  4. Starting navigation in the middle o the programmed Route.
10 Posts 5 Posters 1.1k Views 3 Watching
  • Montorsi Paolo 0
    Montorsi Paolo 0
    Montorsi Paolo 0
    Just returned from a 5 days trip using only MRA Navigation app. And I am already a fan.
    One question: is it already possibile to start navigating in the middle of the route instead from the beginning?
    I haven't found the way.
    I had two real problem to solve:
    1. I accidentally interrupted the navigation in the middle of the route. So when I started the navigation again I did not find the way to skip the waypoints already visited .
    2. Due to the closure of a street I had to skip several waypoint in the middle of the running navigation.
    So, in the both of the cases, i had to park the motorbike, enter in the edit mode and modify the route.
    There is a diffent and quicker way to do that?
    Thanks
    Paolo
    • Montorsi Paolo 0 Montorsi Paolo 0
      Thanks
      Paolo
      @Montorsi-Paolo-0 Great to read that you are a fan. If you long press on any waypoint, all previous waypoints will be skipped so that navigation continues from the chosen waypoint. You can also use this method if you accidentally skip too many. Example, if you long pressed waypoint 7 but you are at waypoint 5, long press waypoint 5 to restore to your chosen waypoint.
      Montorsi Paolo 0 1 Reply Last reply
      • Hubert Thoring
        @montorsi-paolo-0 You also have the option to configure the navigation app so that, after a pause, it starts at the nearest waypoint relative to your starting point.
        Select the route and tap "Navigate," then choose "Routing Settings" from the menu and enable the "Start at nearest waypoint" option.
        Good luck with that!
        What Nick wrote works too, of course—and it’s always visible on the map display at any time. ...
        richard 3v Montorsi Paolo 0 2 Replies Last reply
          richard 3v
          richard 3v
          richard 3v
          wrote on last edited by richard 3v
          So what happens if the nearest waypoint is already behind you ??
          • Herman Veldhuizen
            you are probably navigating the route as track. the current behaviour in that scenario is indeed such that the navigation always starts at the first point.
            but you can click on a waypoint on the map or in the waypoint list and make that point the first target.
            if you navigate a route as route you can select the target waypoint before you start. by default the nearest is selected.
            • richard 3v
              richard 3v
              richard 3v
              Personally I never navigate a route as a track, always a route as a route.
              So in my case will the app try sending me back to where I've already been??
              • richard 3v richard 3v
                @richard-3v yes that can happen
                • richard 3v
                  richard 3v
                  richard 3v
                  @herman-veldhuizen
                  OK, thanks for the reply
                    Montorsi Paolo 0
                    Montorsi Paolo 0
                    Montorsi Paolo 0
                    @Nick-Carthew
                    Thanks
                    Work for me.
                      Montorsi Paolo 0
                      Montorsi Paolo 0
                      Montorsi Paolo 0
                      @Hubert-Thoring
                      The "Start at nearest waypoint" was already selected but the option "Use the actual position" it wasn't. Maybe this was the problem.
                      By the way, following your advice, I found also that is possible select the starting point by choosing a waypoint. My bad.
                      Thanks
                      Montorsi Paolo 0
                      Montorsi Paolo 0
                      richard 3v
                      richard 3v
                      • Audio cuttet via Bluetooth
                        Haug
                        Haug
                        35.5k
                      • One crash today
                      • Download club route folders
                        135
                        peha
                        peha
                        Mosimann
                        Mosimann
                      • Elektrisch rijden
                        John mq
                        John mq
