  4. MRA and tunnels
MRA and tunnels
24 Posts 12 Posters 10.0k Views 7 Watching
  • Herman Veldhuizen
    mra recovers after leaving the tunnel, but inside the tunnel it behaves chaotic. it sometimes thinks that you are driving backwards, recalculates accordingly , severely effecting the ETA info.
    I have a video showing it if you are interested.
    Tomtom behaves better, i guess it assumes that you drive at constant speed and moves the cursor accordingly.
    Adrian Avram Makro 2 Replies Last reply
      @Herman-Veldhuizen yes, can you put a link to the video here ?
      Thanks !
      Adrian
      • Adrian Avram Adrian Avram
        Thanks !
        @Adrian-Avram
        https://drive.google.com/file/d/16xe9XEVUoiZR06ej2_fCkQGDLABxxj3Y/view?usp=drivesdk
        The tunnel starts 1min and 25sec into the video.
        Route:
        https://www.myrouteapp.com/route/open/10876313
          Makro
          Makro
          Makro
          @Herman-Veldhuizen said in MRA and tunnels:
          I experienced the same in a Stockholm tunnel recently. It was a bad experience, because I had to take an in-tunnel exit, and since the map didn't keep updating my assumed position, it was hard to know which exit to take.
          So Adrian, you need to look carefully at the map prior to entering a tunnel, so you know if you have to take an in-tunnel exit.
          Best regards, Makro
          • Makro Makro
            @Makro thats what I am afraid of. Thank you for the advice !
            Adrian
            • Guzt
              Guzt
              Guzt
              Swiss Alps? Don't forget to disable roaming on your telephone. When not, you're in for a surprise when you will receive your telephone bill.
              Rob Verhoeff Adrian Avram 2 Replies Last reply
              • Guzt Guzt
                @Guzt said in MRA and tunnels:
                That entirely depends on what kind of data cap you have with your provider! I don't worry at all 😉
                • Guzt Guzt
                  @Guzt I had forgotten completely about this aspect ... Thank you for reminding me !!
                  Adrian
                  • nomko
                    Banned
                    Does offline navigation not solve this issue? Or are you even with offline navigation depending on a good/solid/working GPS connection?
                    Guzzist 1 Reply Last reply
                    • Guzt
                      Guzt
                      Guzt
                      Using off line navigation or not, always switch off roaming in Switserland. They have their own telecom rules and are not part of the EU which implicates that the EU roaming agreements don't apply for them. As soon as your telephone makes contact to a Swiss telephone service, costs kick in. To avoid this, use a Swiss eSIM .
                      https://saily.com/download-esim-app/
                      Peter Zehentreiter Rob Verhoeff 2 Replies Last reply
                      • Tony 13
                        Tony 13
                        Tony 13
                        For the roaming you just need to check your contract. O2 does include Switzerland in roaming from the UK
                        https://www.o2.co.uk/help/international-and-network/using-your-phone-abroad/roaming-in-europe-pay-monthly
                        • Guzt Guzt
                          @Guzt However, this is only partially true. For example, Deutsche Telekom's tariffs include roaming in Switzerland and the UK.
                          I can't comment on other providers.
                          BMW R 1250 GS
                          DMD-NOR7E 7"
                          SPC Universal mount
                          Motorola Edge 40 "offline"
                          Sena SLR 3
                          Sena 50 R
                          • Guzt Guzt
                            @Guzt I mentioned this before... That's not entirely true! There are Dutch providers that simply consider Switzerland an EU country. For example, with my Dutch mobile plan, I'm allowed to use 50GB per month from my Dutch data bundle in an EU country (including Switzerland). So you really need to check the terms and conditions of your provider in your own country!
                            • Guzt
                              Guzt
                              Guzt
                              My provider blocks Switzerland just to avoid the possible surprise. I have to activate it or buy a data plan for it. But then, Belgian telecom is so what the most expensive in the EU.
                              So it is up to Adrian to check this with his telecom provider.
                              • Guzt Guzt
                                Time to shop elsewhere 😉
                                • nomko nomko
                                  @Nomko-Nomden offline navigation depends also on good GPS receive. Means: you don't need roaming/eSIM for Internet connection. But in long tunnels, you will loose GPS - and if there is an exit inside the tunnel, you need to take- MyRoute-App may will not navigate you!
                                  • Herman Veldhuizen
                                    #19
                                    i drove through many tunnels in Norway today, including the 25km long Laerdals tunnel. MRA worked without a glitch inside these tunnels, no spinning, no jumping to roads above the tunnel. This is with the 5.0.3 version. I even had a shaping point inside one of the tunnels and that worked as well.
                                    Guzzist TomOnTour 2 Replies Last reply
                                      @Herman-Veldhuizen ...then you are lucky.
                                      The reasons are:
                                      • Navigation systems can also interpolate their own position from direction and speed. But that only works in straight tunnels.
                                      • In some tunnels are so called beacons installed, by this navigation systems can also calculate the actual position (in GoogleMaps, this option must be activated in settings).
                                      • In other tunnels there may be TunnelSat installed. This is an advanced tunnel GPS system that extends reliable satellite navigation underground, delivering accurate, real-time positioning signal.
                                      It depends on the tunnel operator.
                                      • Guzzist Guzzist
                                        The reasons are:
                                        #21
                                        @Guzzist the fact that it worked in all tunnels made me think that HERE maybe has made an improvement (i assume a newer version of the sdk is used since I last tried it). The cursor followed the tunnel shape.
                                        I will soon drive through the tunnel again in which I know MRA was struggling.
                                        I dont think that I made any changes on my phone to settings to improve the gps accuracy.
                                        • Garry Davis
                                          Garry Davis
                                          Garry Davis
                                          Never knew about the beacons in tunnels or activation in settings. Just activated mine in Google maps. Thanks for that.
                                          TomOnTour
                                          TomOnTour
                                          Guzt
                                          Guzt
                                          Garry Davis
                                          Garry Davis
                                          Tony 13
                                          Tony 13
                                          Makro
                                          Makro
                                          • Sharing live location with friends on Android Auto problem
                                          • Ability to hide all waypoints at once after planning?
                                            Bé Jeuring
                                            Bé Jeuring
                                          • Next: Ich brauche Hilfe zu POI und Favoriten!
                                          • Planner: Convert batches of shaping points into via points and vice versa
                                          • How can I change colours in the route overview?
                                            Parantapa
                                            Parantapa
                                          • Weather: rain colors
                                          • Display street sign and name during navigation
                                          • vanuit Bibliotheek nieuwe map aanmaken!
