  3. [Beta] Announcements
  4. New beta! 5.0.3 (447)
94 Posts 21 Posters 711 Views 9 Watching
  • Bouke Entundefined Offline
    hopelijk krijg ik nu niet tig meldingen. op een aantal tablets geinstalleerd zowel ios als android en op aantal telefoons ios en android. hopelijk word bij upgrade van app status gelijk offline gemaakt zodat ik alleen met 2 items kan inloggen op app. we gaan het ervaren. op android trouwens beta en op ios gewoon.
      Hi everyone! 👋
      It is time for a lovely new beta.
      Not the most exciting update for you but definitely for us 😉
      Device management
      This is the core aspect of this update.
      Unfortunately we are seeing a massive amount of account sharing going on.
      At MyRoute-app we try our hardest every single day to be customer oriented and keeping our prices low. As of this year our base prices for subscriptions had to be increased (for the first time since 2021) and because of new contracts with our suppliers we also have to implement a device limit per subscription.
      As we now pay per active phone we cannot (ignorantly) allow users to use our app on an unlimited amount of phones. As of this update we allow a maximum of 2 devices to be used at the same time. When exceeding this limit (3 devices) you will be presented a beautiful interface in which you can logoff another device. After doing so, you can use your current phone again 😃
      Some important notes:
      • Excessively switching between multiple phones will lead to an automatic warning
      • Attempts to use way too many devices (4) at once will lead to an automatic block
      Our terms & conditions will be updated appropriately.
      Simply put: times of sharing your account with big groups of friends or your club are over, sharing with your partner / personal use on a few devices is still allowed.
      Note for beta testers: being a beta testers does not mean you are allowed to share your account but if for (proven) testing you wish to use more devices, simply contact our support department.
      SSO fixed
      Signing into the app using a SSO authentication method (such as Apple or Google) was broken. Luckily this has now been fixed! 🎉
      Link and file opening
      Opening links and files with the app has always been possible.
      In this update the stability of these features has been improved to ensure it works as expected when the app is in any state (such as terminated / in the background / opened).
      Minor fixes and stability improvements
      Many small issues that are not relevant to mention here have been fixed.
      Also we fixed a few errors that would result in route calculations failing.
      Finally a few critical CarPlay / Android Auto errors have been solved and we added a bit more logging to investigate some persistent issues a few users have.
      What's next
      Slowly but surely we are transitioning to a more focused dedication on the website.
      In the next update 5.1 we will:
      • Aim for solving all stability issues CarPlay and Android Auto
      • Add highly requested features to CarPlay and Android Auto
      • Major technical internal updates
      Cheers,
      Corjan
      @Corjan-Meijerink Did Some testing of the new Beta.
      I saw that the spinning map issue is not yet solved. In both navigating a route and the free drive mode there’s still a problem. When I comes to a complete stop the map turns in the north direction and the position marker moves direction north. If I was on a road with separated lanes the position marker will move to the lane that is heading north. The north direction of the dynamic mode camera view will then turn witch will be actually not north. I haven’t seen that in the previous versions. So the spin of the map is actually turning the map facing north.
      Another thing that I’ve noticed was when the notification of a speed camera pops up and your speed is over the Max speed the pop-up turns red, great feature. Maybe it was already like this but I haven’t noticed it before
        #63
        Ein Vorschlag: s. Bild, so war das da gemeint, denn ich finden den Hinweis das beim abmelden Dinge gelöscht werden schon sehr wichtig !
        Vorschlag:
        Original, hier ist die Auswahl zwischen "Meine Geräte" und "Abmelden" zu dicht beieinander. Ein Hinweis das was gelöscht wird fehlt auch !
        iPad 9. Gen iOS 26.5.2/ iPhone 16e iOS 26.5/ Navi iPhone Xr iOS 18.7.9 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
        • Bouke Entundefined Bouke Ent
          Rob Verhoeffundefined Offline
          @Bouke-Ent said in New beta! 5.0.3 (447):
          Je heb een limiet van drie apparaten waarvan er twee tegelijkertijd ingelogd kunnen zijn. Wissel jij vaker van toestel dan van sokken? Pas als je met het derde apparaat wilt navigeren dan krijg je op dat apparaat de melding om je af te melden van één van je andere apparaten. En dat vergt bijna geen extra handelingen...
