  4. V5.1.0 - 462 New altitude/heading shows incorrect Data
24 Posts 9 Posters 4.0k Views 9 Watching
  • Reinhard Punz
    Reinhard Punz
    Reinhard Punz
    Note: The displayed altitude is approximately 50 meters too high. Sometimes only 45 meters.
    • Mzokk
      Standard GPS satellites don’t track your height from the actual ground (valleys, mountains). They measure your distance from a theoretical, mathematical model of the Earth called an ellipsoid. Your phone then has to translate that to "Mean Sea Level" using a gravity model, which can easily throw off calculations by hundreds of feet. In short your phone is not that accurate on the vertical plane. Even specific GPS devices such as Garmin are only accurate to +/- 30m unless they also take data from a topographic database which triangulates horizontal position with a topographical datum. My phone is a 60m out using MRA or OSMand (reading high) and my Zumo XT usually under or over reads by 20-30m
      • Mzokk
        Oh and strangely it can be accurate at higher elevations. I was using MRA on a trip on Saturday crossing a pass at 448m and it was reading 447M passing the datum point??
        • Mzokk
          wrote on last edited by Mzokk
          I did a little experiment with this. My house is just below a 50m contour line. My phone using MRA gives 341ft or 104M.
          Same with OSMand.
          In OSMand you can download a correction file "World Altitude Correction"
          This puts me at 157ft or 48M which would be within + or - 3m of my actual elevation.
          Might be worth building in the correction file somewhere?
          • Jörgen
            I noticed also that a correction of about -50 m is necessary.
            • Jörgen
              Regarding the Noth segment display, I believe it was always correct.
              • Guzzist
                I compared several apps and GPX Tools. Only OsmAnd Shows the correct value (at my home base in southern part of Germany.
                • Rob Verhoeff
                  It’s just a nice extra feature! It’s not like your life depends on the altitude display shown by the navigation system. I see it as a fun gimmick. Whether I’m driving at sea level or at 1500 meters in mountainous terrain, it’s simply fun to see — nothing more. And I believe that’s exactly how this functionality was intended: nothing more and nothing less. Apparently, some phones handle it better than others.
                  Guzzist Mzokk MotoCon 3 Replies Last reply
                    @Rob-Verhoeff I totally agree with you Rob. It was just this discussion, which let me check just at home, because I know the hight there 😊
                      @Rob-Verhoeff Agree also. Just a fun thing. Elevation isn't even critical when hill walking. I'm more of a map and old Silva compass person for that activity. I have started to use OSMand a bit whilst walking.......its a slippery slope (sorry couldn't resist) 😊
                      • Bouke Ent
                        In The Netherlands our level is based on NAP. GPS level is based on a globel level. for yhe netherlands it is arround a 40 meter differance then our NAP.
                        • Reinhard Punz
                          Reinhard Punz
                          Reinhard Punz
                          I also see the altitude information as a nice addition, but my main concern is the incorrect direction. It seems the direction is reversed, and west/east are swapped. North/south is displayed correctly on my Android devices.
                          • Reinhard Punz Reinhard Punz
                            @Reinhard-Punz You mean the red stripe in the compass? It always pointed to the north as far as I can see.
                            Reinhard Punz 1 Reply Last reply
                              @Rob-Verhoeff, That is of course true, but does not reason away why other apps show it right 😉 If correction is possible, I am all for it.
                                Reinhard Punz
                                Reinhard Punz
                                Reinhard Punz
                                @Rob-Verhoeff Yes, exactly. The screenshot shows that I'm facing southwest, but the compass is pointing southeast. I'm at an altitude of approximately 331 meters.Screenshot_20260526_133821.jpg
                                  @Reinhard-Punz, I don't think the direction you are facing is relevant. It's the direction you are moving to that is. It looks like you are stationary. Then it will not work.
                                    Reinhard Punz
                                    Reinhard Punz
                                    Reinhard Punz
                                    @Con-Hennekens It's true that in this example I was on foot (so very slowly). But I observed the same thing yesterday during a long car ride.
                                    • Stanisław
                                      Stanisław
                                      Stanisław
                                      I think the red bar is showing North and all is correct, am I wrong?
                                      Staszek
                                        @stanisław You could be right but is not more logical the top is always North and the red part the direction of riding?
                                        • Stanisław
                                          Stanisław
                                          Stanisław
                                          I'm not trying to judge. I'm just taking what the app gives me, Corjan usually knows better 😉
                                          Staszek
                                          Stanisław
                                          Stanisław
                                          Reinhard Punz
                                          Reinhard Punz
                                            Tegel Werner
                                            Tegel Werner
                                          • Béta to no-béta
                                          • Way points and shaping points unable to create route
                                            Parantapa
                                            Parantapa
                                            John Matthews 0
                                            John Matthews 0
