  4. Problems with the "Avoid Toll Roads" option
24 Posts 7 Posters 10.6k Views 3 Watching
  • Manzo91 Manzo91
    @Giancarlo-e you are not the only one with problematic app after the update. i'm in the same situation unfortunally. I've had to revert back to update 4.3.9 to use the app at this moment.
    Giancarlo e
    Giancarlo e
    Giancarlo e
    @Manzo91 I didn't know you could reinstall a previous version... Can you tell me how to do it? Thanks.
    Manzo91 1 Reply Last reply
    • Giancarlo e Giancarlo e
      Manzo91
      Manzo91
      Manzo91
      @Giancarlo-e Install Aptoide from Google. Uninstall version 4.4.0, look for MyRoute App in Aptoide and select "Older Versions" and get V 4.3.9 and log in with your account.
      Good Luck !
      Giancarlo e 1 Reply Last reply
      • Manzo91 Manzo91
        Good Luck !
        Giancarlo e
        Giancarlo e
        Giancarlo e
        @Manzo91 thank
          @Con-Hennekens Thank you for your comment. However, your observation doesn't change the final result. Whether on the web or in the app, the final result is the same. Whether with more OSM or with HERE maps, the result is the same. So I don't fully understand the reason for your comment. The problem is that the web and the app misinterpret the "Avoid toll roads" option.
          I'm also an avid MRA user. I think it's an excellent app and I've recommended it to many friends. But I have to admit that in the latest updates, or whatever you want to call them, the web or the app, they do things they didn't do before. Even on my Blackview 8900 Pro phone, since the last update, the app doesn't work. I load the app and the screen goes black. I don't know if it's the update or something, but the truth is that the problems coincide with the update.
          @Giancarlo-e said in Problems with the "Avoid Toll Roads" option:
          I cannot speak for your black screen problem, but the misinterpretation of your toll-road example has definitely nothing to do with any app update. I checked your situation against the TomTom and HERE maps, and they both do NOT show the same problem:
          This leads me to believe there is a map-error on the OSM map. You can apply for a change here: https://www.openstreetmap.org/fixthemap
          The reason for my earlier comment is that it is illogical to plan routes you want to navigate using the MRA app with any other then the HERE map, since the MRA Navigation module uses HERE maps exclusively. If you take notice of my advice, it definitely changes your result 😉
          • Donovan Smith
            Donovan Smith
            Donovan Smith
            I am a beginner user and think I had a similar issue. Or possibly a similar issue. I planned a route from north to south of France. I had waypoints in the route. I set options to use motorways, avoid tolls and fastest. When I opened route it did give me route violation warning. But did not say where or offer an alternative. On 3 separate occasions the guidance took me on a toll road. Which is I guess the only way to get me to my next waypoint. (This is usually avoided when using Garmin devices.)I think possibly the weighting and priority of the route planning should firstly avoid tools, then compute fastest time. Or not allow route creation. It’s hard to avoid a toll when you’re on the approach road!
            • RetiredWingMan
              Share a link to the route and make the route public. We can review the route to try and solve the issue.
                Since the last update (Version 4.4), when you select the "Avoid Toll Roads" option, the app assumes you shouldn't use highways. It's as if the app can't identify which highways are toll roads and which aren't. Examples:
                In this example, a route has been created where the "Avoid toll roads" option has not been chosen, and the app goes through the M-45 motorway (Madrid), which is not a toll road.
                In the same example, the option "Avoid toll motorways" has now been chosen, and as can be seen, the app avoids using the M-45 motorway (Madrid), identifying it as a toll motorway when it is not.
                Hi @Giancarlo-e I can replicate what you see in MRA with the OSM routing
                Inspecting the OpenStreetMap data on the OSM site, it has no tags for tolls on this section of motorway
                Replicating the same route in Osmand with the Avoid Tolls option enabled it routes correctly along the motorway
                The only conclusion I can come to is that the MRA version of the OSM data must have an incorrect Toll tag on this section
                • Donovan Smith
                  Donovan Smith
                  Donovan Smith
                  View 'To Levigniac' in MyRoute-app! https://www.myrouteapp.com/route/open/11805038 There were sections of this router prior to starting point but I deleted them after use and only have this section left
                  • Donovan Smith Donovan Smith
                    @Donovan-Smith said in Problems with the "Avoid Toll Roads" option:
                    Planning a route in OSM will start the "Navigate Route as a Track" feature, because Navigation uses the HERE map. Navigating a track does not give room for alternative routing. So if you plan your route in OSM (which obviously has a problem in that area concerning toll roads) and start navigating in the MRA app (using HERE as the only option) things like this happen.
