the source of the problem. Riddle solved. Still; HERE has to make that correction for their regular map. Thanks a lot!
    • Rob Veerman Rob Veerman
      @Reinhard-32
      #20
      @Rob-Veerman
      Rob, connect your Zumo via USB with BaseCamp and wait for a while. Then you can select the TopoActive Map from the Map drop down menu. On my Maschine the south west part oft this map is visible only. That includes the Netherlands but not Germany.
        Using the HERE map in MRA (or in Basecamp) for crossing de 'Hogeweg' in Kamperveen (8278BA) tells us that that road is not an through road.
        Using the HERE map in my Garmin Zumo XT shows the correct version of the ongoing road. The OSM map and the TomTom map in MRA also show the correct situation.
        Why is the HERE map that MRA uses not correct and not the same as on the Zumo XT? It looks different versions are being distributed.
        @Rob-Veerman
        Hi Rob, this piece of road has already been mentioned on the forum once, it is true that there are several Here cards ...
        What you can do is use the "skip route point" option
        The different maps:
          @Rob-Veerman
          Rob Veerman
          Rob Veerman
          Rob Veerman
          @Reinhard-32
          Is there a way to download (copy) the TopoActive Map from the XT into Basecamp? Garmin Express doesn't show that (unlike the CityNavigator Map). I am using a MacBook
          HABVEN aka MrMRA Reinhard-32 2 Replies Last reply
            @Reinhard-32
            @Rob-Veerman
            Did you looked at the Garmin website?
            Rob Veerman 2 Replies Last reply
              @Rob-Veerman
              Rob Veerman
              Rob Veerman
              Rob Veerman
              wrote on last edited by Rob Veerman
              #24
              This post is deleted!
                @Rob-Veerman
                Rob Veerman
                Rob Veerman
                Rob Veerman
                @Hans-van-de-Ven-MRA-Master
                Not yet, but I will (and post my findings here).
                  @Rob-Veerman
                  The different maps:
                  Rob Veerman
                  Rob Veerman
                  Rob Veerman
                  Hans,
                  Thanks for the tip, I know that one and used it to connect the 2 roads together (because I constructed a route taking this 'winding' road and that route will also be used by other members of an accompanying group I am making a day trip with) and do use that option regularly, mostly in case of ferries in case of not being part of the MRA-database. Anyhow, bedankt voor het meedenken.
                    @Reinhard-32
                    #27
                    • Rob Veerman
                      Rob Veerman
                      Rob Veerman
                      #28
                      Hi Reinhardt,
                      I was about 10 seconds too late to copy your deleted posting. I think you will understand what I mean. Could you send me the text by email:
                      rob.veerman@icloud.com
                        Hi Reinhardt,
                        @Rob-Veerman
                        Rob, I deleted this because it was not working correctly for the moment. I did this procedure with other Garmins and it worked well but with the XT there was a problem. I know there is a problem with BaseCamp in combination with the ZumoXT. When you connect your zumo to BaseCamp only one of the two ToPoMaps Parts are shown. Garmin will fix this with one of the next updates.
                        I will send you an E- Mail tomorrow with the instructions anyway.
                        Rob Veerman
                        Rob Veerman
                        MyRoute-app community
                        • Online map settings
                          970
                          191
                          Tom Grzelinski
                          Tom Grzelinski
                        • MRA-pictogram
                          BMcG
                          BMcG
