  4. Approximately how long should it take to synchronize all routes?
8 Posts 5 Posters 221 Views 3 Watching
  • Brett Bartick
    Brett Bartick
    Brett Bartick
    wrote last edited by
    I tried to "Sync all my routes". The process seems to be running for a few days. How can I check the progress?
      I'd say: here?
      That's a lot of routes you have though...
      Brian McG 1 Reply Last reply
        I'd say: here?
        @MotoCon you call that a lot 😂 😂 😂
        @brett-bartick I have come across this too, some days the sync can be quite rapid, the route sync counter literally flies through, other times it can be almost glacial, like 1 route sync per second
        I have never worked out a reason why & just put it down the web pipes congested (servers being busy)
        • Brett Bartick
          Brett Bartick
          Brett Bartick
          It's been hours and the counter hasn't changed. Seems like a bug to me. Is there a route limit? I'm not even sure that route count is accurate. But I will say that I usually create a route-track for each route. So, I'm guessing that counts as two routes?
          • Brett Bartick Brett Bartick
            @Brett-Bartick Try turning your phone off completely and then try syncing again.
            Brett Bartick 1 Reply Last reply
              Brett Bartick
              Brett Bartick
              Brett Bartick
              Didn't work. Still stuck at 2168 remaining.
              Maybe this issue/bug is similar to a route search, that only goes 3 levels deep. 😠
                @Brett-Bartick, no I don't think so, I also have more levels than three. Actually I needed to do a storage deletion on the V6 beta app, and it struck me how much faster syncing works than in the (for me by now) "old" app. So improvement is on its way 😉
                • StanisÅ‚aw
                  Stanisław
                  Stanisław
                  Perhaps an additional switch to synchronise routes more recent than X days/months/etc. since the last edit would be a good solution. I don't think there's any reason to have very old routes on my phone. When I plan to use an old folder, I could synchronise it manually.
                  Staszek
                  Stanisław
                  Stanisław
                  Brett Bartick
                  Brett Bartick
                  • Pay for beta?
                    800
                    Stanisław
                    Stanisław
                  • Live payments enabled
                    222
                  • Suggestion -> Statistics