                    • Donovan Smith
                      Donovan Smith
                      Donovan Smith
                      I planned it on the web through the web app. So can I assume the web app is osm ? I know the the Next App is here maps.
                      Brian McG 1 Reply Last reply
                        @Donovan-Smith the navigation app on your mobile uses the Here routing algorithm
                        the Here algorithm is the one used for navigation by MRA
                        on the Web planner when you are planning you can choose which routing algorithm you wish to use either OSM, TomTom or Here
                        You should choose the algorithm that matches your navigation device
                        So if your using MRA or a Garmin to navigate it is best to use the Here routing algorithm
                        If your using a TomTom obviously best to use the TomTom algorithm
                        If your using Osmand then best to use the OSM algorithm
                        The TomTom & Here routing algorithms are not available with a basic web account, you need either a Gold or Navigation subscription to access them
                        The map layers are just graphic overlays they just show you where the roads are, they are not responsible for calculating the routing
                        • Donovan Smith
                          Donovan Smith
                          Donovan Smith
                          @Brian-McG ok. I just looked on the mra route planner. I don’t have access to choose here maps as I am not a gold subscriber. I am only paying for the next nav app. So by default following your post I am guessing I am on osm maps then when I go to my nav app it’s here maps, so that’ll be the issue! If I plan a route using destination input, is that also using osm maps to plan? Vis a vis is there a way around (simple and easy ) or is this a way they force a revenue stream?
                          Nick Carthew Brian McG 2 Replies Last reply
                            An MRA Navigation Next subscription gives you access to the HERE planning map in the website route planner.
                              @Donovan-Smith if you look at the first image in my previous post you can see it says "Here (MyRouteapp/Garmin) Gold / Nav"
                              the "Nav" at then end is to indicate, as @Nick-Carthew says that the Here routing is available with the navigation subscription
                              You need to be logged in to the web planner with the same account that you use for the Navigation app
                              • Donovan Smith
                                Donovan Smith
                                Donovan Smith
                                Ok. Found the here maps setting. Thank you. Next question, if I create a a to b route on the web in the here maps. Does it always open in here maps afterwards when I choose to edit it?
                                  All routes will remember the last planning map that was used for that route.
                                  If you click Always use this map for new routes, the HERE planning map will always be chosen for new routes.
                                  • Donovan Smith
                                    Donovan Smith
                                    Donovan Smith
                                    Thank you @Nick-Carthew. So I guess then I can open and edit it in the mra app and it will do as expected. I have created a simple route here just a to be to avoid tolls. Can someone confirm it’s good please?
                                      @Donovan-Smith You'll need to share the route before anyone can check it.
                                      To share:
                                      Firstly, the privacy of the route must be set to Public.
                                      Open the route and then open the Route-information tab in the left menu column, here you'll see a Privacy drop down box where you can change the privacy to Public.
                                      Now click the Share button in the top right of the map screen, if you do not see a Share button, click Page menu first, then you’ll see Share button.
                                      After clicking Share, you have different options for sharing, choose the Link option and then copy and paste the URL web address into your reply please.
                                      • Donovan Smith
                                        Donovan Smith
                                        Donovan Smith
                                        https://www.myrouteapp.com/en/social/route/11950009?mode=share
                                          @Donovan-Smith that is a long A-B route, just shy of 600 miles
                                          it seems to be doing the right thing in avoiding the tolls
                                          I put similar start - end points in google maps & selected avoid tolls & the 2 systems seem to track pretty well
                                          a few small differences, the main one being how to route round the tool on the A63 at the Aire Port des Landes, only about 35 miles into the trip
                                          If you select the TomTom & Openstreetmap route algorithms you will see they also take slightly different paths but in general they are all doing similar things
                                          Remember to return the route algorithm setting to Here before you navigate
                                          Giancarlo e
                                          Giancarlo e
                                          Donovan Smith
                                          Donovan Smith
                                          Manzo91
                                          Manzo91
                                          • MRA Studio export speed
                                          • Map colours and side roads
                                          • route bug
                                          • geeft routepunt niet weer
                                            643
