  4. Delete Route when open
12 Posts 6 Posters 2.1k Views 2 Watching
  • Jörgen Offline
    Jörgen Offline
    Hi, just a little suggestions.
    I am cleaning my directories with routes, because I have not used always a clear name, I have to open the route to have a look. When I decide to delete this route, I have to close it and find it in the directory.
    Damn, what was the name again?
    It would be really helpful if you could delete the route when it is open.
    A little button with confirmation. 😊
    Guzzist Travellexxie 2 Replies Last reply
    • Lluis Arasanz Offline
      I support this feature!!!!
      Great!!
      • BMW F750GS
      • Jörgen Jörgen
        Guzzist Offline
        Guzzist Offline
        @Jörgen haha - I feel with you Jörgen. Yes, for those users, which have a lot of routes in the library (and maintain it regularly) it's sometimes a frustrating job.
        A delete button (with workflow, to jump back in list view after deletion) in an open route, would be welcome.
        Otherwise: it would also be helpful (for delete/copy/move) to identify in the list view, to have a column with a little picture about the route.
        Same, if you want to make in a route visible another route or track. The workflow shows only the first part of the route or track name; that's often not enough to identify it.
        But that's slightly another topic... 🤔
        • BertM Offline
          BertM Offline
          I am curies how you see that: i never seen this possibility in any program that you can delete a document when it is open.
          If you delete it what would you like to do with the screen that is open?
          Guzzist Jörgen 2 Replies Last reply
            Return to route List.
            I side programming, is coded as:
            • Take route name or id
            • close route without saving
            • delete route name or route id
            • And left focus on route list
            • BMW F750GS
            • BertM BertM
              Guzzist Offline
              Guzzist Offline
              @BertM ...as I mentioned: with workflow in background (many other apps can do this 😉 ) and as @Lluis-Arasanz wrote...
              • BertM BertM
                Jörgen Offline
                Jörgen Offline
                @BertM said in Delete Route when open:
                The button could also be labelled “close” and “delete”, and I would then be back in the route directory.
                What ever, I am not the programmer.
                • Jörgen Jörgen
                  Travellexxie Offline
                  @Jörgen select the date column: newest first and it appears on top in the directorie
                  MRA Lifetime Gold
                  Jörgen 1 Reply Last reply
                  • Travellexxie Travellexxie
                    Jörgen Offline
                    Jörgen Offline
                    @Lex.Kloet.RX said in Delete Route when open:
                    Why should I sort the route by date? How does ist help by selecting unwanted routes?
                    Sorry I do not understand your comment.
                    • Jörgen Jörgen
                      Nick Carthew Offline
                      @Jörgen said in Delete Route when open:
                      I think what @Lex.Kloet.RX meant was: If you make a small edit to the route, when you change the sort order to Date or Change the route will appear at the top of the list so you know which route to delete.
                      Equally, you could easily add a X to the front of the route title so you know it should be deleted.
                      ![alt text](IMG_5506.jpeg image url)
                        @Nick-Carthew you thought right 😉
                        MRA Lifetime Gold
                        • Jörgen Offline
                          Jörgen Offline
                          Ok, understand. But just a quick look, does not help.
                          I like the X option, edit name is easy while open.
                          • POI naming/text display
                          • MRA groups
                            Steve Standing
                            Steve Standing
                          • Onbegrijpelijke afslagen
                            Albert Jan Gombert
                            Albert Jan Gombert
                          • High Contrast Maps
                            1.2k
                          • scenic routes maken werkt niet
                          • Folders that can store tracks and waypoints
                            martin-phogel.de
                            martin-phogel.de
                            506
