  4. Audio cuttet via Bluetooth
67 Posts 14 Posters 34.4k Views 7 Watching
  • Haug
    Haug
    Haug
    Hallo everybody,
    since the last update to version 5.2 I have the same problem with the delay at Bluetooth devices. It does not matter, in which position the slider is.
    Did you change anything? Can you check please?
    Thanks
    Günter
    • Haug
      Haug
      Haug
      @corjan-meijerink: hi corjan, did you change the fix back? Have again the problem with 5.2.
        The same issue with current final and previous final release. The slider doesn't work as it should.
        When you adjust the slider the whole direction chain will be delayed incl. the command to open the audio channel.
        • Haug
          Haug
          Haug
          For me Version 5.0.4 was working, when Corjan wrote, that he changed something. But now it seems, the fix has gone.
          • Haug
            Haug
            Haug
            @corjan-meijerink : any News about this Problem?
            • Haug
              Haug
              Haug
              @corjan-meijerink Hello Corjan, is the delay Problem solved with the latest update?
              • Haug
                Haug
                Haug
                Fya: I did a Test Today. The Delay is still there and so the App is not useable for me.
                Also no response from you @corjan-meijerink
                This is not very friendly!
                  I did my first ride of the year today and used verion 5.0.4 (451). Till the lunch the audio seems fine, but i'm not sure. I did not pay much attention to it. After the lunch i noticed a missing part at the beginning of the instructions.
                  My audio delay was already set to 1 sec. Therefore i started playing with the delay and hoped to hear some difference.
                  I did hear differences but not what i expected.
                  I did not matter if I set the delay to 0 or 2 seconds. The first small part of the directions was always missing.
                  The only thing what happens was the delay when the instructions were spoken. With the of 2 sec delay, the instructions came 2 seconds later.
                  B.t.w I have a Sena SRL 3 headset.
                  Haug
                  Haug
                  Haug
                  @M.-Schrijver
                  Hello M.
                  have you still the Audio Problem like me?
                  First second of the Audio command is missing.
                  Thanks and regards
                  Günter
                    With the last version I don't know. I did one ride with the lastest was focused on the separation of audio channels in Android Auto. That works fine.
                    during this test i had media playing and MRA did it's thing. All was clear and complete. In previous versions in this setting. MRA was a bit low on volume but everything was there (both on the same audio channel). When only MRA was active, i heard only partially directions. The audio delay function doesn't help in this case (anymore). It simple shifts the whole sequence (open the channel, give directions and closing the channel) according the set delay.
                    • Haug
                      Haug
                      Haug
                      If you have a Media playing during Navigation with MRA, the Audio commands work without any Problem. This is due to an open bluetooth Connection with music. But I have normally during motorcycle ride no music playing.
                      • Haug Haug
                        It's still a public forum and this is not a support ticket 🙂
                        Pushing me definitely won't help me finding motivation for looking into an issue one users reports.
                        From my point of view: the issue was fixed (and confirmed fixed). We haven't touched it since. Only updated another independent Android Auto audio channel issue with luckily is now also solved.
                        • Haug
                          Haug
                          Haug
                          Ok clear, but it seems, I am not the only one with this problem.
                          For me it means, that the MRA is not useable anymore.
                            To be fair, I don't really see many complaints about this.
                            The biggest issue with the Android Auto audio channels has been solved.
                            • Haug
                              Haug
                              Haug
                              wrote on last edited by Haug
                              #66
                              Strange, that it was working with 5.0.4. But if it’s not an issue for you, I will leave MRA.
                                We take all feedback serious but please, create a support ticket.
                                Then we have an official way to communicate.
                                Obviously audio is critical.
                                • 4
                                Jan Weerheim
                                Jan Weerheim
                                Haug
                                Haug
                                richard 3v
                                richard 3v
                                Marco Strani
                                Marco Strani
                                Robert Laudensack
                                Robert Laudensack
                                • MRA Studio export speed
                                • Hiya from UK
                                  Russ Nattrass 1
                                  Russ Nattrass 1
                                • geeft routepunt niet weer
