  4. Shaping points and Via points
34 Posts 11 Posters 9.6k Views 4 Watching
    @Herman-Veldhuizen, by no means I meant to imply you being a complainer, hence the addition of the word "constructive!" as in "opbouwende kritiek" in Dutch. I think your way of usage is interesting for sure but probably not practised a lot, not by the target audience anyway. It could be a future expansion perhaps, but in that case indeed probably as an extra licence (more as a logistics solution). I don't think however that is something MRA is willing to spent time on at the moment. For sure not until the new web planner is live and bug free.
    @Martin-Wilcke said in Shaping points and Via points:
    When navigating "Routes as tracks", all waypoints (SPs and VIAs) should be skipped automatically, as this is how track navigation works.
    That is a bit strange, since the one-and-only function of a VIA point is that it cannot be skipped automatically 😉 . How track navigation works is without any route points at all.
    @Con-Hennekens In this topic (https://forum.myrouteapp.com/topic/9552/waypoint-skipping.-mra-vs-beeline) I made a test route in both MRA and Beeline. Both have bikers as their target audience. The behaviour of the apps are however very different when it comes to skipping points. I dont think that Beelines behaviour is odd.
    • Bouke Ent
      #21
      i also looked at beeline. beeline is better is follow the plan you made. MRA is better to plan. MRA Next has many good point but also to many functions and some main function like how to deal with track and gpx file or skipping shaping point or follow the route when back on the route you planned are in my opinion not perfect. I hope in planning of future development.
        MartinW
        MartinW
        MartinW
        #22
        @Con-Hennekens said in Shaping points and Via points:
        Hence, my suggestion for a change.
        When navigating a track, there are two common concepts to lead you back in case of a deviation:
        • to the point where you left the track
        • to the most logical point in the forward direction
        There might be additional "points" (waypoints, POIs, whatever) along the track; however, they are informational only (may be announced) and do not influence the navigation.
        This concept is becoming increasingly popular, and it would be a good idea to implement it in MRA as well.
        BertM 1 Reply Last reply
        • MartinW MartinW
          This seems like an interesting point to me:
          When following a track, you follow a line.
          How does the program know what the next point is, i.e., the direction you want to go?
          I believe a program can only calculate the nearest point, and unfortunately, that can also be in the wrong direction.
          MartinW 1 Reply Last reply
          • BertM BertM
            MartinW
            MartinW
            MartinW
            @BertM said in Shaping points and Via points:
            Trackpoints <trkpt> do have a specific order, and therefore a track <trk> has a direction. "Forward direction" means "Track forward direction".
            • MartinW MartinW
              But you are not ON the track... your outside the track.
              Lets assume you left the track on point 3, and now you near point 6, how does the app knows your best point to enter is 7 instead of 6?
              • BertM BertM
                MartinW
                MartinW
                MartinW
                @BertM
                From what I've experienced, the route back to the track is calculated as if you were planning a route—and in fact, some programs do exactly this: the track remains unchanged, and an additional route is generated.
                Of course, I don't know the exact program logic, but I imagine it works like this:
                • First, various entry points are determined (i.e., points where a routable path intersects the track), possibly as an initial approximation based on the straight-line distance.
                • Then the resulting routes are calculated based on an explicit or implicitly assumed routing profile (fast, short, winding, etc.).
                • The result that best matches the profile specifications is then used to generate the route back to the track
                • MartinW
                  MartinW
                  MartinW
                  #27
                  @BertM
                  Here's a screenshot (actually a simulation with Stegra.io ) :
                  • the blue line is the original track
                  • the red/purple is the calculated (re-) route
                  • the green is the recorded track
                  • BertM
                    I understand your point and
                    is the key:
                    You are going in the direction of the original track, so the heading is importent for calculation.
                    If you made a u-turn it will send you back to the point where you came from.
                    • BertM BertM
                      is the key:
                      MartinW
                      MartinW
                      MartinW
                      In the example above with Stegra.io?
                      No. As I'm currently navigating an A-B route, a U-turn or deviation from the route will force a recalculation, and the algorithm will always lead me to the route endpoint, the intersection with the track.
                      As soon as I reach this point, route navigation mode will stop, and track navigation mode will automatically take over, providing TBT instructions based on the track.
                      DMD works the same way.
                      • Paul Smith 3
                        Paul Smith 3
                        Paul Smith 3
                        How about a compromise? Ask the developers to add an option in settings to specify on a given route how close to waypoint is close enough to move on. The figure is already hard-coded in the navigation software at somewhere around 25 meters, but I suggest making it dynamic. Even 25 meters can be too much in a medieval city center and 500 meters is more than enough on rural back roads.
                        • Paul Smith 3 Paul Smith 3
                          @Paul-Smith-3 This would just move but not solve the problem that the app can send you backwards on the track.
                          • Herman Veldhuizen
                            #32
                            Those who navigate a route as track do that because they prefer the stability of a track. My guess is that these users also have the auto recalculation setting to Off.
                            For me it would be a massiv improvement if the app would only offer navigation ON the track and not TO the track (but with the ETA info to the points ahead of me).
                            And this is maybe the easiest part to get right.
                            • Flyingstoo
                              Flyingstoo
                              Flyingstoo
                              When we go off track and the system deicides to give us a reroute to the wrong waypoint why not have some way of the app allowing us to choose
                              the entry waypoint back to the track. Maybe a message' select waypoint for return to route' whilst displaying our position and the nearest 2 waypoints.
                              • Flyingstoo Flyingstoo
                                @Flyingstoo simply display the route and long press on the waypoint you want to return to.
                                MartinW
                                MartinW
                                Flyingstoo
                                Flyingstoo
                                Paul Smith 3
                                Paul Smith 3
                                  Nick Elsom 0
                                  Nick Elsom 0
                                • 0 van 15 klaar
                                  Mark Vroomen
                                  Mark Vroomen
                                  Bart van de Griendt
                                  Bart van de Griendt
                                • Routelijn transparantie
                                  Mark Vroomen
                                  Mark Vroomen
