  4. Bulk Upload of POI's
25 Posts 8 Posters 11.0k Views 6 Watching
  • MartinW MartinW
    @Dikke-Wim @Mzokk
    Here's another attempt in three simple steps:
    1. Launch a query on overpass-turbo.eu
    1. export as gpx
    1. upload into MRA
    Dikke Wim
    Dikke Wim
    Dikke Wim
    @Martin-Wilcke
    Thank you very much! It seems to work great....
    However, not all dots of castles of South UH that are shown on the map are found in MRA when imported.
    Do you have any idea how to fix this? See screendumps below.
    See e.g. Cornwall with many castles
    Cornwall without any castles
    MartinW 1 Reply Last reply
    • Dikke Wim Dikke Wim
      @Martin-Wilcke
      MartinW
      MartinW
      MartinW
      @Dikke-Wim said in Bulk Upload of POI's:
      Hmmm... Maybe you need to zoom in?
      Overpass:
      Imported:
      Dikke Wim 1 Reply Last reply
      • MartinW MartinW
        Overpass:
        Imported:
        Dikke Wim
        Dikke Wim
        Dikke Wim
        @Martin-Wilcke
        Unfortunately even when I zoom in more than in the example above, no additional castles appear. Only "few" of the cirkels with castles in the overpass.eu website, are visible.
        Any suggestions what I do wrong?
        Example of the map with castles in Cornwall
        No castles in Cornwall after importing the GPX file
        the KML file shows more castles in Google Earth than the GPX file in MRA
        MartinW 3 Replies Last reply
          @Martin-Wilcke
          MartinW
          MartinW
          MartinW
          @Dikke-Wim
          OK - let's focus on "Crane Castle" as an example; it's this one:
          Please have a look at the GPX you've uploaded with an editor and search for "Crane", there should be a match like this:
          In MRA, search for "Portreath" and zoom in to a scale of 1 km / 1 mile or less:
          Does it show up?
            @Martin-Wilcke
            MartinW
            MartinW
            MartinW
            @Dikke-Wim
            And one more note:
            I have just noticed that "historic=castle" can be modelled both as a β€˜node’ (point) and as a β€˜way’ (path, here in the sense of area). They appear as yellow dots for nodes and red dots for ways/areas.
            That's why my example query node ["historic"="castle"]; is not ideal, because it only finds castles that are modelled as a point.
            Better, as in your example, is nwr ["historic"="castle"]; as it includes nodes, ways and relations.
              @Martin-Wilcke
              MartinW
              MartinW
              MartinW
              @Dikke-Wim
              OK - I got it.
              You need an out centre (instead of an out geom) to create a single node for ways/areas. This will generate waypoints for both types (nodes and ways) when exporting as GPX.
              Here's the result
              https://hidrive.ionos.com/lnk/LhseBgcKc
              for the query:
              Sorry for the confusion!
              Dikke Wim JP d 2 Replies Last reply
                @Mzokk Thanks a lot. But.... is a lot of work I guess. Therefore I prefer AI who takes over the difficult stuff. I'm doing some experiments with AI. Curious how things work out.
                @Dikke-Wim Somewhat less work than the method you describeπŸ‘
                • MartinW MartinW
                  @Dikke-Wim
                  OK - I got it.
                  Here's the result
                  for the query:
                  Dikke Wim
                  Dikke Wim
                  Dikke Wim
                  @Martin-Wilcke
                  Thanks Martin. It works now much better (see below).
                  • Mzokk Mzokk
                    Dikke Wim
                    Dikke Wim
                    Dikke Wim
                    @Mzokk
                    What method do you mean? I don't get it.
                    For me: the easier the better!
                      @Martin-Wilcke
                      MartinW
                      MartinW
                      MartinW
                      @Dikke-Wim
                      πŸ‘
                      • MartinW MartinW
                        @Dikke-Wim
                        OK - I got it.
                        Here's the result
                        for the query:
                        JP d
                        JP d
                        JP d
                        @Martin-Wilcke this is amazing never knew how to use this feature! It would be of great help if the MRA team @Corjan-Meijerink could make a YouTube tutorial on this. πŸ™
                        • BertM BertM
                          I do not think @Greenham want to harvest POI's but to put his own POI's into MRA in bulk.
                          I use Excel to make them and then convert to GPX.
                          MRA only uses the description but If I load them into my Garmin I get the other fields also. I am now busy to find out how to bulk import a GPX into my little housemade tool.
                          Greenham
                          Greenham
                          Greenham
                          @BertM
                          Yes this is what I am trying to do. Add my own POI's
                          BertM 1 Reply Last reply
                          • Greenham Greenham
                            @BertM
                            @Greenham said in Bulk Upload of POI's:
                            @BertM
                            As another member of this forum asked me the same because I replied here, I have been dusting off my 20 year old programming skills in Excel VBA πŸ™‚
                            the today status of the tools is the following
                            • Import simple POI GPX files into Excel
                            • Edit the imported file and add Symbol, Description, Street, Phone etc for import into Garmin devices
                            • Export the POI file to GPX format
                            • Double Click on the filled in row and the POI wil open in Google maps.
                            Excel file with Ribbon (KML does not work yet)
                            MOHO hotels GPX imported into Excel
                            3rd Item in the list selected and button "Show in Google Maps" selected
                            Import in MRA from GPX file
                            Import in Basecamp with selected symbol
                            Data added in Excel and transferred to Garmin GPX, see also the different symbols in the same GPX
                            Send me your email in a PB and I send you the current file with the following status:
                            • Made and only tested in Excel/Windows10
                            • Error handeling is still poor in the progarmming
                            • Program as is, it works on my system, not tested on other equipment.
                            • Program is made in MS VBA and not tested in other programs.
                            regards,
                            Bert
                            MartinW
                            MartinW
                            JP d
                            JP d
                            Dikke Wim
                            Dikke Wim
                            Greenham
                            Greenham
                            • The menu option β€œContinue with your last route” is missing
                              Axel Lange
                              Axel Lange
                            • In het kort......
                            • Route probleem
                              Jack 13
                              Jack 13
                              160
