  4. MRA and tunnels
MRA and tunnels
24 Posts 12 Posters 7.4k Views 7 Watching
    Hi !
    In just 29 days I leave from Romania to the Swiss Alps and I am wondering how does MRA behave in tunnels (and I have to pass a lot in Austria) ?
    I want to use the track record function as well, and I was wondering if it works well trough long tunnels, where there is no GPS signal ?
    Thanks !
    Adrian
      Hi !
      Thanks !
      Nick Carthewundefined Offline
      @Adrian-Avram I would for obvious reasons avoid positioning route points inside a tunnel and I would also avoid positioning them too close to the exit of a tunnel, the app will need to wake up and get a fix on the satellites again. As the tracking works from the GPS signal, I suspect that you'll see straight lines for the tunnels.
      • Herman Veldhuizenundefined Offline
        mra recovers after leaving the tunnel, but inside the tunnel it behaves chaotic. it sometimes thinks that you are driving backwards, recalculates accordingly , severely effecting the ETA info.
        I have a video showing it if you are interested.
        Tomtom behaves better, i guess it assumes that you drive at constant speed and moves the cursor accordingly.
        Adrian Avramundefined Makroundefined 2 Replies Last reply
        • Herman Veldhuizenundefined Herman Veldhuizen
          @Herman-Veldhuizen yes, can you put a link to the video here ?
          Thanks !
          Adrian
          Herman Veldhuizenundefined 1 Reply Last reply
            Thanks !
            @Adrian-Avram
            https://drive.google.com/file/d/16xe9XEVUoiZR06ej2_fCkQGDLABxxj3Y/view?usp=drivesdk
            The tunnel starts 1min and 25sec into the video.
            Route:
            https://www.myrouteapp.com/route/open/10876313
              Makroundefined Offline
              Makro
              @Herman-Veldhuizen said in MRA and tunnels:
              I experienced the same in a Stockholm tunnel recently. It was a bad experience, because I had to take an in-tunnel exit, and since the map didn't keep updating my assumed position, it was hard to know which exit to take.
              So Adrian, you need to look carefully at the map prior to entering a tunnel, so you know if you have to take an in-tunnel exit.
              Best regards, Makro
              • Makroundefined Makro
                @Makro thats what I am afraid of. Thank you for the advice !
                Adrian
                • Guztundefined Offline
                  Guzt
                  Swiss Alps? Don't forget to disable roaming on your telephone. When not, you're in for a surprise when you will receive your telephone bill.
                  Rob Verhoeffundefined Adrian Avramundefined 2 Replies Last reply
                  • Guztundefined Guzt
                    Rob Verhoeffundefined Offline
                    @Guzt said in MRA and tunnels:
                    That entirely depends on what kind of data cap you have with your provider! I don't worry at all šŸ˜‰
                      @Guzt I had forgotten completely about this aspect ... Thank you for reminding me !!
                      Adrian
                      • nomkoundefined Offline
                        Does offline navigation not solve this issue? Or are you even with offline navigation depending on a good/solid/working GPS connection?
                        | MRA Gold Member |
                        | MRA Next + Kawasaki Z650 |
                          Guzt
                          Using off line navigation or not, always switch off roaming in Switserland. They have their own telecom rules and are not part of the EU which implicates that the EU roaming agreements don't apply for them. As soon as your telephone makes contact to a Swiss telephone service, costs kick in. To avoid this, use a Swiss eSIM .
                          https://saily.com/download-esim-app/
                          Peter Zehentreiterundefined Rob Verhoeffundefined 2 Replies Last reply
                          • Tony 13undefined Offline
                            Tony 13
                            For the roaming you just need to check your contract. O2 does include Switzerland in roaming from the UK
                            https://www.o2.co.uk/help/international-and-network/using-your-phone-abroad/roaming-in-europe-pay-monthly
                              @Guzt However, this is only partially true. For example, Deutsche Telekom's tariffs include roaming in Switzerland and the UK.
                              I can't comment on other providers.
                              BMW R 1250 GS
                              DMD-NOR7E 7"
                              SPC Universal mount
                              Motorola Edge 40 "offline"
                              Sena SLR 3
                              Sena 50 R
                                @Guzt I mentioned this before... That's not entirely true! There are Dutch providers that simply consider Switzerland an EU country. For example, with my Dutch mobile plan, I'm allowed to use 50GB per month from my Dutch data bundle in an EU country (including Switzerland). So you really need to check the terms and conditions of your provider in your own country!
                                  Guzt
                                  My provider blocks Switzerland just to avoid the possible surprise. I have to activate it or buy a data plan for it. But then, Belgian telecom is so what the most expensive in the EU.
                                  So it is up to Adrian to check this with his telecom provider.
                                    Time to shop elsewhere šŸ˜‰
                                    • nomkoundefined nomko
                                      Guzzistundefined Offline
                                      @Nomko-Nomden offline navigation depends also on good GPS receive. Means: you don't need roaming/eSIM for Internet connection. But in long tunnels, you will loose GPS - and if there is an exit inside the tunnel, you need to take- MyRoute-App may will not navigate you!
                                        #19
                                        i drove through many tunnels in Norway today, including the 25km long Laerdals tunnel. MRA worked without a glitch inside these tunnels, no spinning, no jumping to roads above the tunnel. This is with the 5.0.3 version. I even had a shaping point inside one of the tunnels and that worked as well.
                                        Guzzistundefined TomOnTourundefined 2 Replies Last reply
                                          @Herman-Veldhuizen ...then you are lucky.
                                          The reasons are:
                                          • Navigation systems can also interpolate their own position from direction and speed. But that only works in straight tunnels.
                                          • In some tunnels are so called beacons installed, by this navigation systems can also calculate the actual position (in GoogleMaps, this option must be activated in settings).
                                          • In other tunnels there may be TunnelSat installed. This is an advanced tunnel GPS system that extends reliable satellite navigation underground, delivering accurate, real-time positioning signal.
                                          It depends on the tunnel operator.
                                          nomkoundefined
                                          Makroundefined
                                          Makro
                                          Guztundefined
                                          Guzt
                                          TomOnTourundefined
                                          TomOnTour
                                          Tony 13undefined
                                          Tony 13
                                          Garry Davisundefined
                                          Garry Davis
                                            Travellexxieundefined
                                            LennyOundefined
                                            Huibertusundefined
                                            Huibertus
                                            762
                                            haweboundefined
                                            hawebo
                                            454
                                            John S Parryundefined
                                            8.1k
                                          • Updated beta! 5.2.1 (486)
                                            660
                                          • Route spoor gpx
