  4. Using Folders
Using Folders
8 Posts 4 Posters 721 Views 2 Watching
  • Keith Hofgartnerundefined Offline
    Keith Hofgartner
    How do you save a new route into an existing folder.
    Is it possible to move a saved route to a folder?
    • supergundefined Offline
      You can select one and more routes and then on the bottom of your screen you can select move.
      Keith Hofgartnerundefined 1 Reply Last reply
      • Jörgenundefined Online
        MRA works like a database; you do not save anything. As soon as you open a new route, space for any changes is reserved for it. If you move a waypoint, it is already changed in the data. It's important to know, if you want to change something or want to try something, make a copy first and then edit the copy.
        • supergundefined superg
          Keith Hofgartner
          wrote on last edited by Keith Hofgartner
          @superg thanks… is this using an android device as I can’t seem to ‘select’ multiple files. Once I click on it, it opens the route.
            You need to select in front of the file.
              It is a bit hidden.
              • Keith Hofgartnerundefined Keith Hofgartner
                Nick Carthewundefined Offline
                @Keith-Hofgartner You need to be in the website to move routes to folders. From your Android phone, tap Route lab which is a portal to the website. Moving routes into folders is not possible from the Routes and Tracklogs section of the app.
                  Keith Hofgartner
                  Thanks..
                  supergundefined
                  Keith Hofgartner
                    291
                  • New update 5.2.1
                    Hub 1undefined
                    Hub 1
                    RetiredWingManundefined
                  • Nieuwe functie: OSM-zoekcategorieën per voertuigtype [5.2.1-486]
                    PeterKerkhofundefined
                    PeterKerkhof
                  • Route spoor gpx
                    Steve Jarrellundefined
                    Steve Jarrell
                    5.4k
                  • how can I make Next speak the waypoints and notes to me?
                  • Breadcrumbs always ON option