          Hubert Thoringundefined Bouke Entundefined 2 Replies Last reply
          • Guzzistundefined Offline
            @Corjan-Meijerink may I ask the question: what is the background for simultaneously use of 2, but not 3 devices?
            And may it is misunderstood: if someone is using 2 mobile phones for navigation at same time - and uses a tablet at night in hotel room - this is not counted as third device? I believe the first 2 devices are used for navigation during the ride. And the third device is just in use in the hotel at evening - while the app at the 2 navigation devices is switched off. Then there are not 3 devices in count, or? I mean in the hotel, no one is going to navigate...?
              #66
              @Rob-Verhoeff said in New beta! 5.0.3 (447):
              Der Begriff „Abmelden“ ist irreführend, denn mit der einen Funktion „s.Bild“ Symbol rechts wie ein „Ausgang“ wird nicht abgemeldet sondern nur das Gerät ausgetragen und damit auf das 3. Gerät gewechselt…
              Wenn man dann den Status abfragt ist die App an diesem Gerät freigegeben!!!
              The term "log out" is misleading, because with the one function "s.picture" symbol on the right like an "output" is not logged out but only the device is logged out and thus on the 3rd Device changed...
              If you then ask for the status, the app is released on this device!!!
              Rob Verhoeffundefined Cristiano Repettiundefined 2 Replies Last reply
                @Hubert-Thoring said in New beta! 5.0.3 (447):
                And that's where translating Dutch to English to German goes wrong! I didn't use the term "Log out" in Dutch!!! So thank you for your comment that is not saying anything.
                • Lluis Arasanzundefined Offline
                  #68
                  La verdad, lo que no entenderé nunca es no respetar el idioma original del post.
                  No todo el mundo habla alemán o neerlandés o, como en mi caso, castellano.
                  Tan difícil es mantener el mismo idioma?
                  The truth is, what I will never understand is not respecting the original language of the post.
                  Not everyone speaks German or Dutch or, as in my case, Spanish.
                  Is it so difficult to maintain the same language?
                  Die Wahrheit ist, dass ich nie verstehen werde, dass die Originalsprache des Beitrags nicht respektiert wird.
                  Nicht jeder spricht Deutsch oder Niederländisch oder, wie in meinem Fall, Spanisch.
                  Ist es so schwierig, die gleiche Sprache beizubehalten?
                  De waarheid is dat ik nooit zal begrijpen dat ik de oorspronkelijke taal van de post niet respecteer.
                  Niet iedereen spreekt Duits of Nederlands of, zoals in mijn geval, Spaans.
                  Is het zo moeilijk om dezelfde taal te behouden?
                  • BMW F750GS
                    @Rob-Verhoeff ik ga terug naar max 2. maar ik heb nog een paar oude telefoons en tablets waar mra nog op staat. ik ga ze wel eerst deinstalleren omdat ze in theorie al ingelogd zijn. ik gebruikte voor kleine aanpassingen van routes een tablet met app in planner omdat menu op klein scherm in app iets handiger is dan webplanner in chrome. daar springen menus nog wel eens naar vreemde plaatsen en touch is minder handig.
                    optie blijft dan in en uitloggen..... maar dat is niet mijn voorkeur.
                    op telefoon route aanpassen is me iets te klein.
                    Bouke
                      Bouke
                      Houd er rekening mee dat je met max 3 apparaten mag werken! Als je inlogt met de 4e dan blokkeert je account 😉
                      • Cristiano Repettiundefined Offline
                        Cristiano Repetti
                        wrote on last edited by Cristiano Repetti
                        #71
                        Just noticed the devices issue. I’m lifetime member, MRA in iPhone 16 and iPad. Connected to my Harley, I received message that I need a navigation next subscription to use it. Now I try to disconnect from iPad… anyway they are only TWO devices!! (If web browser connections from PC are allowed)
                        Update: after deleted app from iPad, so I have only on iPhone, the CarPlay connected with iPhone goes well. Tried connecting to Audi and to Harley.
