  4. Bulk Upload of POI's
25 Posts 8 Posters 11.0k Views 6 Watching
  • MartinW MartinW
    @Dikke-Wim said in Bulk Upload of POI's:
    However, not all dots of castles of South UH that are shown on the map are found in MRA when imported.
    Hmmm... Maybe you need to zoom in?
    Overpass:
    Imported:
    Dikke Wim
    Dikke Wim
    Dikke Wim
    @Martin-Wilcke
    Unfortunately even when I zoom in more than in the example above, no additional castles appear. Only "few" of the cirkels with castles in the overpass.eu website, are visible.
    Any suggestions what I do wrong?
    Example of the map with castles in Cornwall
    No castles in Cornwall after importing the GPX file
    the KML file shows more castles in Google Earth than the GPX file in MRA
    MartinW 3 Replies Last reply
    • Dikke Wim Dikke Wim
      @Martin-Wilcke
      MartinW
      MartinW
      MartinW
      @Dikke-Wim
      OK - let's focus on "Crane Castle" as an example; it's this one:
      Please have a look at the GPX you've uploaded with an editor and search for "Crane", there should be a match like this:
      In MRA, search for "Portreath" and zoom in to a scale of 1 km / 1 mile or less:
      Does it show up?
        @Martin-Wilcke
        MartinW
        MartinW
        MartinW
        @Dikke-Wim
        And one more note:
        I have just noticed that "historic=castle" can be modelled both as a โ€˜nodeโ€™ (point) and as a โ€˜wayโ€™ (path, here in the sense of area). They appear as yellow dots for nodes and red dots for ways/areas.
        That's why my example query node ["historic"="castle"]; is not ideal, because it only finds castles that are modelled as a point.
        Better, as in your example, is nwr ["historic"="castle"]; as it includes nodes, ways and relations.
          @Martin-Wilcke
          MartinW
          MartinW
          MartinW
          @Dikke-Wim
          OK - I got it.
          You need an out centre (instead of an out geom) to create a single node for ways/areas. This will generate waypoints for both types (nodes and ways) when exporting as GPX.
          Here's the result
          https://hidrive.ionos.com/lnk/LhseBgcKc
          for the query:
          Sorry for the confusion!
          Dikke Wim JP d 2 Replies Last reply
            @Mzokk Thanks a lot. But.... is a lot of work I guess. Therefore I prefer AI who takes over the difficult stuff. I'm doing some experiments with AI. Curious how things work out.
            @Dikke-Wim Somewhat less work than the method you describe๐Ÿ‘
            Dikke Wim 1 Reply Last reply
            • MartinW MartinW
              @Dikke-Wim
              OK - I got it.
              Here's the result
              for the query:
              Dikke Wim
              Dikke Wim
              Dikke Wim
              @Martin-Wilcke
              Thanks Martin. It works now much better (see below).
              MartinW 1 Reply Last reply
              • Mzokk Mzokk
                Dikke Wim
                Dikke Wim
                Dikke Wim
                @Mzokk
                What method do you mean? I don't get it.
                For me: the easier the better!
                  @Martin-Wilcke
                  MartinW
                  MartinW
                  MartinW
                  @Dikke-Wim
                  ๐Ÿ‘
                  • MartinW MartinW
                    @Dikke-Wim
                    OK - I got it.
                    Here's the result
                    for the query:
                    JP d
                    JP d
                    JP d
                    @Martin-Wilcke this is amazing never knew how to use this feature! It would be of great help if the MRA team @Corjan-Meijerink could make a YouTube tutorial on this. ๐Ÿ™
                    • BertM BertM
                      I do not think @Greenham want to harvest POI's but to put his own POI's into MRA in bulk.
                      I use Excel to make them and then convert to GPX.
                      MRA only uses the description but If I load them into my Garmin I get the other fields also. I am now busy to find out how to bulk import a GPX into my little housemade tool.
                      Greenham
                      Greenham
                      Greenham
                      @BertM
                      Yes this is what I am trying to do. Add my own POI's
                      BertM 1 Reply Last reply
                      • Greenham Greenham
                        @BertM
                        @Greenham said in Bulk Upload of POI's:
                        @BertM
                        As another member of this forum asked me the same because I replied here, I have been dusting off my 20 year old programming skills in Excel VBA ๐Ÿ™‚
                        the today status of the tools is the following
                        • Import simple POI GPX files into Excel
                        • Edit the imported file and add Symbol, Description, Street, Phone etc for import into Garmin devices
                        • Export the POI file to GPX format
                        • Double Click on the filled in row and the POI wil open in Google maps.
                        Excel file with Ribbon (KML does not work yet)
                        MOHO hotels GPX imported into Excel
                        3rd Item in the list selected and button "Show in Google Maps" selected
                        Import in MRA from GPX file
                        Import in Basecamp with selected symbol
                        Data added in Excel and transferred to Garmin GPX, see also the different symbols in the same GPX
                        Send me your email in a PB and I send you the current file with the following status:
                        • Made and only tested in Excel/Windows10
                        • Error handeling is still poor in the progarmming
                        • Program as is, it works on my system, not tested on other equipment.
                        • Program is made in MS VBA and not tested in other programs.
                        regards,
                        Bert
                        MartinW
                        MartinW
                        JP d
                        JP d
                        Dikke Wim
                        Dikke Wim
                        Greenham
                        Greenham
                        • The menu option โ€œContinue with your last routeโ€ is missing
                          Axel Lange
                          Axel Lange
                        • In het kort......
                        • Route probleem
                          Jack 13
                          Jack 13
                          160
