Max distance for scenic route generator in the Nav App
What is the maximum distance the scenic route generator in the Nav App can handle?
Thx! -
Nick Carthew moved this topic from [App] Problems, Bugs and other Issues on
Thx!@LennyO It’s not a specific distance but the distance is related to the amount of nodes. Nodes are coordinates used to draw the route. If I was to put a distance I would say approximately 600 miles. Standard (fastest) A - B routes are not affected by this.
And currently the time calculated for scenic has a known issue that will be addressed.
@Nick-Carthew HI, Nick!
On the App I selected Destination, created A to B From Jacksonville, FL to Helen, Ga.
It created a route, but when I chose the next curviness level, it came back with the message that states: "Scenic routes can only be created when you have an Internet connection".
Well, I do have Internet connection (everything else works fine), I did not select Off-line Navigation.
The route it created was 450 miles.
Is that too much for the generator to handle?
Also, the message is very ambiguous.
Thank you! -
Thank you!@LennyO Issues with scenic routing will be addressed.
@Nick-Carthew Thanks Nick!
