  4. Bulk Upload of POI's
25 Posts 8 Posters 11.0k Views 6 Watching
  • Greenham Greenham
    Is there an easy way to bulk upload POI's? I am referring to the use of a spreadsheet/CVS that I would properly add all my desired POI's into a spreadsheet then upload them ALL?
    It would be really handy to have a formatted example of a spreadsheet/CVS with all the proper headings for easy population. They could be easily shared, added too etc.
    It has to be fairly easy as this is just one big database.
    Am I right?
    @Greenham I have a POI file that I am constantly updating and I use this website. I upload the file, add points, then download the new updated file.
    https://www.poieditor.com/
    Adrian
    • nomko nomko
      Da's heel apart, die ik het in ChatGPT dan krijg ik dit te zien:
      Geen .gpx bestand zoals bij @Dikke-Wim. Doe ik iets verkeerd?
      Dikke Wim
      Dikke Wim
      Dikke Wim
      @Nomko-Nomden
      Ik heb ChatGPT gebruikt en daarbinnen de ChatBot "Travel Guide". Helaas kun je die maar zeer beperkt gratis gebruiken. Dus gisteravond moest ik wachten om verder te kunnen.
      Maar uiteindelijk wordt er een GPX file gegenereerd en een KML file op mijn verzoek om in Google Earth e.a. te kunnen zien.
      Zie hieronder wat ik bedoel met "Travel Guide">
      Mzokk 1 Reply Last reply
      • Dikke Wim Dikke Wim
        @Nomko-Nomden
        @Dikke-Wim you can also use Qgis to harvest POI's from OSM mapping.
        You need two add ins to get the information QuickOSM
        Which gives a dialog like this.
        And POI exporter which allows export as a GPX file that MRA can read.
        Dikke Wim 1 Reply Last reply
        • Mzokk Mzokk
          Dikke Wim
          Dikke Wim
          Dikke Wim
          @Mzokk Thanks a lot. But.... is a lot of work I guess. Therefore I prefer AI who takes over the difficult stuff. I'm doing some experiments with AI. Curious how things work out.
          MartinW Mzokk 2 Replies Last reply
            MartinW
            MartinW
            MartinW
            @Dikke-Wim @Mzokk
            Here's another attempt in three simple steps:
            1. Launch a query on overpass-turbo.eu
            1. export as gpx
            1. upload into MRA
            BertM Dikke Wim 2 Replies Last reply
            • MartinW MartinW
              @Dikke-Wim @Mzokk
              1. export as gpx
              1. upload into MRA
              I do not think @Greenham want to harvest POI's but to put his own POI's into MRA in bulk.
              I use Excel to make them and then convert to GPX.
              MRA only uses the description but If I load them into my Garmin I get the other fields also. I am now busy to find out how to bulk import a GPX into my little housemade tool.
              Greenham 1 Reply Last reply
              • MartinW MartinW
                @Dikke-Wim @Mzokk
                1. export as gpx
                1. upload into MRA
                Dikke Wim
                Dikke Wim
                Dikke Wim
                @Martin-Wilcke
                Thank you very much! It seems to work great....
                However, not all dots of castles of South UH that are shown on the map are found in MRA when imported.
                Do you have any idea how to fix this? See screendumps below.
                See e.g. Cornwall with many castles
                Cornwall without any castles
                MartinW 1 Reply Last reply
                  @Martin-Wilcke
                  MartinW
                  MartinW
                  MartinW
                  @Dikke-Wim said in Bulk Upload of POI's:
                  Hmmm... Maybe you need to zoom in?
                  Overpass:
                  Imported:
                  • MartinW MartinW
                    Overpass:
                    Imported:
                    Dikke Wim
                    Dikke Wim
                    Dikke Wim
                    @Martin-Wilcke
                    Unfortunately even when I zoom in more than in the example above, no additional castles appear. Only "few" of the cirkels with castles in the overpass.eu website, are visible.
                    Any suggestions what I do wrong?
