  4. Navigation Option Show "Original Route" Does Not Display Consistently
22 Posts 8 Posters 12.1k Views 6 Watching
  • BMcG BMcG
    @Corjan-Meijerink sorry the divergences of the "original route" are sometimes not minor, they are major, hundreds of metres, plus the issue is the system is not consistent
    if the original route can fit to the road correctly after the route is edited in the app route planner,
    why does it not fit correctly when the last edit is done on the web planner?
    @Brian-McG, are you saying that a web-planned route that shows these imperfections does NOT show those imperfections if it got last edited in the in-app planner? That would be interesting...
    BMcG 1 Reply Last reply
      BMcG
      BMcG
      BMcG
      @Con-Hennekens yes that is what I am saying, it would be nice if someone could replicate 😜
      I am seeing the error in offline navigation
      the route is edited in web planner - then synced to the device
      the device is taken offline (airplane mode or wifi/network off)
      the route is opened & navigationĀ started with original route displayed
      sometimes the web planned route appears ok with small errors as @Corjan-Meijerink expects
      other times it can have larger errors & occasionally very huge errors
      if I edit the web planned route in the app planner it seems to fit perfectly
      I can understand the idea of trying to save storage, reduce data & speedĀ up transfer
      if the errors were always small then I would say - not a problem
      when the error is large the original track line can obscure whole junctions & makes it difficult to read the map
      for me the problem is the original route is not displayed consistently
      I don'tĀ think a long term solution is to re-edit every route every time it is transferred/synced to the app
      oh & don'tĀ forget the lack of contrast with a white original track
      on the default garmin style map with this bug you can see nothing of the roads
      MotoCon JP d 2 Replies Last reply
      • BMcG BMcG
        @Brian-McG, This is a good find. Thanks for your elaborate explanation. I will try to replicate this behavior.
          BMcG
          BMcG
          BMcG
          wrote on last edited by BMcG
          Sometimes the errors with the "original track" can be huge,
          with the above route the "original route" is wrong by hundreds & hundreds of metres
          what causes the wrong calculation of the "original route" in offline mode?
          I have also noticed that with a route created in the web planner,
          if the navigation is started with a network connection, the "original route" will fit perfectly to the road
          the same as when the route is edited in the app planner, you get a perfect fit
          I only seem to get the bad fit of the "original route" when I start the navigation in offline mode
          • BMcG BMcG
            @Brian-McG, Tried to replicate this some days ago, but did not succeed... Although I have seen these straight lines before too, I was not able to replicate it in any circumstance you described. I was surprised by that and don't understand why. Old routes, new routes, offline, online, changed in the webplanner, I could not get the straight lines to appear. I'll try again later, probably after the holiday season.
            • Marinus van Deudekom
              I've seen the same behavior during my 8 days trip in the Eiffel 2 weeks ago. It was clear to see it when driving hair pins.
              I was driving offline
              • Nick Carthew
                I think the solution is to open the route when you have wi-fi, irrespective of whether you will navigate online or offline. I had this happen to me a few weeks back, so from that point I have always opened the route with wi-fi before navigating and I haven't had the problem since.
                Marinus van Deudekom BMcG 2 Replies Last reply
                  @Nick-Carthew my problem was that the WiFi was Shi... To
                    BMcG
                    BMcG
                    BMcG
                    @Nick-Carthew yes the problem only appears if you try to start to try navigating with the device offline i.e. with no internet, no wifi connection
                    the route must be last edited in the web planner
                    if you open/edit on the device with an internet/wifi/online connection, it will recalculate the "original route" & you won't see the problem
                    as far as I am concerned this is a definitive hard reproducible bug
                    I can replicate it on 3 different devices with 2 different accounts
                    now I know there are several work arounds, it is not so much of a big issue for me
                    just a pain having to go through extra steps to get things to work
                    but as this seems to be the norm for mra, things never quite work as expected ... hey ho
                    • BMcG BMcG
                      @Brian-McG when the Devs find some time maybe they can fix it For me also low priority
                      • BMcG BMcG referenced this topic on
                      • BMcG BMcG
                        JP d
                        JP d
                        JP d
                        @Brian-McG said in Navigation Option Show "Original Route" Does Not Display Consistently:
                        Brian you absolute LEGEND! you found a work around! I just tried it. WiFi and 4G off.
                        Offline maps and the original route was all over the place, hit the pencil icon and BOOM it follows the exact route!!
                        This is such a great hack, I had turned off (Show Original route) as it was doing more bad than good.
                        The downside is being taken down a single track thinking I don't remember planning this only to realise it wasn't part of the original route.
                        Now thanks to you I can avoid that! Thank you so much!!!
                        Hopefully the MRA team will come up with a fix in the next update @Corjan-Meijerink more work your way mate cheers šŸ».
                        JP d
                        JP d
                        BMcG
                        BMcG
                          Erdna
                          Erdna
                        • Minimap
                          LE DIZES Freddy
                          LE DIZES Freddy
                        • Bollard trouble
                        • Map movement
