  3. two or more seperate tracks in a single GPX-file
10 Posts 5 Posters 3.2k Views 1 Watching
  • Bas de Haan
    Bas de Haan
    Bas de Haan
    wrote on last edited by Bas de Haan
    Hello!
    This is my first forum post, however I have already used MRA for the past 3 years.
    In these years I still haven't been able to find a function to combine several tracks into a single GPX file.
    In such a way that the indivudual tracks/routes are still visible in the navigation device. This would be (in my eyes) a nice feature to simplify sharing multiday trips with friends. Does this feature exist within MRA? if so, where can I find it?
    I know it is possible (Basecamp for instance does it) and I usually just combine the waypoints within the standard windows notepad. This never caused an issue for both garmin or TT.
    [edit to translate title to English]
    HABVEN aka MrMRA sudolea 2 Replies Last reply
    • Bas de Haan Bas de Haan
      Hello!
      @Bas-de-Haan
      You can only make them visible in a route, not save then in a gpx
        Hello!
        sudolea
        sudolea
        sudolea
        @Bas-de-Haan You may want to convert the route-tracks (i.e. initially created from individual gpx files and imported as a route-track) to a route, and put all those (converted-to-route) routes in some public folder so that the rest the group can access them. If you then consequently want to visualise those routes together, next to each other (or should I say "simultaneously"), you can select one and select the tab "Routes" at the left, and then "Add" (toevoegen); you can even give each of them a different visualised color.
        Maybe not exactly what you're after (and somewhat cumbersome), but who knows (and hopefully) close enough ?
        Bas de Haan 1 Reply Last reply
        • Steve Lynch
          Steve Lynch
          Steve Lynch
          Isn’t the answer here to do it the other way round?
          As in create the whole multi day route first because if you are a Gold MRA user then you can split routes in MRA.
          If you are using MRA Navigation app you could use different waypoint colours to separate the days for the whole multi day route.
          Bas de Haan MotoCon 2 Replies Last reply
          • Steve Lynch Steve Lynch
            Bas de Haan
            Bas de Haan
            Bas de Haan
            @Steve-Lynch That could work, but I do not use the MRA navigation app, just the "make a route" module. The main reason I'd like just one GPX for let's say 5 seperate tracks is because my friends all use different kinds of software & navigation device. Just sharing one file instead of five is so much easier and less likely to cause differences in version (that is if everyone just uses the latest version of the single file).
            • sudolea sudolea
              Bas de Haan
              Bas de Haan
              Bas de Haan
              @sudolea Unfortunately not everyone of my friends use MRA (they're dumb, I know 😉 ). so doing that is not truely viable option. Having everyone (even the less tech savvy) just importing a single GPX to a TT or garmin device is the most reliable option (so far, at least for us).
              Steve Lynch sudolea 2 Replies Last reply
                Steve Lynch
                Steve Lynch
                Steve Lynch
                @Bas-de-Haan said in two or more seperate tracks in a single GPX-file:
                If you make your route public in MRA then you can share a link via email to your group which will take them to your specific route in MRA.
                This will allow them to download the route as a GPX1.1 without even Registering or having an account.
                Once your Group actually see’s MRA in action you may even convert a few. 👍
                I will log out to provide some screenshots and paste them here
                The user clicks "Use Route"
                .Screenshot 2021-06-30 at 06.47.28.jpg Screenshot 2021-06-30 at 06.49.52.jpg
                  sudolea
                  sudolea
                  sudolea
                  @Bas-de-Haan Then I suggest you save the several routes as (separate) gpx files, and compress them to a zipped folder. Maybe not ideal, but if your friends can get a single gpx into their own gps devices, they for sure will be able to repeat the same procedure as many times as there are routes 🙂
                  Of course, they can start using (the free version of) MRA too : maybe that's less cumbersome 😉
                    @Steve-Lynch said in two or more seperate tracks in a single GPX-file:
                    I don't think that is a practical practice (yet). Because when you start it will default to the beginning of your route (which is day1). Skipping waypoints goes one-by-one. I think having multiple routes (for each day) in one event is much more practical.
                      Steve Lynch
                      Steve Lynch
                      Steve Lynch
                      Yes I agree totally that having the files split by days is a far better option but the OP did ask for a solution to “Merge” individual routes which is not currently possible but splitting the whole Multi Day route is. (and therefore possibly less work)
                      Also agree on MRA Navigation use and the issues.
                      I don’t generally use it but have ran some tests recently on my Samsung S10 5G.
                      I haven’t had any issues with it so far but do see issues for iOS on my iPad but can’t test it on the road.
                      Steve Lynch
                      Steve Lynch
                      sudolea
                      sudolea
                      Bas de Haan
                      Bas de Haan
                      • Kaart niet zichtbaar
                        212
                        22
                        41
                        363
                      • Xpert overlay not clear
                        Corrado Miniati 0
                        Corrado Miniati 0
                      • Google maps
                        Ed Bos 0
                        Ed Bos 0
                        208
                      • Trains like Ferries?
                        Corrado Miniati 0
                        Corrado Miniati 0
                        288