                    Example of the map with castles in Cornwall
                    No castles in Cornwall after importing the GPX file
                    the KML file shows more castles in Google Earth than the GPX file in MRA
                    MartinW 3 Replies Last reply
                      @Martin-Wilcke
                      MartinW
                      MartinW
                      MartinW
                      @Dikke-Wim
                      OK - let's focus on "Crane Castle" as an example; it's this one:
                      Please have a look at the GPX you've uploaded with an editor and search for "Crane", there should be a match like this:
                      In MRA, search for "Portreath" and zoom in to a scale of 1 km / 1 mile or less:
                      Does it show up?
                        @Martin-Wilcke
                        MartinW
                        MartinW
                        MartinW
                        @Dikke-Wim
                        And one more note:
                        I have just noticed that "historic=castle" can be modelled both as a ‘node’ (point) and as a ‘way’ (path, here in the sense of area). They appear as yellow dots for nodes and red dots for ways/areas.
                        That's why my example query node ["historic"="castle"]; is not ideal, because it only finds castles that are modelled as a point.
                        Better, as in your example, is nwr ["historic"="castle"]; as it includes nodes, ways and relations.
                          @Martin-Wilcke
                          MartinW
                          MartinW
                          MartinW
                          @Dikke-Wim
                          OK - I got it.
                          You need an out centre (instead of an out geom) to create a single node for ways/areas. This will generate waypoints for both types (nodes and ways) when exporting as GPX.
                          Here's the result
                          https://hidrive.ionos.com/lnk/LhseBgcKc
                          for the query:
                          Sorry for the confusion!
                          Dikke Wim JP d 2 Replies Last reply
                            @Dikke-Wim Somewhat less work than the method you describe👍
                            • MartinW MartinW
                              @Dikke-Wim
                              OK - I got it.
                              Here's the result
                              for the query:
                              Dikke Wim
                              Dikke Wim
                              Dikke Wim
                              @Martin-Wilcke
                              Thanks Martin. It works now much better (see below).
                              • Mzokk Mzokk
                                Dikke Wim
                                Dikke Wim
                                Dikke Wim
                                @Mzokk
                                What method do you mean? I don't get it.
                                For me: the easier the better!
                                  @Martin-Wilcke
                                  MartinW
                                  MartinW
                                  MartinW
                                  @Dikke-Wim
                                  • MartinW MartinW
                                    @Dikke-Wim
                                    OK - I got it.
                                    Here's the result
                                    for the query:
                                    JP d
                                    JP d
                                    JP d
                                    @Martin-Wilcke this is amazing never knew how to use this feature! It would be of great help if the MRA team @Corjan-Meijerink could make a YouTube tutorial on this. 🙏
                                    • BertM BertM
                                      Greenham
                                      Greenham
                                      Greenham
                                      @BertM
                                      Yes this is what I am trying to do. Add my own POI's
                                      BertM 1 Reply Last reply
                                      • Greenham Greenham
                                        @BertM
                                        @Greenham said in Bulk Upload of POI's:
                                        @BertM
                                        As another member of this forum asked me the same because I replied here, I have been dusting off my 20 year old programming skills in Excel VBA 🙂
                                        the today status of the tools is the following
                                        • Import simple POI GPX files into Excel
                                        • Edit the imported file and add Symbol, Description, Street, Phone etc for import into Garmin devices
                                        • Export the POI file to GPX format
                                        • Double Click on the filled in row and the POI wil open in Google maps.
                                        Excel file with Ribbon (KML does not work yet)
                                        MOHO hotels GPX imported into Excel
                                        3rd Item in the list selected and button "Show in Google Maps" selected
                                        Import in MRA from GPX file
                                        Import in Basecamp with selected symbol
                                        Data added in Excel and transferred to Garmin GPX, see also the different symbols in the same GPX
                                        Send me your email in a PB and I send you the current file with the following status:
                                        • Made and only tested in Excel/Windows10
                                        • Error handeling is still poor in the progarmming
                                        • Program as is, it works on my system, not tested on other equipment.
                                        • Program is made in MS VBA and not tested in other programs.
                                        regards,
                                        Bert
                                        MartinW
                                        MartinW
                                        JP d
                                        JP d
                                        Dikke Wim
                                        Dikke Wim
                                        Greenham
                                        Greenham
                                          Axel Lange
                                          Axel Lange
                                        • In het kort......
                                        • Route probleem
                                          Jack 13
                                          Jack 13
                                          161
