  4. Move blocks of routepoints
17 Posts 7 Posters 475 Views 3 Watching
    wrote last edited by
    Yes, that last suggestion does seem like a good option to me. Selecting multiple points to delete them all at once. At the moment, if I want to change part of the route, I have to delete each point in that section individually. It would be easier if I could delete those route points all at once. And it would be even better if you could then see the selected section with the route points on the map as well!
    • David Joblingundefined Offline
      David Jobling
      I'd like to see a way to work on a group of waypoints too. Some of my routes are figure 8 or cloverleaf and I like to reverse (or remove) sections of the route to keep it interesting. If we could select a group of waypoints in the list, then delete / reverse / move them, I'd be very happy 🙂
      Yannick_van_Vugtundefined 1 Reply Last reply
      • David Joblingundefined David Jobling
        Yannick_van_Vugtundefined Offline
        Yannick_van_Vugt
        You get my exact idea. 😌👌🏻
        Feels like a basic feature that should’ve always been there.
        📷: YannickvanVugt | 🏍️: DutchTransalp
        • Jörgenundefined Offline
          Hi,
          I don't quite understand the point of moving multiple waypoints. That would cause all the geographic coordinates to shift at the same time, which would result in an uncontrolled track.
          Just a copy/paste sample
          Copying multiple waypoints to use them in a new route makes more sense.
            I think group delete will be fine.
            Moving will indeed be not possible.
              I agree, copy and delete.
              • Jörgenundefined Jörgen
                Hi,
                Yannick_van_Vugt
                @Jörgen said:
                Hi,
                It’s not about moving them physically, it’s about moving them in order in the list of routepoints. Have you guys even read the thread properly? Change them from 59-84 to let’s say 20-45 in a single go.
                • Yannick_van_Vugtundefined Yannick_van_Vugt
                  @Jörgen said:
                  Hi,
                  @Yannick_van_Vugt Yes I have but want you want is not possible at all
                    David Jobling
                    #14
                    It shouldn't be too difficult? We can do it now, one-by-one (but it is slow and can be confusing, and MRA recalculates for each waypoint), I'd just like to work on several adjacent points at the same time.
                      When creating a route that stays in a singular area, or creating off-road tracks, and you want to re-arrange things, it can get pretty messy pretty quickly when you need to move each point at a time. It would be awesome if you could re-arrange a complete block of multiple points in a single go.
                      Either via a multi-select and drag or a little like how the split function works, select start and end-point and select where you want to push the selected block to.
                      For example, this block are basically all 'skipped' points, this works to create a track on unpaved roads that are ignored by the algorithms, but now I want those 24 points in another 'section' of my complete track/route.
                      Brian McGundefined Offline
                      wrote last edited by Brian McG
                      This post is deleted!
                        Yannick_van_Vugt
                        @Marinus-van-Deudekom Currently it isn't, that's why I brought it on as a suggestion. Right?
                        Other see the value of my request, I understand you don't, but if it ain't valuable to you, or you don't use the tool in a certain way, doesn't mean it's not for someone else.
                        @Brian-McG Yes, possible, but that shouldn't be needed and is devious work. It also floods the database and back-end with splits and merges, that will later be deleted. This feature is will prevent that as well.
                          #17
                          Yannick_van_Vugt
                          David Jobling
                          Leike Lodiersundefined
                            Mzokkundefined
                            3.0k
                            LennyOundefined
                          • Move blocks of routepoints
                            Yannick_van_Vugt
                            475
                            Peter Zehentreiterundefined
                            LennyOundefined
                          • v5.2 (473) Feedback
                            C.A. Kielenundefined
                            C.A. Kielen
                            730
                          • MRA V5.2.1 (486) Photo in the track recording is rotated; photo orientation is ambiguous.
