  2. Routes & Tracks
  3. Move routes of position
23 Posts 11 Posters 12.5k Views 3 Watching
  • fbarr47gmail.com
    fbarr47gmail.com
    fbarr47gmail.com
    I don't know how to move a route position. I have a folder with several routes in a country and they are not in order. How do I order them?
    thanks!
    Nick Carthew Reinhard-32 3 Replies Last reply
    • fbarr47gmail.com fbarr47gmail.com
      thanks!
      @FRANCISCO-BARRENA Click the title of the column in your library to change the order. Name, Type, Change etc click it again to reverse the order.
      fbarr47gmail.com 1 Reply Last reply
      • Rob Veerman
        Renaming your routes by giving them a letter, number (by date or whatever). They will then be sorted in that new order.
          fbarr47gmail.com
          fbarr47gmail.com
          fbarr47gmail.com
          @Nick-Carthew sorry but that not work like this. If CLICK the title , OPEN the file... I want place in order. I want go down 2 places more down. I can't mark the file and drag it to another position?? that would be simple.
          Rob Veerman Marinus van Deudekom 2 Replies Last reply
            @FRANCISCO-BARRENA As I wrote, rename the files. Something like 240601, 240602, 240603 and your files will be sorted that way.
            • Rob Veerman Rob Veerman
              fbarr47gmail.com
              fbarr47gmail.com
              fbarr47gmail.com
              @Rob-Veerman but I don,t want rename the files... I prefer the files with the name of the route.. Not is possible to drag the files to another position????
                @FRANCISCO-BARRENA what you want is impossible. You like Nick said you can sort them by clicking on the column's title. By name date etc. Changing the order in witch they appear can't be done without changing the titles like Rob said
                  thanks!
                  Reinhard-32
                  Reinhard-32
                  Reinhard-32
                  @FRANCISCO-BARRENA said in Move routes of position:
                  thanks!
                  You can add a number at first as beginning of the route name.
                  Kindly regards
                  Reinhard
                  Montana 700i and Mac
                  TomOnTour fbarr47gmail.com 2 Replies Last reply
                  • Reinhard-32 Reinhard-32
                    thanks!
                    TomOnTour
                    TomOnTour
                    TomOnTour
                    @Reinhard-32 said in Move routes of position:
                    thanks!
                    That is exactly how I do it with my routes. 🙂
                    Works perfect for me.
                    Greetings
                    Thomas
                    Erdna 1 Reply Last reply
                    • TomOnTour TomOnTour
                      thanks!
                      Greetings
                      Thomas
                      @TomOnTour said in Move routes of position:
                      thanks!
                      Greetings
                      Thomas
                      Same here.
                        thanks!
                        fbarr47gmail.com
                        fbarr47gmail.com
                        fbarr47gmail.com
                        @Reinhard-32 yes, like this I have done in my routes and not work properly. The route num 3 not in position
                          Reinhard-32
                          Reinhard-32
                          Reinhard-32
                          @FRANCISCO-BARRENA That is strange. I can see there are dots in your route names and after the route numbers. Remove them could be helpful. It is often not a good idea use special characters in file names.
                          Kindly regards
                          Reinhard
                          GT JWR 1 Reply Last reply
                            GT JWR
                            GT JWR
                            GT JWR
                            @Reinhard-32 the dots are because the name is longer than the space it's in...if that section was resized to show the entire name, the dots would not be there.
                            • GT JWR GT JWR
                              Reinhard-32
                              Reinhard-32
                              Reinhard-32
                              #14
                              @GT-JWR I know that behavior. I was referring to the dots marked in the screenshot.
                              Kindly regards
                              Reinhard
                                fbarr47gmail.com
                                fbarr47gmail.com
                                fbarr47gmail.com
                                I removed the points and it's still the same. This cannot be a mistake, it is very basic. I don't understand
                                  Reinhard-32
                                  Reinhard-32
                                  Reinhard-32
                                  #16
                                  @FRANCISCO-BARRENA
                                  No. 3 sticks out, that‘s weird. When you close your browser and restart it, does it help?
                                  You could temporarily rename route no. 3 to something like 15 or so.
                                  BTW: The sort order goes from left to right and from numbers to letters.
                                  If you have more than 9 routes it is recommended to use 2 digits like this:
                                  01
                                  02
                                  09
                                  Otherwise you will get:
                                  21
                                  Kindly regards
                                  Reinhard
                                    @FRANCISCO-BARRENA
                                    01
                                    02
                                    09
                                    21
                                    @Reinhard-32 not the colum with the names is selected but it seems like the colum date is selected
                                    Herko ter Horst MotoCon 2 Replies Last reply
                                      Herko ter Horst
                                      Herko ter Horst
                                      Herko ter Horst
                                      #18
                                      @Marinus-van-Deudekom Where do you see that? The name column has the "sorting" arrow on it, which as far as I know, means it's selected. Plus it's light blue, so it's definitely selected.
                                        @Herko-ter-Horst My bad. I let myself being confused by the order of the date time colum.
                                          @Marinus-van-Deudekom said in Move routes of position:
                                          In that case Route 8 would be sticking out 😉
                                          But no, the name column is selected.
                                          TomOnTour
                                          TomOnTour
                                          Reinhard-32
                                          Reinhard-32
                                          GT JWR
                                          GT JWR
                                          BFG
                                          BFG
                                          Herko ter Horst
                                          Herko ter Horst
                                          fbarr47gmail.com
                                          fbarr47gmail.com
                                            Jacob Waterweg
                                            Jacob Waterweg
                                            96
                                            Edwin van Klink 6
                                            Edwin van Klink 6
                                          • Startpunt wijzigen
                                            Ad V
                                            Ad V
                                            Giancarlo e
                                            Giancarlo e
                                          • Route exporteren uit beta
                                            Johan 5q
                                            Johan 5q
                                          • PDF export: suggested additional options
                                            Emanuele 5
                                            Emanuele 5
