  4. Extra navigation needed in warm weather (sunlight)...
15 Posts 9 Posters 198 Views 3 Watching
  • Dikke Wimundefined Offline
    Dikke Wim
    When navigating in warm weather my iPhone 13 Pro Max becomes so hot that the brightness of the screen goes down. Then it's impossible to navigate.
    Unfortunately this implies for me that I remain to use my BMW Navigator V as a backup.
    Fortunately, I can add my routes to my BMW Navigation V with a wired connection. This way I have the necessary backup navigation.
    Bart De Medtsundefined 1 Reply Last reply
    • Dikke Wimundefined Dikke Wim
      @Dikke-Wim Last weekend I had the same problem, but if I am correct they are working on it 😉
      Dikke Wimundefined 1 Reply Last reply
      • Nick Carthewundefined Nick Carthew moved this topic from General Discussion on
        Moved to the BETA forum
        • Bart De Medtsundefined Bart De Medts
          Dikke Wim
          @Bart-DM
          As far as I know, this has nothing to do with Navigation Next, but has everything to do with the iPhone. Maybe I'm mistaken.
          If that is the case I would like to know!
            @Bart-DM
            @Dikke-Wim It's a combination of both factors I guess.
              Dikke Wim
              @Bart-DM
              You could be (are probably) right. MyRoute Next uses a lot of processor time and heats up the iPhone.
              Thanks for your fast reply!
              • Jörgenundefined Offline
                Use a Carplay device for bikes, then you can keep your phone in your pocket.
                richtea999undefined 1 Reply Last reply
                • Jörgenundefined Jörgen
                  richtea999undefined Offline
                  @Jörgen said in Extra navigation needed in warm weather (sunlight)...:
                  Hmmm. The whole point of MRA Nav Next is to avoid buying yet another device.
                  https://support.apple.com/en-us/HT201678
                  'Additionally, if you're navigating, your device might show this alert and turn off the display: "Temperature: iPhone needs to cool down." Navigation still provides audible turn-by-turn directions. When approaching a turn, the display will illuminate to guide you through the turn.'
                  That 'approaching a turn' option may be available to MRA Nav Next, but knowing Apple it's probably specific to just their own navigation apps. One for investigation later, maybe.
                    Correct, battery usage is the top priority but unfortunately part of it is HERE.
                    Battery usage = high CPU usage = temperature increase
                    Kudeeundefined CD130undefined 2 Replies Last reply
                      @richtea999 said in Extra navigation needed in warm weather (sunlight)...:
                      That may be right, but "normal" smart phones are not made for heat, rain and vibration. So may be kill better a less than 200€ device then a 1000€ smart phone. jm2c
                        Kudeeundefined Offline
                        Kudee
                        @Corjan-Meijerink Iphone könnte das Problem sein. Mein Huawei P30 Pro wird moderat warm und wird sogar wireless geladen wärend der Fahrt. Bei Ankunft immer 90 -100% Ladung
                          CD130undefined Offline
                          @Corjan-Meijerink even wat testjes gedaan de afgelopen dagen. Beschik over een Quad Lock QI lader op de motor.
                          20 graden
                          30 minuten
                          52% start
                          52% stop
                          MRA aan
                          Scherm aan
                          17 graden
                          20 minuten
                          42% start
                          48% stop
                          Google Maps aan, MRA uit
                          Scherm aan
                          13 graden
                          20 minuten
                          92% start
                          97% stop
                          MRA uit
                          Scherm uit
                          20 graden
                          30 minuten
                          72% start
                          89% stop
                          MRA uit
                          Scherm uit
                          Conclusie en geen verassing 🙂 :
                          MRA trekt aardig wat stroom.
                            @CD130
                            Not only MRA Next. Other navigation apps also but MRA Next is clearly the winner.
                            Make sure your phone is mounted in the wind for cooling. This helps a lot.
                            @Jörgen
                            Keep the phone in your pocket with Carplay or AA is bad advice. The phone will stil get very hot.
                            Also with Carplay of AA the will need cooling.
                            • CD130undefined CD130
                              20 graden
                              30 minuten
                              52% start
                              52% stop
                              MRA aan
                              Scherm aan
                              17 graden
                              20 minuten
                              42% start
                              48% stop
                              Scherm aan
                              13 graden
                              20 minuten
                              92% start
                              97% stop
                              MRA uit
                              Scherm uit
                              20 graden
                              30 minuten
                              72% start
                              89% stop
                              MRA uit
                              Scherm uit
                              Dikke Wim
                              @CD130
                              Ik neem aan dat je in alle gevallen het scherm op dezelfde helderheid hebt gehad?
                              CD130undefined 1 Reply Last reply
                                @CD130
                                @Dikke-Wim ja, op 100% 🙂
                                CD130undefined
                                richtea999undefined
                                Dikke Wimundefined
                                Dikke Wim
                                Kudeeundefined
                                Kudee
                                  Gianluca 0undefined
                                  Gianluca 0
                                  474
                                • Updated beta! 5.2.1 (486)
                                  342
                                • Creating routes on HERE versus TomTom
                                  Hans Ruttenundefined
                                  Hans Rutten
                                  Lenny Oundefined
                                  Lenny O
                                  7.2k
                                  Massimo Cardoneundefined
                                  Massimo Cardone
                                  7.9k
                                • inconsistent travel times
                                • exporteren naar xt2
                                  toni cccundefined
                                  toni ccc
                                • Hello guys again, please help
