  4. Unable to calculate route
58 Posts 12 Posters 18.4k Views 5 Watching
    So if you are in a place where there is no connection, even if there are offline maps, do you risk not being able to follow an itinerary because there is no connection?
    Marinus van Deudekom Do not disturb
    @Aiello-antonino If you end up in a place where there's no internet available for you you can turn to navigating off line. Make shure that the sync. your routes is enabled so you can start those route anywhere
    • Aiello antonino Online
      Everything you write was already done when what I wrote happened...
        I did some tests, I put it in airplane mode to recreate yesterday's situation and this is what comes out, 2 different behaviors if you change certain settings, but IMPOSSIBLE to be able to use the app if there is no signal
        With these settings
        THIS HAPPENS
        IF I CHANGE THE SETTINGS IN THE PHOTO BOX
        THIS HAPPENS
        So in these conditions, if I were to find myself somewhere (I'm planning a trip to Turkey and I don't know if I'll always have an internet connection) where there's no connection, I wouldn't be able to navigate with the app...
        Nick Carthew Peter Zehentreiter 2 Replies Last reply
          With these settings
          THIS HAPPENS
          THIS HAPPENS
          Nick Carthew Offline
          @Aiello-antonino said in Unable to calculate route:
          You need 3 things to navigate offline.
          All of the offline maps that you will use.
          All of the routes should be synced
          Offline navigation selected in the functional section of Navigation settings.
          With all these in place you can navigate entirely offline without any data connection.
            With these settings
            THIS HAPPENS
            THIS HAPPENS
            Peter Zehentreiter Offline
            @Aiello-antonino I tried to recreate your problems, but was unable to get the error you mentioned.
            Please try the following settings; they work perfectly for me.
            Im currently in Germany and the Route I opened is in Italy, without any problems.
            You can see from the screenshot that this mobile phone is completely offline, without a SIM card and without Wi-Fi.
            Screenshot_20260112-212429.MyRoute-app.png Screenshot_20260112-212443.MyRoute-app.png Screenshot_20260112-212453.MyRoute-app.png Screenshot_20260112-212515.MyRoute-app.png Screenshot_20260112-212529.MyRoute-app.png Screenshot_20260112-212548.MyRoute-app.png Screenshot_20260112-212613.MyRoute-app.png
            BMW R 1250 GS
            DMD-NOR7E 7"
            SPC Universal mount
            Motorola Edge 40 "offline"
            Sena SLR 3
            Sena 50 R
            Aiello antonino 2 Replies Last reply
              @Nick-Carthew As you can see from the photos I did everything you write, I forgot to upload the photo where you can see that I have all the maps offline, but here it is...!
                @Peter-Zehentreiter I just checked your settings and they are the same as mine in the various tests, but it doesn't work for me…
                  @Peter-Zehentreiter can you please try this route?
                  https://www.myrouteapp.com/it/social/route/12491866?mode=share
                  • M. Schrijver Offline
                    Try to use Car modus instead of Motorcycle modus. See what's happens
                      #17
                      I don't understand...now it's working perfectly as I thought it should be...
                        @M.-Schrijver I didn't change anything and now it works...I don't know what to think...
                          #19
                          It's behaving very strangely. Although all the library's openings and paths are synced, it seems some aren't. The one I was trying earlier, which I linked to, started working, and I don't understand why. Now I'm trying to load others, but some work, and others don't... I just don't understand. I'll leave you with one that can't calculate the path at the moment. Could it be that I'm doing something wrong?
                          https://www.myrouteapp.com/it/social/route/558376?
                            @Aiello-antonino Both routes you set up for us to test, work for me.
                            However, for the route “Villach/panoramica delle vette,” there is a note that routes with off-road points only work online.
                            I briefly checked your waypoints, and some of them are not correct on the line.
                            When setting your waypoints, you should also make sure not to place them in the middle of an intersection or roundabout, but rather after them.
                            Screenshot_20260113-051215.MyRoute-app.png Screenshot_20260113-051254.MyRoute-app.png Screenshot_20260113-051317.MyRoute-app.png Screenshot_20260113-051536.MyRoute-app.png Screenshot_20260113-051613.MyRoute-app.png Screenshot_20260113-051635.MyRoute-app.png Screenshot_20260113-051650.MyRoute-app.png Screenshot_20260113-051705.MyRoute-app.png
                            BMW R 1250 GS
                            DMD-NOR7E 7"
                            SPC Universal mount
                            Sena SLR 3
                            Sena 50 R
                              #21
                              Quando c’è stata la nota, dopo il percorso è partito anche se eri offline?
                              Con Hennekens Peter Zehentreiter 2 Replies Last reply
                                This is very explicitly NOT the case.
                                I will not repeat all that has been said by others, but solely what I said myself earlier:
                                It is not phone signal that is the problem here. You are probably too far away from any road for the app to decide where to start. Once you are at your bike or car, it will most likely just work. I get this also sometimes when in my backyard testing things.
                                I regularly are confronted with this issue, when testing things from the couch or in my backyard with a too large distance from any road. Lack of GPS signal could probably also cause this, or being on an uncharted road. In reality, where you start a route from within your car or near your bike that is actually ON a road, this will not happen.
                                  @Aiello-antonino, another thing to check is if you really have ALL segments of the needed maps offline. Sometimes it happens when a map update is interrupted, that some segments are skipped. So check your maps, and see if ALL needed segments have a checkmark.
                                    Yes the route started after the information!
                                    And again the phone is completly offline, no simcard, no wifi.
                                    BMW R 1250 GS
                                    DMD-NOR7E 7"
                                    SPC Universal mount
                                    Sena SLR 3
                                    Sena 50 R
                                      #25
                                      @Con-Hennekens As you say, however, it is not always like this, this is my route in Turkey, despite being very far, the 1º WP is igoumenitsa, the trip is calculated despite the ferry, and starting the navigation leaves... Yes, I don't understand what it can depend on, sometimes it works sometimes it doesn't... In the tests done I always had the maps downloaded on the device
                                      •  IMG_2806.jpeg elemento elenco
                                        #26
                                        @Aiello-antonino Like Con mentioned, download Maps again, it could be that it looks like the maps are downloaded but during an interruption while downloading something went wrong with a map.
                                        In addition, have you set all the way points on the route "panoramic del vette" accurat on the line and did you test the route again?
                                        BMW R 1250 GS
                                        DMD-NOR7E 7"
                                        SPC Universal mount
                                        Sena SLR 3
                                        Sena 50 R
                                          #27
                                          @Peter-Zehentreiter I haven't moved anything but it works...🤦🏼‍♂️
                                          David Rudgley
                                          David Rudgley
                                          • routes opening as tracks on iphone
                                          • Rondrit maken lukt niet
                                            Rob Vonk
                                            Rob Vonk
                                            291
                                          • Is there a site to go to for getting custom POI symbols
                                            Peter Burch 1 0
                                            Peter Burch 1 0
                                            785
