  4. POI
POI
16 Posts 9 Posters 5.5k Views 3 Watching
  • Mr Richard Kitchen Offline
    Mr Richard Kitchen
    Is there a way to have selected POI open automatically when creating a new route?
    Guzzist Nick Carthew 2 Replies Last reply
    • Mr Richard Kitchen Mr Richard Kitchen
      Guzzist Offline
      Guzzist Offline
      @Mr-Richard-Kitchen please what do you mean with "selected POI"? And what do you mean with "open automatically" in detail?
        Nick Carthew Online
        Nick Carthew Online
        @Mr-Richard-Kitchen Not from the MRA POI library. But if you have added a list of POIs to MRA then you can choose to have these visible in all routes and also in MRA Navigation Next.
        In your Personal POI library click the Personal (head) icon and that POI list will show in all new routes and while using MRS Navigation Next.
        • Martin Garand Offline
          Martin Garand
          I'M looking also for that.
          Is there any way to do it ?
          • Martin Garand Martin Garand
            @Martin-Garand, look one message up... 😉
            Martin Garand 1 Reply Last reply
              Martin Garand
              @Con-Hennekens I tried that. But when using POI that way, I cannot see those POI unless i'm zoomed in really close.
              If I'm zoomed out for a better overview, those POI don't show.
              But if my POI are in the Manage section, I can see them even at an overview zoom. But to be able to have POI in Manage section, you have to have created them in that route.
              Maybe I'm missing somtehing or don't understand how to use those POI...
                Nick Carthew Online
                Nick Carthew Online
                @Martin-Garand There is a very good reason why POIs are not visible when you are zoomed out, some POIs would block the map!
                • Travellexxie Offline
                  You need petrol Nick? 🤣
                  MRA Lifetime Gold
                  • Travellexxie Travellexxie
                    Nick Carthew Online
                    Nick Carthew Online
                    @Lex.Kloet.RX 😂
                      Martin Garand
                      @Nick-Carthew I understand that.
                      But, maybe with explanation of what I'm trying to do it will be more clear.
                      I'm planning a 3 weeks trip and I made a POI list of all the place I want to go.
                      If the POI are created in the route I'm planning (Manage section), I can always see them.
                      But if I export the POI and reuse them within the Library, I can't see them unless I'm zoomed in really close.
                      So I can't share my POI Library unless I always reuse the first route in which I Managed all the POI.
                      Is there another way to do it ?
                      Brett Bartick 1 Reply Last reply
                      • Con Hennekens Offline
                        I am afraid not, at least not in the current web-planner.
                        • GEORGIOS PANTELIDIS 0 Offline
                          It would be perfect if we could choose at which zoom level the POIs are visible. For example, when I want to search for campsites, I have to zoom in a lot, which isn’t helpful because I want to look around my route. If I zoom in too much, I might miss a campsite that’s there but not visible due to the zoom level.
                          Alex reds 1 Reply Last reply
                          • GEORGIOS PANTELIDIS 0 GEORGIOS PANTELIDIS 0
                            Alex reds Offline
                            Alex reds Offline
                            Alex reds
                            @GEORGIOS-PANTELIDIS-0
                            I did a test by adding the POIs for the mountain passes in Trentino and Veneto, Italy.
                            They’re already visible at this zoom level, which I think is enough to see most of a route.
                            The marked road is 288 km long, while the straight-line distance between the two points is 155 km — in my opinion, that’s sufficient to get a clear overview of a good portion of the route.mappa.png
                            GEORGIOS PANTELIDIS 0 1 Reply Last reply
                              I have good memories of Mezzolombardo. I used to fill up at the Shell gas station there. 🙂
                              MRA Lifetime Gold
                              • Alex reds Alex reds
                                @Alex-reds said in POI:
                                It’s different for POIs that you import yourself and different for the points of interest that the MyRoute Planner website provides. In the first case, it’s as you described, but in the second one, you have to zoom in quite a lot to see them. I don’t know why this happens.
                                  Brett Bartick Offline
                                  Brett Bartick
                                  @Martin-Garand said in POI:
                                  I understand exactly the issue you are having. Library POIs are only visible from a zoom level of 5 miles (10 km) or closer. If you are zoomed out to get a macro view of your route, you can't see the Library POIs.
                                  You need to do what I do. Create a POI folder and in that POI folder create empty routes that only contain "Managed" POIs, which you manually add to the empty route.
                                  Now, when you want to create a new route, just "copy" your POI route file and work from that. Now you will be able to see your managed POIs at any zoom level. Any POIs that seem to be cluttering up your route, can be quickly deleted. Going forward, always start your route creation by copy one of your empty route POI files.
                                  Martin Garand
                                  Martin Garand
                                  Alex reds
                                  Alex reds
                                  Brett Bartick
                                  Brett Bartick
                                  Mr Richard Kitchen
                                  Mr Richard Kitchen
                                  • Is there a way to put a Home button in the program
                                  • It was not possible to find a correct route to Wheels Through Time
                                    266
                                  • Google maps and Streetview
                                    Stevedo 6 0
                                    Stevedo 6 0
                                    601
                                    655
                                  • Is there a way to re-order the routes in your routes folder?
                                  • MRA 5.2.2 (489) Route time is calculated incorrectly /// Strecken Zeit wird falsch berechnet
                                  • Route doesn’t recalculate to my destination
                                  • MRA In the BMW - Cradel vertically and horizontally /// MRA im BMW - Cradel senkrecht und waagerecht nutzen
