  2. Routes & Tracks
  3. Incorrect mapversion of HERE in MRA
29 Posts 6 Posters 17.2k Views 2 Watching
  • Rob Veerman Rob Veerman
    Using the HERE map in MRA (or in Basecamp) for crossing de 'Hogeweg' in Kamperveen (8278BA) tells us that that road is not an through road.
    Using the HERE map in my Garmin Zumo XT shows the correct version of the ongoing road. The OSM map and the TomTom map in MRA also show the correct situation.
    Why is the HERE map that MRA uses not correct and not the same as on the Zumo XT? It looks different versions are being distributed.
    @Rob-Veerman
    Hi Rob, this piece of road has already been mentioned on the forum once, it is true that there are several Here cards ...
    What you can do is use the "skip route point" option
    The different maps:
    • Reinhard-32 Reinhard-32
      @Rob-Veerman
      Rob, connect your Zumo via USB with BaseCamp and wait for a while. Then you can select the TopoActive Map from the Map drop down menu. On my Maschine the south west part oft this map is visible only. That includes the Netherlands but not Germany.
      Rob Veerman
      Rob Veerman
      Rob Veerman
      @Reinhard-32
      Is there a way to download (copy) the TopoActive Map from the XT into Basecamp? Garmin Express doesn't show that (unlike the CityNavigator Map). I am using a MacBook
      HABVEN aka MrMRA Reinhard-32 2 Replies Last reply
        @Reinhard-32
        @Rob-Veerman
        Did you looked at the Garmin website?
        Rob Veerman 2 Replies Last reply
          @Rob-Veerman
          Rob Veerman
          Rob Veerman
          Rob Veerman
          wrote on last edited by Rob Veerman
          #24
          This post is deleted!
            @Rob-Veerman
            Rob Veerman
            Rob Veerman
            Rob Veerman
            @Hans-van-de-Ven-MRA-Master
            Not yet, but I will (and post my findings here).
              @Rob-Veerman
              The different maps:
              Rob Veerman
              Rob Veerman
              Rob Veerman
              Hans,
              Thanks for the tip, I know that one and used it to connect the 2 roads together (because I constructed a route taking this 'winding' road and that route will also be used by other members of an accompanying group I am making a day trip with) and do use that option regularly, mostly in case of ferries in case of not being part of the MRA-database. Anyhow, bedankt voor het meedenken.
                @Reinhard-32
                #27
                • Rob Veerman
                  Rob Veerman
                  Rob Veerman
                  #28
                  Hi Reinhardt,
                  I was about 10 seconds too late to copy your deleted posting. I think you will understand what I mean. Could you send me the text by email:
                  rob.veerman@icloud.com
                    Hi Reinhardt,
                    @Rob-Veerman
                    Rob, I deleted this because it was not working correctly for the moment. I did this procedure with other Garmins and it worked well but with the XT there was a problem. I know there is a problem with BaseCamp in combination with the ZumoXT. When you connect your zumo to BaseCamp only one of the two ToPoMaps Parts are shown. Garmin will fix this with one of the next updates.
                    I will send you an E- Mail tomorrow with the instructions anyway.
                    Rob Veerman
                    Rob Veerman
                    MyRoute-app community
                      814
                      Grant de-St-Croix 1 0
                    • Trips in Commercial Clubs?
                      Mike West
                      Mike West
                      Marcel Versluis
                      Marcel Versluis
                    • Exporting GPX
                      smfollen 0
                      smfollen 0
                    • Na rit vanuit event geen tracklog
                      Hanza 0
                      Hanza 0
                    • Storage of tracklogs
