  4. Map "spinning" when standing still
110 Posts 33 Posters 46.7k Views 10 Watching
    Yeah, that’s the annoying thing of these issues. It’s definitely device related so some have it, others do not. GPS positioning and especially on Android devices is not always as accurate as you’d hope.
    • peha
      peha
      peha
      wrote on last edited by peha
      #42
      With my Samsung S22 Ultra, it is reproducibly a problem that occurs with MyRouteApp, but not with Google Maps: Sitting on my couch at home, phone laying on a table (i.e., not moving at all, not being touched), after I have opened MRA on the phone, the "view direction" (map orientation) changes several times for about 90 or 180 degrees, the movement pauses some seconds and then moves again. When it finally settles, it doesn't point in the actual direction the phone faces. Moving the phone after it has "settled", the map doesn't react any longer (map not moving). The compass needle symbol changes from "triangle shape" (map rotation follows phone) to a "strike-through compass needle" (?). No AA device involved at this point. This happens only with MRA, Google Maps doesn't show any problems, and another navigation app I had (but have uninstalled a few days ago), Magic Earth, didn't either show this problem. For me, it's clearly isolated with MRA, and while I may have seen an occasional map spin in earlier versions, it is now a constant problem (as soon as the device doesn't move) and, unfortunately, dramatically reduces the actual usefulness of the app for navigation. Phone is the same; the only thing that has changed is, there have been security/firmware updates by Samsung over the years.
      BMW F 450 GS: AA with Carpuride W702BS Pro (via Samsung S22 Ultra)
      VOGE DS 900 X: AA with Carpuride W702 (via Samsung S22 Ultra)
      Skoda Citigo: AA with Carpuride W903 (via Samsung S22 Ultra)
        It is also MRA related. Why?
        At least on my phones, only MRA has this problem. Maybe Here is the cause. I don't know
        But just like i wrote in other topics. There are other GPS related things which only occur in MRA and not in other navigation apps
        • Con Hennekens
          Some phone have not only GPS but also a hardware compass. These are able to "see" in which direction they are held. Phones that don't have a compass, extrapolate direction from movement. That gets very inaccurate while standing still. Then there are apps that that rely on location services only (I don't know if direction is taken from compass if available), and there are apps that have different methods of approaching hardware. It all is a little more complicated then one might think...
          • Donovan Smith
            Donovan Smith
            Donovan Smith
            same with me on i phone. not touching phone or anything. It flips and then flips back. doesn't happen every time but sometimes even when riding
            • peha
              peha
              peha
              I don't doubt that it's complicated. I also didn't mean to "blame", should it have come across like this, stating that Google Maps doesn't show this phenomenon, but rather point out that it is possible to somehow avoid this problem (i.e., there's hope). I do, however, wonder why (for my setup at least) the severity/frequency of the spinning has increased to a level where it occurs at practically every stop. 🙁 Something must have changed.
                @Con-Hennekens said in Map "spinning" when standing still:
                It is true what you say but when you have multiple navigation apps on your phone and use all of them also. And only one app have issues. Than it is pretty obvious that this app is the one which needs to fix it.
                I know it not easy to fix this. As @Corjan-Meijerink wrote. There so many different phones and not all have these issues.
                • M. Schrijver M. Schrijver
                  @M.-Schrijver When version 5.0.2 is released you may see an improvement.
                  • LE DIZES Freddy
                    I just tried version 5.02 and the problem with the map spinning while stopped is still there.
                    Happy holidays to everyone!
                    • LE DIZES Freddy LE DIZES Freddy
                      @LE-DIZES-Freddy said in Map "spinning" when standing still:
                      Are you one of the BETA testers?
                      LE DIZES Freddy 1 Reply Last reply
                        @Nick-Carthew oui
                          @LE-DIZES-Freddy is that on Android itself or in Android Auto?
                          A big part of my fix for the map spinning caused a major issue on some Android Auto devices leading to the position not updating al all 🙂
                            @Corjan-Meijerink bonsoir Cojan
                            sur Android , Crossacall Action X5 MRA 5.0.2-441
                              I won't make any further changes regarding this issue for now.
                              To resolve the true core of the issue - which I attempted - another solution needs to be designed. My fix resulted in major Android Auto issues.
