  3. Beta Instructions 🍏iOS (Forum)
Scheduled Pinned Locked Moved [App-Beta] The MyRoute-app
42 Posts 25 Posters 1.8k Views 5 Watching
  • MyRoute-app community
    Administrator
    wrote on last edited by MyRoute-app community
    👋Welcome Tester!
    If your application for the iOS Beta of MRA Navigation Next has been approved, you can get started with the instructions below. Do the check below one more time:
    1. Have you signed up for the iOS Beta?
      Please take a good look at the e-mail you received from us. iOS should be listed under the 'test platform'. Is this correct?
      💚Yes, go to the next question.
      ⛔No, then please send an email to support@myrouteapp.com and include your iOS email address so that we can add you.
    2. Has your spot been released?
      You should have received an email from us entitled “Access ticket MRA Navigation Next Beta”. Correct?
      💚Yes, nice! You have been cleared to participate in the Beta.
      ⛔No, your spot has not been released yet. We add new users to the test environment every two weeks.
    Answered yes to all of the above? Then you can continue with the following instructions.
    ⚠️Make sure you have read the above questions carefully to avoid confusion.
    ⚠️Please note: MyRoute-app is developing MRA Navigation Next as part of our one app vision. That means that the Beta of MRA Navigation Next will be held through the well-known “MyRoute-app Mobile” app.
    How to participate in the Beta:
    1. You have received an email to the email address your iPhone is registered with from “ TestFlight ”, open that email and accept the invitation;
    2. Download the " TestFlight " app from the App Store. This app is required to download the Beta on your iPhone;
    3. Open the TestFlight app;
    4. Follow TestFlight 's instructions and download the latest version of the beta .
    5. Finished!
    Have fun testing!
    ⚖️Conditions for testers
    From this moment you can participate in the Beta version. When the Beta ends you will also receive an email from us about the best way to deactivate it. To make good use of the Beta, here are some rules to keep in mind:
    🤷Questions, problems and suggestions
    As a tester you may want to make the most of your opportunities to influence the development of MRA Navigation Next. Which can. You do this by starting discussions and participating in ongoing discussions on the MRA Navigation Next Forum. The MRA team actively watches, writes and reads along.
    💔Note: fragile!
    A Beta is an 'early version' of the final product. This means that not all functionalities may be available yet, the experience varies from version to version and problems may arise during use. Problems, bugs and suggestions are therefore not dealt with via support, but via the forum.
    🙅I don't want to be a beta tester anymore.
    You can install the production version from the App Store at any time. Before you do that, please uninstall the Beta installation first. Otherwise you run the risk that the app will not start. Do you want the test version again? Which can! Just go back to the TestFlight app.
    😱Help! I can't access the beta
    Are you unable to participate in the Beta with the above instructions and have you checked whether you have access? Don't worry, you can send us an email at support@myrouteapp.com . Then we will help you on your way again.
    • MyRoute-app community MyRoute-app community pinned this topic on
    • Albert Renting
      Albert Renting
      Albert Renting
      Ik krijg mails die ik verstuur naar support@myrouteapp.com terug als onbestelbaar?
      Wil van Hulst Michel van Hagen MRA-Founder 2 Replies Last reply
      • Albert Renting Albert Renting
        Wil van Hulst
        Wil van Hulst
        Wil van Hulst
        @Albert-Renting ik ook
        Michel van Hagen MRA-Founder 1 Reply Last reply
        • Wil van Hulst Wil van Hulst
          Administrator
          @Wil-van-Hulst Is hersteld, doet het nu wel.
            Administrator
            @Albert-Renting Is hersteld, doet het nu wel.
            Albert Renting 1 Reply Last reply
            • Michel van Hagen MRA-Founder Michel van Hagen MRA-Founder
              Albert Renting
              Albert Renting
              Albert Renting
              @Michel-van-Hagen-MRA-Founder Dank!
              • Arjan de Vries
                Arjan de Vries
                Arjan de Vries
                Ik heb de benodigde emails. Ik heb de app testflight gedownload (iOS).
                Dan moet ik een code invoeren (wissel code in).
                En die code heb ik niet. In beide mails niet.
                Hoe nu verder?
                Corjan Meijerink TorqueRider 2 Replies Last reply
                  Hoe nu verder?
                  @Arjan-de-Vries Klikken op de knop in de mail van TestFlight zou voldoende moeten zijn.
                  Mart Hanssen Arjan de Vries 2 Replies Last reply
                    Hoe nu verder?
                    @Arjan-de-Vries
                    en @Mart-Hanssen
                    Als je de procedure gevolgd hebt staat MyRoute in het venster . Als je daar op tikt kun je de app openen.
