  4. Navigation Option Show "Original Route" Does Not Display Consistently
22 Posts 8 Posters 12.1k Views 6 Watching
  • BMcG
    BMcG
    BMcG
    sometimes the offset from the road for the "original route" (track) can be large
    when this happens & zoomed in at a junction the "original route" (track) can sometimes overlay the entire junction so the exit roads from the junction are hidden/obscured by the overlay
    This imo is borderline dangerous as instead of concentrating on the dangers of navigating the junction I am busy trying to guess which exit road from the junction the navigation system is telling me I need to take
    • JP d
      JP d
      JP d
      I had the same problem so I turned off (show original route) from settings.
      Which is a shame because it is very useful to have if you decide to go on a detour and then want to get back to the original route at the nearest point. And just as a confirmation that that is the original route you planned.
      I'm sure it worked fine last year and belive it was a change or update somewhere that started to cause this issue.
      • Adrian Avram
        Had the same problem, turned off the app, deleted cache and restarted app and everything was fine.
        Adrian
        šŸ“±Samsung S24 Ultra with MyRoute-APP (GOLD Lifetime)
        šŸļøHonda NC750X (2021) with AA/CarPlay by CHIGEE Aio-5
        šŸš™Renault Duster with onboard AA/CarPlay Unit
        • BMcG BMcG
          When I load some routes for navigation the display of the "original route" beneath the planned navigation route does not conform closelyĀ to the road, it appears to straight line between some unidentifiable points
          On other routes it fits very close to the road & can only be seen to deviate a small bit when the navigation app is zoomed in to its maximum setting
          All the routes are planned with MRA on the PC & then navigated offline with MRA Navigation.
          Some routes may then be edited in the app
          Could someone please explain why with some of my routes the display of the "original route" differs?
          & while on the subject of the "original route" could the colour be changed from white to a much more contrastingĀ colour?
          on a bright sunny day with a washed out garmin map style selected the white "original route" is virtually impossible to see
          (yes I know there are other map styles but occasionally for whatever reason my style reverts to the washed out bland garmin default colouring"
          @Brian-McG, I see you are using offline-mode. I suspect you have "Navigate Routes as Tracks" enabled. Tracks work best in online mode, because tracks van only be calculated online. If offline, you get a less optimal track. If offline use is a must for you, you would better disable "Route as Track".
          BMcG Marinus van Deudekom 3 Replies Last reply
            BMcG
            BMcG
            BMcG
            @Con-Hennekens nope, not navigating tracks & option is always disabled
            I normally navigates routes as you can see from previous post picture - blue line with multiple waypoints
            The option to display the "original route" (track) is a great idea/feature, it just needs to work better (& be more visible/greater contrast on the garmin washed out style!)
            others seem to be seeing a similar issue so there has to be a cause/reason
              BMcG
              BMcG
              BMcG
              wrote on last edited by BMcG
              @Con-Hennekens These statement confused me
              but they did get me thinking -
              I always operate in offline mode, basically airplane mode because my phone, a rugged Blackview BV6200 does not contain a sim card. It is only ever connected to internet via wifi at home or hotels when touring.
              So firstly if "tracks can only be calculated online" how is the "original route" (track) being calculated when I am using mra for navigation offline & how is it producing the "original route" (track)s show in my previous posts?
              Secondly what does this mean "you get a less optimal track" & why?
              So after a bit of playing about I think I may have found something -
              If I edit a route in the web planner or via the app website route lab link - when I try to navigate this route offline the "original route" (track) displayed in the navigation will as you say not be ""optimal"
              In fact they can be far from it. In the second picture the right turn at the roundabout with the track disappearing off a couple of hundred metres before is the same roundabout shown in my first post which shows very small calculation errors, in this example the track error is huge.
              What I have found is that if I take a route that has been created on the web planner & then edit it within the app route planner I get a different & what appears to be optimal "original route" (track)
              Yes this is the same round about as in the above posts but with the "original route" (track) completley hidden because it is perfectly matched to the route/road
              So my questions are why did you think the "original route" (track) in offline mode would be "less optimal"?
              & why is it that when the route is edited in the app planner it appears to calculate the optimal "original route" (track)?
              my guess is that there is some tiny difference between the Here online map & the downloaded offline map -
              this small difference upsets/causes a glitch in the calculation of the "original route" (track) such that it uses less points (sometimes a lot less points) to calculate the "original route" (track)
              • Bouke Ent
                a track is not a orginal route. a track is a list off points in a sequeance. so track is not fixed with a map or road. with online calculation the server connects the points and looks if there is a road or path on the map and tries to follow that. offline is less able to do that and then you get straight lines between the points. because a track has many points it seem it is following the road. for old basecamp users it was the same. if calculation was not done or offroad you also got straight lines between points.
                the white line can be 2 things. if you ride a route it can be the original route and it will show if you do recalculation and route takes a new way but it will follow the road. other option it is a route based on track information and then it depends on the calculation off the server or offline in app.
