  4. My Route ignores Ferry-route
6 Posts 2 Posters 2.0k Views
  • Giver
    Giver
    Giver
    wrote on last edited by Giver
    Hi There,
    I'm new with My Route. Trying to create my first route to Danmark.
    I wanted to include the Ferry from Rostock to Gedser. But My Route keeps navigating from Rohstock to Putgarden to hop on an other Ferry.
    Perhaps there's a impossibility in my idea, but the ferry seems to be available and running.
    Does anyone have a clue why My Route refuses while MyDrive accepts this?
    Gil
    Nick Carthew 2 Replies Last reply
    • Giver Giver
      Hi There,
      Gil
      @Gil-2 Place a route point on both sides of the ferry and choose the skip function on the far side.
      Giver 1 Reply Last reply
      • Giver Giver
        Hi There,
        Gil
        @Gil-2 If I use the HERE, OpenStreetMap or the TomTom map for planning, none of these maps use the ferry from Rostock. Are you sure that it is still operating?
          Giver
          Giver
          Giver
          This post is deleted!
            Giver
            Giver
            Giver
            @Nick-Carthew
            TomTom Mydrive does and it is bookable on internet.
            I could not find that 'SKIP' function but I found the same icon on the section function, 'OFFROAD'. That works; from begin to end Ferry-route OFFROAD. Makes sense!
            Thanks for pointing me the right direction!
            • Giver Giver
              @Nick-Carthew
              @Gil-2 said in My Route ignores Ferry-route:
              @Nick-Carthew
              The Off-road option is only available if you are using the OpenStreetMap to plan your route.
              If you intend to use your route for a Garmin GPS device you need to use the Compare with Garmin tool from the toolkit.
              If your device is a TomTom, use the Compare with TomTom tool.
              With the tool turned on, place enough route points so that your track on the OSM map is the same as the Garmin or TomTom.
              Giver
              Giver
                Thomas Schäfer
                Thomas Schäfer
                superg
                superg
              • reuse pictures
