  4. Approximately how long should it take to synchronize all routes?
12 Posts 6 Posters 289 Views 4 Watching
  • Brett Bartick
    Brett Bartick
    Brett Bartick
    wrote last edited by
    I tried to "Sync all my routes". The process seems to be running for a few days. How can I check the progress?
      I'd say: here?
      That's a lot of routes you have though...
      Brian McG 1 Reply Last reply
        I'd say: here?
        @MotoCon you call that a lot 😂 😂 😂
        @brett-bartick I have come across this too, some days the sync can be quite rapid, the route sync counter literally flies through, other times it can be almost glacial, like 1 route sync per second
        I have never worked out a reason why & just put it down the web pipes congested (servers being busy)
        • Brett Bartick
          Brett Bartick
          Brett Bartick
          It's been hours and the counter hasn't changed. Seems like a bug to me. Is there a route limit? I'm not even sure that route count is accurate. But I will say that I usually create a route-track for each route. So, I'm guessing that counts as two routes?
          • Brett Bartick Brett Bartick
            @Brett-Bartick Try turning your phone off completely and then try syncing again.
            Brett Bartick 1 Reply Last reply
              Brett Bartick
              Brett Bartick
              Brett Bartick
              Didn't work. Still stuck at 2168 remaining.
              Maybe this issue/bug is similar to a route search, that only goes 3 levels deep. 😠
                @Brett-Bartick, no I don't think so, I also have more levels than three. Actually I needed to do a storage deletion on the V6 beta app, and it struck me how much faster syncing works than in the (for me by now) "old" app. So improvement is on its way 😉
                • StanisÅ‚aw
                  Stanisław
                  Stanisław
                  Perhaps an additional switch to synchronise routes more recent than X days/months/etc. since the last edit would be a good solution. I don't think there's any reason to have very old routes on my phone. When I plan to use an old folder, I could synchronise it manually.
                  Staszek
                  • StanisÅ‚aw StanisÅ‚aw
                    @Stanisław, You can still sync routes and folders manually, but I really would not recommend that. Syncing only takes some time at first try, if you have many routes. After that it just keeps everything equal blindingly fast.
                    • StanisÅ‚aw
                      Stanisław
                      Stanisław
                      wrote last edited by Stanisław
                      Of course but when someone has 3000 router in his library, could synchronise only 250 from last year and every new created later, without waiting hours for old routes synchro.
                      Just an idea, not a problem for me.
                      Staszek
                        @Stanisław, certainly not a bad idea! 😉 Who knows, maybe it will be picked up by the team.
                          Customer support was able to assist.
                          As of version 6 one route cannot block the entire sync.
                          Stanisław
                          Stanisław
                          Brett Bartick
                          Brett Bartick
                            107
                            843
                          • Download club route folders
                          • Live tracking problem on Android tablet
                          • Pay for beta?
                            Arjan de Vries
                            Arjan de Vries
                            938
