  2. Announcements
  3. Other standard map
Other standard map
25 Posts 11 Posters 13.5k Views 1 Watching
    @Baltus said in Other standard map:
    @Nick-Carthew
    Nick, thanks for your reply. Ofcourse you can make bike routes with the MRA- mobile app. That is the same as MRA on the pc. But you can not use the app to navigate. Therefore you need the navigation app. But...... the navigation app only works with Here maps. If you load your OSM bike route.gpx into the navigation app than it rebuild your complete route, because the Here map does not have bikepaths. The new route sends you to the moon and even further.
    The MRA Mobile app does have a navigation function and is perfect for cycling. Design a route on the OSM planning map (use the OpenCyclemap overlay) and choose cycling as the form of transport. Then open that route in the MRA Mobile app and click the arrow in the bottom right of the screen twice, you will see that the position cursor changes to a blue arrow, you are now in navigation mode. Navigation is only follow the line with no spoken instructions but it does have auto zoom that changes the zoom level with speed.
    Baltus
    Baltus
    Baltus
    @Nick-Carthew
    Nick, this is an eyeopener for me. I found the MRA mobile app not useful. Most of the time i have my laptop with me. So if i want to make or adjust a route that is the thing i use.
    The only question i have now is: How much mobile data wil it cost if i navigate this way. I can not make use of offline maps nor a downloaded route. Do you have any idea. If Not, I simply give it a try.
    Baltus.
    • Baltus Baltus
      @Nick-Carthew
      Baltus.
      @Nick-Carthew
      Baltus.
      I don’t have an exact answer but I would think that mobile data usage will be minimal. Give it a try, I’m sure that you will be pleasantly surprised.
      • Baltus Baltus
        Dear Michel. When will it be possible to make use of the OSM in the navigation app?
        I bought the app to use aspecially for my bike tours. In MRA it is possible to make very nice bike routes with the OSM. But in the navigation app it is impossible to play them.
        Best regards, Baltus.
        sudolea
        sudolea
        sudolea
        @Baltus I suggest you give it a try to use OsmAnd as your bike navigation app. Construct your routes in the OSM map with MRA, and load them up in the OsmAnd app. I've never used it to navigate myself, but I know there is a bike mode, and you can upload your tracks in it. Should it be said, it works (only ?) with OSM card material. And it looks finished, I can tell...
        • Nick Carthew Nick Carthew forked this topic on
        • Con Hennekens
          @John-Roberts, I am in no way affiliated to MyRouteApp and have no video's whatsoever. But I am willing to try to help. But that is difficult if you don't tell what satnav we are talking about, do not link your route and share no screenshots. But if your device acknowledges new data, and then cannot find it, the problem lies most likely within your device.
          John Roberts 1 Reply Last reply
          • Hans van de Ven MR.MRA
            @John-Roberts said in Other standard map:
            Hello Con-Hennekens
            I can create a route on myrouteapp with no problem, but when I transfer it in the standard way exactly as demonstrated by your video, my satnav acknowledges it has received "new data" but when I select ok, the satnav then advises "no data found".
            I have created over the years several routes, but just lately it is not transferring to my Garmin?
            Have you had other users with the same problem?
            Can you advise how I can resolve this please?
            Hi John,
            Some questions and suggestions:
            Which Zumo do you have?
            Is your ZUMO upToDate, maps and software.
            Do you have the latest version of the connector? (Windows 49.msi & Mac 24.pkg)
            Which file are you transferring? (gpx.....)
            Share your route, so we can see if it might be the route.
            • System unpinned this topic on
            Drabslab
            Drabslab
            Baltus
            Baltus
            Michel van Hagen MRA-Founder
            Steve Lynch
            Steve Lynch
            sudolea
            sudolea
            John Roberts
            John Roberts
            Andries Mulder
            Andries Mulder
              Drabslab
              Drabslab
              2.4k
              2.2k
            • Elektrisch voertuig
              715
            • Eerste keer MRA met Android auto, een wat mindere ervaring
              AWDC LAO
              AWDC LAO
            • Seizoensafsluitingen
            • Altitude numbers size
              RainerT
              RainerT
            • Hoe kan ik in één route een stuk met en een stuk zonder snelwegen plannen
