  4. Move blocks of routepoints
21 Posts 7 Posters 2.7k Views 2 Watching
  • Leike Lodiers Leike Lodiers
    @Yannick_van_Vugt that's true.😁 😁 But it creates a problem when you want to replace you're route to a other road. I think to help you're self, don't place to many way point to follow the offroad way. Choose the most critical point on the way so when you see a crossing or split of the way place one there . You don't need to follow the whole way with waypoint.
    Yannick_van_Vugt
    Yannick_van_Vugt
    Yannick_van_Vugt
    wrote on last edited by Yannick_van_Vugt
    @Leike-Lodiers It is nice to have and there is no reason not to. Except for the fact that if you want to move a whole block of routepoints.
    Same could be said if you have a lot of little towns and you want to change that order by a block of points. It is not really an unnecessary feature, I called it "move" in my primary post, but it would also be great if a multi-select could be done to delete a big part of the route.
    📷: YannickvanVugt | 🏍️: DutchTransalp
      Yes, that last suggestion does seem like a good option to me. Selecting multiple points to delete them all at once. At the moment, if I want to change part of the route, I have to delete each point in that section individually. It would be easier if I could delete those route points all at once. And it would be even better if you could then see the selected section with the route points on the map as well!
      • David Jobling
        David Jobling
        David Jobling
        I'd like to see a way to work on a group of waypoints too. Some of my routes are figure 8 or cloverleaf and I like to reverse (or remove) sections of the route to keep it interesting. If we could select a group of waypoints in the list, then delete / reverse / move them, I'd be very happy 🙂
        Yannick_van_Vugt 1 Reply Last reply
        • David Jobling David Jobling
          Yannick_van_Vugt
          Yannick_van_Vugt
          Yannick_van_Vugt
          You get my exact idea. 😌👌🏻
          Feels like a basic feature that should’ve always been there.
          • Jörgen
            Hi,
            I don't quite understand the point of moving multiple waypoints. That would cause all the geographic coordinates to shift at the same time, which would result in an uncontrolled track.
            Just a copy/paste sample
            Copying multiple waypoints to use them in a new route makes more sense.
              I think group delete will be fine.
              Moving will indeed be not possible.
              • Jörgen
                I agree, copy and delete.
                • Jörgen Jörgen
                  Hi,
                  Yannick_van_Vugt
                  Yannick_van_Vugt
                  Yannick_van_Vugt
                  @Jörgen said:
                  Hi,
                  It’s not about moving them physically, it’s about moving them in order in the list of routepoints. Have you guys even read the thread properly? Change them from 59-84 to let’s say 20-45 in a single go.
                  • Yannick_van_Vugt Yannick_van_Vugt
                    @Jörgen said:
                    Hi,
                    @Yannick_van_Vugt Yes I have but want you want is not possible at all
                    • David Jobling
                      David Jobling
                      David Jobling
                      It shouldn't be too difficult? We can do it now, one-by-one (but it is slow and can be confusing, and MRA recalculates for each waypoint), I'd just like to work on several adjacent points at the same time.
                      • David Jobling
                        David Jobling
                        David Jobling
                        Simple example of the request (hoping the image uploads OK): I want to do waypoints 6-7-8-9 before 2-3-4-5. Secondly, I'd like to reverse 6-7-8-9 (only) without changing the rest of the route.
                        Reason: I do some routes twice a year, wonderful roads, I like to vary the sequence / direction to keep it interesting 🙂
                          When creating a route that stays in a singular area, or creating off-road tracks, and you want to re-arrange things, it can get pretty messy pretty quickly when you need to move each point at a time. It would be awesome if you could re-arrange a complete block of multiple points in a single go.
                          Either via a multi-select and drag or a little like how the split function works, select start and end-point and select where you want to push the selected block to.
                          For example, this block are basically all 'skipped' points, this works to create a track on unpaved roads that are ignored by the algorithms, but now I want those 24 points in another 'section' of my complete track/route.
                          BMcG
                          BMcG
                          BMcG
                          wrote on last edited by BMcG
                          This post is deleted!
                            Yannick_van_Vugt
                            Yannick_van_Vugt
                            Yannick_van_Vugt
                            @Marinus-van-Deudekom Currently it isn't, that's why I brought it on as a suggestion. Right?
                            Other see the value of my request, I understand you don't, but if it ain't valuable to you, or you don't use the tool in a certain way, doesn't mean it's not for someone else.
                            @Brian-McG Yes, possible, but that shouldn't be needed and is devious work. It also floods the database and back-end with splits and merges, that will later be deleted. This feature is will prevent that as well.
                            BMcG Marinus van Deudekom 2 Replies Last reply
                              BMcG
                              BMcG
                              BMcG
                                Its not that I dont want to use such a tool. I just think that its just impossible
                                • Jörgen
                                  @yannick_van_vugt , even in the translation, your suggestion isn't 100% clear; it's only after David's explanation that things become clear. (lost in translation) 😉
                                  Now I understand the suggestion. You kept talking about moving multiple waypoints. I always thought you were referring to the map.
                                  Saying “moving within the ‘Waypoint List’” would have helped me understand it right away.
                                  If, perhaps, there’s a feature in the future to delete or copy multiple waypoints, it should also be possible to move multiple waypoints (within the waypoint list). I vote for this.
                                  • Jörgen Jörgen
                                    Yannick_van_Vugt
                                    Yannick_van_Vugt
                                    Yannick_van_Vugt
                                    @Jörgen After reading my post again, I get what you mean. I mention re-arrange and 'section' of route, for me that felt clear when I wrote it. It was never about changing their physical location on the map, of course, when there is no street or path, it would be useless to place a marker there.
                                    BMcG
                                    BMcG
                                    Yannick_van_Vugt
                                    Yannick_van_Vugt
                                    David Jobling
                                    David Jobling
                                      Will Brooks
                                      Will Brooks
                                      3.0k
                                      1.0k
                                      Will Brooks
                                      Will Brooks
                                    • The ‘Start route here’ option doesn’t seem to be working properly.
                                      Parantapa
                                      Parantapa
                                      Marcel Versluis
                                      Marcel Versluis
                                    • Trips in Commercial Clubs?
                                      Mike West
                                      Mike West