                        So… problem is when I have app logged on 2 devices?
                          Cristiano Repetti
                          @Hubert-Thoring where may I see this screen?? I’m looking out from app but I cannot find where to see my devices logged…
                          • Cristiano Repettiundefined Cristiano Repetti
                            @Cristiano-Repetti said in New beta! 5.0.3 (447):
                            This only comes with the second / third device in the app application...
                            It's not possible to check, but it would be helpful...
                              If you open the app on your phone and you don’t see a warning about the devices, that’s definitely not the issue.
                              Try restarting the app completely and reconnecting again to CarPlay.
                              • AWDC LAOundefined Offline
                                Een groepsabonnement zou natuurlijk welkom zijn.
                                CD130undefined AWDC LAOundefined 2 Replies Last reply
                                • paul69undefined Offline
                                  could someone answer a query for me. the answer may be obvious, but thought i would ask.
                                  as I have previously mentioned earlier in the thread, I am a supporter of device restriction, as it stops freeloaders.
                                  That said, it doesn’t really affect me personally. I only use an iPhone with a CarPlay device, plus a rugged Android tablet for multi-day tours, and I only ever use one or the other, never both at same time, anyhow,
                                  my question is.
                                  does a CarPlay unit (specifically a Carpuride 702) count as an extra device? My understanding is that you’re only logged in on the phone itself, not the CarPlay device.
                                  K1600 GTL
                                  Oukitel RT3
                                  iPhone 13 Pro, carpuride 702b
                                    @paul69 : It only affects the devices on which the app is installed, so your CarPlay device is not affected because the content of the phone is played on the CarPlay device. Have fun!
                                    • AWDC LAOundefined AWDC LAO
                                      CD130undefined Offline
                                      @AWDC-LAO zou daar niet op rekenen 😊
                                      • paul69undefined paul69
                                        my question is.
                                        @paul69 what @Hubert-Thoring says is correct.
                                        CarPlay / Android Auto is not an extra device.
                                          I'm a bit irritated, be ause I'm not familiar enough with AA/CP. Until now, I thought that these devices merely "mirror the monitor" of the connected mobile phone (wireless or wired). So, Corjan's last answer faces into my understanding.
                                          But currently @Con-Hennekens replies to me, I should not call such devices as "mirror".
                                          So, does this mean, on some AA/CP models apps can be installed?
                                          Or in other words: is my understanding correct - does the new rule only counts a device, if "Navigation Next" is really installed on a device?
                                          Corjan Meijerinkundefined Rob Verhoeffundefined b0hd1undefined Marinus van Deudekomundefined Con Hennekensundefined 5 Replies Last reply
                                          • 4
                                          • 5
                                          AWDC LAOundefined
                                          paul69undefined
                                          white.mouseundefined
                                          b0hd1undefined
                                          richtea999undefined
                                          Albert van den Elsenundefined
                                          Bouke Entundefined
                                          ConiKostundefined
                                          ConiKost
                                          M. Schrijverundefined
                                          CD130undefined
                                          Vince Hydeundefined
                                          Vince Hyde
                                          Cristiano Repetti
                                          Rob de Weijzeundefined
                                          Rob de Weijze
                                          • 3 Devices and only 1 using NN.
                                            Big Al 1undefined
                                            Big Al 1
                                          • Segmentation
                                            Lenny Oundefined
                                            Lenny O
                                          • Onbekende fout, 3 problemen
                                            Klompenmaker1undefined
                                            Klompenmaker1
                                            376
                                            supergundefined
                                            Thomas Neumeyerundefined
                                            Thomas Neumeyer
                                            1.6k
                                          • erratic routing instructions
                                          • Route opslaan op Pc vanuit telefoon MRA app