                      Mart Hanssen
                      Mart Hanssen
                      Mart Hanssen
                      @Corjan-Meijerink: hoi Cor-Jan,
                      ik ervaar hetzelfde. TestFlight vraagt direct om wisselcode. Deze heb ik niet en iets anders kan ik niet aanklikken.
                      • Mart Hanssen Mart Hanssen
                        @Mart-Hanssen Als de instructies precies worden gevolgd, zou het goed moeten gaan.
                        Als je TestFlight hebt geïnstalleerd, ga terug naar de mail die je van TestFlight hebt gehad en klik hier wederom op de knop. Als het goed is, opent TestFlight nu en heb je toegang tot de Beta.
                        @Jack-van-Tilburg Bedankt voor de bevestiging!
                        Siepermann- Ronald Mart Hanssen 2 Replies Last reply
                          Siepermann- Ronald
                          Siepermann- Ronald
                          Siepermann- Ronald
                          @Corjan-Meijerink hier had ik vandaag ook last van. Ben naar de link gegaan van de oude versie van MyRoute-app en deze toen aangeklikt. MyRoute Navigation Next startte toen wel op.
                          • Jose Pinheiro 0
                            Jose Pinheiro 0
                            Jose Pinheiro 0
                            Hi.
                            I'm trying to test the beta version, but I think that I only get the some old version of MRA, and not the navigation next.
                            I've opened the app from the TestFligth, after following the instructions on email.
                            Is this the layout of MRA Navigation Next? I can't see the turn-by turn information, and it just look like the old version:
                            "So many roads, so little time"
                            • Jose Pinheiro 0 Jose Pinheiro 0
                              Hi.
                              @Jose-Pinheiro-0 This is the correct version. Instead of opening the route, you can click on the "Navigation" icon (most right in the row containing 4 buttons).
                              Note: track navigation is not support
                              Jose Pinheiro 0 1 Reply Last reply
                                Arjan de Vries
                                Arjan de Vries
                                Arjan de Vries
                                @Corjan-Meijerink werkt
                                  Jose Pinheiro 0
                                  Jose Pinheiro 0
                                  Jose Pinheiro 0
                                  wrote on last edited by Jose Pinheiro 0
                                  #16
                                  @Corjan-Meijerink What I'm doing is:
                                  1. Search the destination and click on "Generate"
                                  2. After the route is presented, I choose "Start"
                                  3. The Navigation starts, but without tur-by-turn information
                                  I believe I'm doing something wrong, but can't figured out what is it 😞
                                  Christopher M Kelly 1 Reply Last reply
                                    Mart Hanssen
                                    Mart Hanssen
                                    Mart Hanssen
                                    @Corjan-Meijerink Het werkt. Probleem lag in de e-mailadressen. Als je een ander e-mailadres gebruikt dan je apple account.
                                      Christopher M Kelly
                                      Christopher M Kelly
                                      Christopher M Kelly
                                      @Jose-Pinheiro-0 above the 'Generate' button select the right-hand button'Y' shape and then tap 'Generate'
                                      I ride for work, I work to ride
                                      • Christopher M Kelly Christopher M Kelly
                                        Jose Pinheiro 0
                                        Jose Pinheiro 0
                                        Jose Pinheiro 0
                                        @Christopher-M-Kelly Thank you.
                                        You are right. I'm using the button on the left and it doesn't work, but with the button on right "the Y button" it works. 🙂
                                          @Arjan-de-Vries Super!
                                          Arjan de Vries
                                          Arjan de Vries
                                          Dikke Wim
                                          Dikke Wim
                                          Siepermann- Ronald
                                          Siepermann- Ronald
                                          Albert Renting
                                          Albert Renting
                                          Paul 41
                                          Paul 41
                                          Herko ter Horst
                                          Herko ter Horst
                                          Frappawotsit
                                          Frappawotsit
                                          Ad Koppenol
                                          Ad Koppenol
                                          M Gaudion 0
                                          M Gaudion 0
                                          Mart Hanssen
                                          Mart Hanssen
                                          Jose Pinheiro 0
                                          Jose Pinheiro 0
                                          JoukeStroo
                                          JoukeStroo
                                          ron putting
                                          ron putting
                                          Wil van Hulst
                                          Wil van Hulst
                                          Christopher M Kelly
                                          Christopher M Kelly
                                          Ewen Fowler
                                          Ewen Fowler
                                          Evert-Jan 0
                                          Evert-Jan 0
                                          WoFi
                                          WoFi
                                          • MyRoute-app offline
                                            Rob Kelley
                                            Rob Kelley
                                            47.6k
                                          • route bug
                                          • Tekst Startpunt blijft in beeld
                                          • Hiya from UK
                                          • Kaart loopt achter op de anwijzingen
                                          • Pay for beta?
                                          • Friends synchronisation?
                                          • wegnummers / aanduiding wel heel erg klein!
