Approximately how long should it take to synchronize all routes?
I'd say: here?
That's a lot of routes you have though...
@MotoCon you call that a lot
@brett-bartick I have come across this too, some days the sync can be quite rapid, the route sync counter literally flies through, other times it can be almost glacial, like 1 route sync per second
I have never worked out a reason why & just put it down the web pipes congested (servers being busy) -
It's been hours and the counter hasn't changed. Seems like a bug to me. Is there a route limit? I'm not even sure that route count is accurate. But I will say that I usually create a route-track for each route. So, I'm guessing that counts as two routes?
@Brett-Bartick Try turning your phone off completely and then try syncing again.
Didn't work. Still stuck at 2168 remaining.
Maybe this issue/bug is similar to a route search, that only goes 3 levels deep.
@Brett-Bartick, no I don't think so, I also have more levels than three. Actually I needed to do a storage deletion on the V6 beta app, and it struck me how much faster syncing works than in the (for me by now) "old" app. So improvement is on its way
Perhaps an additional switch to synchronise routes more recent than X days/months/etc. since the last edit would be a good solution. I don't think there's any reason to have very old routes on my phone. When I plan to use an old folder, I could synchronise it manually.
@Stanisław, You can still sync routes and folders manually, but I really would not recommend that. Syncing only takes some time at first try, if you have many routes. After that it just keeps everything equal blindingly fast.
Of course but when someone has 3000 router in his library, could synchronise only 250 from last year and every new created later, without waiting hours for old routes synchro.
Just an idea, not a problem for me. -
Just an idea, not a problem for me.@Stanisław, certainly not a bad idea!
Who knows, maybe it will be picked up by the team. -
Customer support was able to assist.
As of version 6 one route cannot block the entire sync. -
Yes, customer support is working on this! A fix was implemented, but the sync now gets stuck at 1083 remaining. I've uploaded new logs to customer support to further investigate.
The issue has been resolved successfully and quickly! Synchronization of all my routes (2000+) finishes without any problems.
