  4. The compas direction on the elevation circle is wrong
63 Posts 19 Posters 10.8k Views 9 Watching
  • LennyO LennyO
    @Con-Hennekens said:
    @LennyO, Remember that "North UP" does not show where North is whatsoever. It just indicates you are not holding the map upside down... 😉
    What about #2 in this descripption:
    @LennyO I think it should say: “In this camera mode, the map does not rotate with your direction of travel but always remains oriented toward the top of the map.”
    LennyO 2 Replies Last reply
      @Rob-Verhoeff Bravo! That would stop the confusion for everyone! And this change should be announced to all, as I suspect many people are confused to the point of being frustrated.... me included.
        @nick-carthew Hi, Nick! Would you please assist in correcting the Manual. Thx!
        • LennyO LennyO
          @LennyO I’m not responsible for the manual and personally I think the wording is perfectly clear. The view is called ‘North up’ and the definition in the manual says
          ‘North will always be up’ I’m unsure what part is unclear!
          LennyO 1 Reply Last reply
            @Nick-Carthew Hi, Nick!
            Sorry... i thought you are a part of the crew.
            The issue is the fact that North will not always be up. I wish it was.
            if you put the map in this orientation, you often see that the Red segment on the elevation circle is NOT pointing up, thus contradicting the manual.
            Thank you!
            • LennyO LennyO
              Thank you!
              Thank you!
              @nick-carthew Nick, to clarify my previous post I should add - when you are in fact heading North on the map in North up orientation, the Red segment may be pointing somewhere else, but be at the 12 o'clock. And since the Red segment always shows where the North is there is a conflict in the definition in the manual.
              • LennyO LennyO
                Thank you!
                @LennyO
                Corjan is aware of the situation and although he doesn’t reply to many forum posts he does read them.
                  @LennyO
                  I don’t? 😮
                    I don’t? 😮
                    @Corjan-Meijerink A direct contradiction 😉
                    • LennyO LennyO
                      @LennyO, "North will always be up" in this context refers to the north of the map, not to the north pole 😉
                        I know the North Pole and North on the map are not exact the same. But considering the few segments of the compass, should then the north pole and north on the map be same?
                          @M.-Schrijver, I don't think that makes it easier for most 😉
                          BertM 1 Reply Last reply
                            then this post goes from 50 to 500 😉
                              #52
                              @Con-Hennekens Ok, Con! I get it! Not the most intuitive implementation, but it is what it is....
                              Having said that, I strongly feel that the manual needs to be updated to state what you and @rob-verhoeff are saying.
                              Every GPS unit is actually North up if you select such an orientation.
                              Who would ever deduce, reading the manual, that North does not really mean North when it clearly strates that " in the North Up camera vew ( map orientation ) North will always be up".
                              When people read "North" they can not imagine that it means "North of the map"....
                              And that includes myself, which caused a major confusion in my head.
                              What's going on???? I see a discrepancy between what I thought was North and the Red segment! Re-check the manual. The manual says so, then the Red segment must be wrong, correct?
                              This whoole thing could be easily resolved in two simple steps:
                              1. Update the manual
                              2. Put the N,E,S,W cardinal markings on the segmented circle.
                                DONE!
                                I am sure you would agree with that 😕
                              Many people are having issues with this thing, so something needs to be done and hopefully soon.
                              Thank you!
                                @lennyo, In "North Up" North does not mean top, UP means top (of your phone, or paper map, or whatever). Projection of a map has really nothing to do with where North is. North Up is only about how you hold the map. I agree that adding E,S and W would help for some in that it obviously does not indicate your heading, but then again North will still not always point to the top of your phone 😉
                                  @Con-Hennekens Con, there is an ambiguity and it's never good. Right?
                                    As always, there are some in favour and some against. And that will always be the case. A decision has been made and implemented. Some have already got used to it, whilst others may still need to get used to it. For those who navigate using the ‘North Up’ map, just ignore the red square and pretend you don’t see it. For them, north is always visible on the map. But for those who use the map in the direction of travel, it’s a welcome addition.
                                    And since the compass directions never change, it’s simply a matter of getting used to the order: N-E-S-W. Is that difficult? Not for us older folk, anyway.
                                    And let’s not make a fuss about adding all the directions, because the screen is already so crowded!
                                    So . . .
                                    Just see it as a compass rose and remember that the red segment is pointing to the North
                                      So . . .
                                      #56
                                      @white.mouse This is your opinion and I respect it. Mine is different, so respect that too.
                                      But that is only half of the problem...
                                      The phraseology in the manual regarding the "North up" map orientation is misleading.
                                      And no matter how many people think that it's ok (for whatever reason...), the fact remains -
                                      the current description in the manual is not clear and does not depict the current state if events.
                                      I do not see how that could be argued or defended or ignored.
                                      This Forum is a shakeout platform that helps developers make the product better and people discover things here and there, that Corjan and the crew may not have seen or did not get to, etc,...
                                      I was an IT developer on Wall street for 40 years and know how that works first hand.
                                      But to say that it's fine or turn it off or look the other way goes against my grain.
                                      I want this product to be the best, that's why I even bother to bring it up.
                                      Not to cause an argument or a confrontation.
                                      The issue has to be acknowledged and then put in the queue for a fix based on the priorities.
                                      That is the professional approach.
                                      So, that's it. I am done. This issue is brought to light and it's not up to me how it will be resolved.
                                      All I know is that new users will be confused and frustrated if it's left like it is now.
                                      It is not my Product, not my business and not my decision.
                                      And all I am suggesting really is to change one... ONE sentence in the manual to create proper expectations.
                                      Thank you all for your thoughts!
                                      Stevedo 6 0 1 Reply Last reply
                                      • LennyO LennyO
                                        Stevedo 6 0
                                        Stevedo 6 0
                                        Stevedo 6 0
                                        Well said. There are a small number of, I call them MRA jihadists, on here whose approach seems to be not to accept anything that they consider to be negative feedback against MRA. I'm relatively new around here and to MRA but in my short time here I'm not the first one to have noticed this and called it out. You gave perfectly sound and reasoned feedback. The response was to keep arguing until you eventually gave up. Maybe that's the strategy? IMHO, there is far too much of people putting their fingers in their ears and saying la la la la I can't hear you. I retired from the corporate world at the age of fifty in 2013. Over time, the culture had changed to one where negative feedback, no matter how constructive, was viewed negatively and only positive feedback would be accepted. These forums often remind me of that time.
                                        I fully appreciate the things that I've learnt from these forums and their contributors. My fear is, as you put it, unless issues are acknowledged and then put in a queue for a fix, MRA will never become the best. Right now I do not recommend MRA Next to anyone, there are too many issues. MRA planner on the other hand, at the moment, is great and I have used it extensively. I will use it to plan routes for an upcoming motorcycle trip to Australia but will continue to use those routes and tracks in my Garmin. My fear here is that MRA Planner is currently being re-written and may turn out to be not so great as a result.
                                          I respect everyone’s opinion, that why I started with "As always, there are some in favour and some against. And that will always be the case."
                                          • 4
                                          Stevedo 6 0
                                          Stevedo 6 0
                                          Stanisław
                                          Stanisław
                                          Ioan Dragulescu
                                          Ioan Dragulescu
                                          Jim Allen
                                          Jim Allen
                                            TomOnTour
                                            TomOnTour
                                          • Pay for beta?
                                            764
                                            Thomas Neumeyer
                                            Thomas Neumeyer
                                            1.2k
                                          • Live payments enabled
                                            211
                                            Brett Bartick
                                            Brett Bartick
                                          • import in beta-mra failed