                              In short: some GPS information (regarding accuracy) is missing on certain devices causing the spinning. However some Android Auto devices never report this information as the GPS is often very cheap (no offence). So I simply cannot say something like "if accuracy is missing, ignore the position update" which in reality is exactly what we'd need to do. When I tested this with simulations the spinning was indeed completely gone while when driving everything still worked as designed. But because those Android Auto devices never report certain GPS metadata, this solution cannot be used.
                              Now why do other apps possibly not show this issue? We completely rely on GPS data and their accuracy while other apps (especially native ones) might use extra device information from internal accelerometers etc.
                              Erik Plaggenborg 1 Reply Last reply
                                Erik Plaggenborg
                                Erik Plaggenborg
                                Erik Plaggenborg
                                @Corjan-Meijerink I use two android devices to navigate with MRA. One a Samsung S25+ and the other is the T865 from ThorkRacing. Both devices are only having a spinning map at a stand still, not while driving.
                                Don't know if this information is useful, i didn't read this in this topic so thought the problem was a spinning map while driving. This never happend to my devices only at a complete stand still.
                                BMW R1250 GSA Ultimate Edition
                                Garmin XT3
                                Samsung S25+
                                Enthousiast MRA/MRA Next gebruiker
                                • Erik Plaggenborg Erik Plaggenborg
                                  Erik Plaggenborg
                                  Erik Plaggenborg
                                  Erik Plaggenborg
                                  Yesterday i drove a route A2B and the only time the "spinned" was at a complete stand still. The map turnend about 180 degrees, the minute i started moving the map turned in the correct position. This kept on happening everytime i stopped for a turn or trafficlight.
                                  Garmin XT3
                                  Samsung S25+
                                    wrote on last edited by Marinus van Deudekom
                                    #57
                                    @Erik-Plaggenborg when the 441 update was rekeased I did a test with the T865X and for me the map didn’t spin at a complete stop. Are you using the T865 or like me the T865X. As fas as I know the difference those twi is the better screen and more interval memory
                                    peha 1 Reply Last reply
                                      peha
                                      peha
                                      peha
                                      The thread (at least how I meant it) is about the spinning when at a standstill; for me, there is no problem while moving. Unfortunately, the difficulties also occur on my phone (Samsung S22 Ultra) alone, without any Android Auto device involved, and they keep occurring with 5.02 as well. It happens at practically every stop, and almost every time the map then turns 180 degrees (facing the direction from where I came), causing the navigation to recalculate. Something must have changed compared to earlier versions-be it the app, the phone, or hardware conditions-because I did not have the problem this massively in the past. It drastically reduces the usefulness of the app, and it is not good news that seemingly not much can be done to solve this. 🙁 I do, however, appreciate the attempts to fix it, and I am hopeful that a new solution can be found and designed over time. I like the app a lot; it's been my everyday navigation app (and especially now, with free drive, even more so)-I believe in the team's ability to eventually find a fix for the phenomenon. 🙂🚀
                                      Con Hennekens LE DIZES Freddy 2 Replies Last reply
                                        I’ll definitely spend some more time! 🙂
                                        peha LE DIZES Freddy 2 Replies Last reply
                                        • peha
                                          peha
                                          peha
                                          #60
                                          Thank you - much appreciated!
                                          If there's a way I could help somehow - maybe with logs, or as a beta tester, if more are needed -, I'd gladly, please just let me know.
                                          • 4
                                          • 5
                                          • 6
                                          Bouke Ent
                                          Bouke Ent
                                          peha
                                          peha
                                          Bill Harrison
                                          Bill Harrison
                                          TomOnTour
                                          TomOnTour
                                          Herman Veldhuizen
                                          Herman Veldhuizen
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Albert van den Elsen
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Nick Watts
                                          Nick Watts
                                          Forest
                                          Forest
                                          Donovan Smith
                                          Donovan Smith
                                          Paul Steinberg
                                          Paul Steinberg
                                          • Vergrendel scherm zet alles op z'n kop
                                          • Upgrading from Zumo XT to XT2
                                            3.5k
                                            178
                                            Stanisław
                                            Stanisław
                                          • Route Breakdown
                                          • MRA 6.0.0 - 515 Carplay folder twice
                                          • How to delete favourites?
                                            3.2k
