  2. Routes & Tracks
  3. Incorrect mapversion of HERE in MRA
29 Posts 6 Posters 17.2k Views 2 Watching
    @Rob-Veerman Hi Rob,
    The HERE-map version in web and Navigation may differ for any number of reason, but as people correctly guessed already in this thread, this is by no means our (MRA) intention. Maintenance on these maps is done by HERE, not by MyRoute-app. Both Navigation and MRA Web use what's called an API key which facilitates the communication between HERE's map database and the different MyRoute-app services.
    To create a visual metaphor: imagine that instead of a routeplanner, MRA delivers you each day two boxes of apples. One day you open both boxes and find that one box (MRA Navigation) is empty whilst the other still has apples. This is what happened here, one service (WEB) has an updated version of the map you're looking for while the other service (Navigation) apparantly doesn't have the version you're looking for. We both don't expect this but it does happen occasionally. The reason for this is as good a guess for you as for us. The missing apples are not something we could have known about, since the orchard (HERE) gives us the boxes. Hopefully this answers your question as to how this could happen.
    Next question: why does MRA not report this to HERE? we do, however it does take some time for a specific question like this to get on our radar. To go back to the example of apples in boxes: when we send out the boxes we can't check every single box, instead the orchard promises to check them for us and correct it if something goes wrong.
    Now your final question: how come your Zumo does show the right route? This may have several reasons, but the most logical one that comes to mind is that the map on this Zumo isn't up to date. Again, this is pure speculation, but if all permantently connected services (Navigation, MRA Web and even Basecamp) show the exact same behavior, then it's most likely that this is the case. To go back once more to the example of apples: your Garmin XT might as well be an old box of old apples, there's no correlation between that box and the boxes you received today.
    I hope I've been as clear as possible. Thank you for your time.
    Kind regards,
    Timo
    @Timo-Martosatiman-MRA
    Regarding to the Zumo XT. I own this model as well and I have checked the installed map (CN NTU 2020.30) and the road Segment is missing as well.
    But at the Zumo there is an additional map installed called TopoActive. This map is activated by default together with the CN 2020.30.
    The TopoActive Map is based on the OSM Maps and at this location the Road Segment is there. This could explain the calculation behavior at the Zumo XT.
    • Reinhard-32 Reinhard-32
      Rob Veerman
      Rob Veerman
      Rob Veerman
      @Reinhard-32
      Hello Reinhardt. That now explains why that part of the road is not present in Basecamp, because that TOPOActive map is not present in Basecamp.
      I have the Topo Active Map installed and active on my Zumo XT.
      I have now checked the situation again after having 'unticked' the TopoActive map and yes, that particular part then disappears on the map. Ticking the boxes again, the road is back. Thanks for letting me know the source of the problem. Riddle solved. Still; HERE has to make that correction for their regular map. Thanks a lot!
      • Rob Veerman Rob Veerman
        @Reinhard-32
        #20
        @Rob-Veerman
        Rob, connect your Zumo via USB with BaseCamp and wait for a while. Then you can select the TopoActive Map from the Map drop down menu. On my Maschine the south west part oft this map is visible only. That includes the Netherlands but not Germany.
          Using the HERE map in MRA (or in Basecamp) for crossing de 'Hogeweg' in Kamperveen (8278BA) tells us that that road is not an through road.
          Using the HERE map in my Garmin Zumo XT shows the correct version of the ongoing road. The OSM map and the TomTom map in MRA also show the correct situation.
          Why is the HERE map that MRA uses not correct and not the same as on the Zumo XT? It looks different versions are being distributed.
          @Rob-Veerman
          Hi Rob, this piece of road has already been mentioned on the forum once, it is true that there are several Here cards ...
          What you can do is use the "skip route point" option
          The different maps:
            @Rob-Veerman
            Rob Veerman
            Rob Veerman
            Rob Veerman
            @Reinhard-32
            Is there a way to download (copy) the TopoActive Map from the XT into Basecamp? Garmin Express doesn't show that (unlike the CityNavigator Map). I am using a MacBook
            HABVEN aka MrMRA Reinhard-32 2 Replies Last reply
              @Reinhard-32
              @Rob-Veerman
              Did you looked at the Garmin website?
              Rob Veerman 2 Replies Last reply
                @Rob-Veerman
                Rob Veerman
                Rob Veerman
                Rob Veerman
                wrote on last edited by Rob Veerman
                #24
                This post is deleted!
                  @Rob-Veerman
                  Rob Veerman
                  Rob Veerman
                  Rob Veerman
                  @Hans-van-de-Ven-MRA-Master
                  Not yet, but I will (and post my findings here).
                    @Rob-Veerman
                    The different maps:
                    Rob Veerman
                    Rob Veerman
                    Rob Veerman
                    Hans,
                    Thanks for the tip, I know that one and used it to connect the 2 roads together (because I constructed a route taking this 'winding' road and that route will also be used by other members of an accompanying group I am making a day trip with) and do use that option regularly, mostly in case of ferries in case of not being part of the MRA-database. Anyhow, bedankt voor het meedenken.
                      @Reinhard-32
                      #27
                      • Rob Veerman
                        Rob Veerman
                        Rob Veerman
                        #28
                        Hi Reinhardt,
                        I was about 10 seconds too late to copy your deleted posting. I think you will understand what I mean. Could you send me the text by email:
                        rob.veerman@icloud.com
                          Hi Reinhardt,
                          @Rob-Veerman
                          Rob, I deleted this because it was not working correctly for the moment. I did this procedure with other Garmins and it worked well but with the XT there was a problem. I know there is a problem with BaseCamp in combination with the ZumoXT. When you connect your zumo to BaseCamp only one of the two ToPoMaps Parts are shown. Garmin will fix this with one of the next updates.
                          I will send you an E- Mail tomorrow with the instructions anyway.
                          Rob Veerman
                          Rob Veerman
                            814
                            Grant de-St-Croix 1 0
                          • Trips in Commercial Clubs?
                            Mike West
                            Mike West
                            Marcel Versluis
                            Marcel Versluis
                          • Exporting GPX
                            smfollen 0
                            smfollen 0
                          • Na rit vanuit event geen tracklog
                            Hanza 0
                            Hanza 0
                          • Storage of tracklogs