                  @Con-Hennekens just got back from an 8days tour in The Eifel. Since rĆ©ception is por over there I user offline navigation all the t8me. I’ve noticed the the original route under my actual route was mostly bespied the route. Sometimes, mostly while driving hairpins it was way Off. Could using the offline mode be cousinage this
                    The calculated route is infinitely detailed šŸ™‚
                    Routes stored by us have a certain resolution to not take up way too much space when syncing them. This results in the minor differences so to say.
                    The original route is a nice indicator of how you planned it so I personally would not be too bothered by it showing these minor divergences (in resolution due to missing coordinates, not actual route).
                    BMcG 1 Reply Last reply
                      BMcG
                      BMcG
                      BMcG
                      @Corjan-Meijerink sorry the divergences of the "original route" are sometimes not minor, they are major, hundreds of metres, plus the issue is the system is not consistent
                      if the original route can fit to the road correctly after the route is edited in the app route planner,
                      why does it not fit correctly when the last edit is done on the web planner?
                      • BMcG BMcG
                        @Brian-McG, are you saying that a web-planned route that shows these imperfections does NOT show those imperfections if it got last edited in the in-app planner? That would be interesting...
                          BMcG
                          BMcG
                          BMcG
                          @Con-Hennekens yes that is what I am saying, it would be nice if someone could replicate 😜
                          I am seeing the error in offline navigation
                          the route is edited in web planner - then synced to the device
                          the device is taken offline (airplane mode or wifi/network off)
                          the route is opened & navigationĀ started with original route displayed
                          sometimes the web planned route appears ok with small errors as @Corjan-Meijerink expects
                          other times it can have larger errors & occasionally very huge errors
                          if I edit the web planned route in the app planner it seems to fit perfectly
                          I can understand the idea of trying to save storage, reduce data & speedĀ up transfer
                          if the errors were always small then I would say - not a problem
                          when the error is large the original track line can obscure whole junctions & makes it difficult to read the map
                          for me the problem is the original route is not displayed consistently
                          I don'tĀ think a long term solution is to re-edit every route every time it is transferred/synced to the app
                          oh & don'tĀ forget the lack of contrast with a white original track
                          on the default garmin style map with this bug you can see nothing of the roads
                          MotoCon JP d 2 Replies Last reply
                          • BMcG BMcG
                            @Brian-McG, This is a good find. Thanks for your elaborate explanation. I will try to replicate this behavior.
                              BMcG
                              BMcG
                              BMcG
                              Sometimes the errors with the "original track" can be huge,
                              with the above route the "original route" is wrong by hundreds & hundreds of metres
                              what causes the wrong calculation of the "original route" in offline mode?
                              I have also noticed that with a route created in the web planner,
                              if the navigation is started with a network connection, the "original route" will fit perfectly to the road
                              the same as when the route is edited in the app planner, you get a perfect fit
                              I only seem to get the bad fit of the "original route" when I start the navigation in offline mode
                              • BMcG BMcG
                                @Brian-McG, Tried to replicate this some days ago, but did not succeed... Although I have seen these straight lines before too, I was not able to replicate it in any circumstance you described. I was surprised by that and don't understand why. Old routes, new routes, offline, online, changed in the webplanner, I could not get the straight lines to appear. I'll try again later, probably after the holiday season.
                                • Marinus van Deudekom
                                  I've seen the same behavior during my 8 days trip in the Eiffel 2 weeks ago. It was clear to see it when driving hair pins.
                                  I was driving offline
                                  • Nick Carthew
                                    I think the solution is to open the route when you have wi-fi, irrespective of whether you will navigate online or offline. I had this happen to me a few weeks back, so from that point I have always opened the route with wi-fi before navigating and I haven't had the problem since.
                                    Marinus van Deudekom BMcG 2 Replies Last reply
                                      @Nick-Carthew my problem was that the WiFi was Shi... To
                                        BMcG
                                        BMcG
                                        BMcG
                                        @Nick-Carthew yes the problem only appears if you try to start to try navigating with the device offline i.e. with no internet, no wifi connection
                                        the route must be last edited in the web planner
                                        if you open/edit on the device with an internet/wifi/online connection, it will recalculate the "original route" & you won't see the problem
                                        as far as I am concerned this is a definitive hard reproducible bug
                                        I can replicate it on 3 different devices with 2 different accounts
                                        now I know there are several work arounds, it is not so much of a big issue for me
                                        just a pain having to go through extra steps to get things to work
                                        but as this seems to be the norm for mra, things never quite work as expected ... hey ho
                                        • BMcG BMcG
                                          @Brian-McG when the Devs find some time maybe they can fix it For me also low priority
                                          • BMcG BMcG referenced this topic on
                                          JP d
                                          JP d
                                          BMcG
                                          BMcG
                                            Erdna
                                            Erdna
                                          • Minimap
                                            LE DIZES Freddy
                                            LE DIZES Freddy
                                          • Bollard trouble
                                          • Map movement
