  4. New App - dissapointed
19 Posts 10 Posters 6.4k Views 4 Watching
    @Rob-Kelley I have never had a problem with offline maps or navigation. You can clearly see No internet in the first screenshot and no Wi-Fi or Data icons in the second screenshot.
    Rob Kelley
    Rob Kelley
    Rob Kelley
    @Nick-Carthew said in New App - dissapointed:
    Correct there's no wifi or data - that's why this is an issue around 'offline' mode, I can't test offline mode and be online at the same time.
    Here you say A > B routes cannot be calculated when offline but you say you've never had a problem offline, you can see where the confusion is coming from.
    GSA1250
    HD Street Glide
    XT500 x 2
      The update is released today so forgive the community not yet knowing everything 😉
      Edit: Answers from a while ago don’t have to be relevant for this 5.0 update
      Offline maps are now used throughout the entire application!
      Rob Kelley 1 Reply Last reply
        Rob Kelley
        Rob Kelley
        Rob Kelley
        @Corjan-Meijerink said in New App - dissapointed:
        Thanks, the issue I had was the satellite imagery not being offline - which makes total sense, the roads etc are loading nicely so good to see.
        GSA1250
        HD Street Glide
        XT500 x 2
        • Rob Kelley Rob Kelley
          @Rob-Kelley cool! If that solved it, nice.
          As said, we can add a notice (which is a great idea) when being offline but you enabled satellite maps 🙂
            Rob Kelley
            Rob Kelley
            Rob Kelley
            wrote on last edited by Rob Kelley
            If my phone is offline, (no wifi or data) it won't calculate a simple route, if I put the app into Offline mode when the phone does have a data conenction then it can calculate the route.
            If the app detects the phone is offline, it puts itself into Offline mode, it then can't calculate the route and says it needs to be Online as per my screen shots.
            GSA1250
            HD Street Glide
            XT500 x 2
              @Rob-Kelley I’d recommend downloading the offline maps again or even reinstalling.
              If the app cannot calculate a route in offline mode when you say you have all maps there are 2 scenarios:
              • user did not download (correct / all) maps
              • an internal issue with the offline maps
              • stuart marritt
                stuart marritt
                stuart marritt
                Have just tried in offline mode with all Internet turned off and it works flawlessly for me
                • D Griffin
                  D Griffin
                  D Griffin
                  I run almost every ride with off line maps! I downloaded the new version, undated my off line maps and planned my test route which I take everyday. Had no problems at all.
                  • Paul Steinberg
                    Paul Steinberg
                    Paul Steinberg
                    @Rob-Kelley hey just a thought, check that your offline maps have a checkmark beside them. In v4 I found that sometimes the downloads are interrupted and offline navigation won’t work until the downloads are completed.
                    See this thread. https://forum.myrouteapp.com/topic/10116/suggestion-prompt-to-update-downloaded-maps.?_=1762835124036
                    2022 R1250GS
                    Google Pixel 10XL
                    Android Auto
                    Chigee AIO6
                    • Adrian Avram
                      Same happened for me with all the maps freshly downloaded ...
                      From my point of view, internet should be used only to download new maps and display traffic information, just like other apps are doing (the ones that use offline maps)
                      Adrian
                      • Paul Steinberg Paul Steinberg
                        @Paul-Steinberg said in New App - dissapointed:
                        True, and this has not changed in V5. I think you have hit the culprit with this. People sometimes are so convinced they have their maps offline, but forget to check it 😉 To be honest, the method of downloading maps could benefit from some TLC.
                        • GHPA
                          GHPA
                          GHPA
                          It looks like when you enable offline navigation in the settjngs, route calculation is working. (phone in airplane mode).
                          When I switch to online navigation no route calculated possible.
                          Message something went wrong.
                          • GHPA GHPA
                            @infohagentb.nl, yes, but that is only logical isn't it? In online mode you get a message that online calculation is not possible, and the suggestion to go to offline mode, which is enabled by a confirmation... Seems completely logical to me.
                              In the next update I've added a warning when you go offline and you are using satellite maps to inform you they cannot load properly
                              Rob Kelley
                              Rob Kelley
                              Paul Steinberg
                              Paul Steinberg
                              D Griffin
                              D Griffin
                              stuart marritt
                              stuart marritt
                              GHPA
                              GHPA
                              • Route wordt afgesneden
                                Wim Hompes
                                Wim Hompes
                                Jacob Waterweg
                                Jacob Waterweg
                              • OSM Routing with MRA
