<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using Folders]]></title><description><![CDATA[<p dir="auto">How do you save a new route into an existing folder.</p>
<p dir="auto">Is it possible to move a saved route to a folder?</p>
]]></description><link>https://forum.myrouteapp.com/topic/10869/using-folders</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 23:33:07 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/10869.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 May 2026 21:17:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using Folders on Thu, 07 May 2026 22:05:35 GMT]]></title><description><![CDATA[<p dir="auto">MRA works like a database; you do not save anything. As soon as you open a new route, space for any changes is reserved for it. If you move a waypoint, it is already changed in the data. It's important to know, if you want to change something or want to try something, make a copy first and then edit the copy.</p>
]]></description><link>https://forum.myrouteapp.com/post/77127</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/77127</guid><dc:creator><![CDATA[Jörgen]]></dc:creator><pubDate>Thu, 07 May 2026 22:05:35 GMT</pubDate></item><item><title><![CDATA[Reply to Using Folders on Thu, 07 May 2026 21:40:52 GMT]]></title><description><![CDATA[<p dir="auto">You can select one and more routes and then on the bottom of your screen you can select move.</p>
]]></description><link>https://forum.myrouteapp.com/post/77126</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/77126</guid><dc:creator><![CDATA[superg]]></dc:creator><pubDate>Thu, 07 May 2026 21:40:52 GMT</pubDate></item></channel></rss>
