  3. map contrast issues
map contrast issues
33 Posts 15 Posters 19.2k Views 7 Watching
    @Sharon-Wilson No... the map is provided bij Here!
    Sharon Wilson
    Sharon Wilson
    Sharon Wilson
    @Rob-Verhoeff I see the Here map using the app on my phone but its not the same on carplay, much more simple basic map with very little definition.
    • Dae 0
      Dae 0
      Dae 0
      wrote on last edited by Dae 0
      It’s one of the reasons I only use MRA for planning and Scenic (iOS only) for navigating - Scenic allows complete customisation of colours and also allows you to change font sizes and line/road thicknesses.
      I had the same contrast issue with the default Here! colour scheme that Scenic was using, both using the iPhone as a navigation device and also using the Chigee CarPlay device. These are the colours I use now - not pretty but high contrast and totally readable on my Chigee even in the brightest direct sunshine.
      The following are zoomed out quite far - you can see a lot of detail clearly when zoomed in more
      Sharon Wilson HighPeakRider 2 Replies Last reply
      • Dae 0 Dae 0
        Sharon Wilson
        Sharon Wilson
        Sharon Wilson
        @Dae-0 Thanks, I have the Scenic, I'll give it a try. 👍
        Hopefully though MRA will address this, I purchased the Nav add on to keep it simple and have everything in one place, MRA Routplanner is useless if the map is unreadable.
        Dae 0 1 Reply Last reply
        • Bouke Ent
          i have the same problem with Here maps. my wish is to have color selection but i do not know if it will come on the list.
          • Bouke Ent
            @Peter-Schiefer good to hear you have no problem. i have the problem also the white track line and the white landscape background. i hope there will be a solution for that. route (blue) and recorded trackline (yellow) are good but origonal track line (white) is hard to see.
            • Sharon Wilson Sharon Wilson
              Dae 0
              Dae 0
              Dae 0
              @Sharon-Wilson said in map contrast issues:
              I know what you mean. I’d love to have MRA as my one-stop-shop, but sometimes you have to use tools that are perfect for their own task, rather than a multi-tool. MRA is unrivalled for planning, but Scenic is far more useable for actual navigation. I therefore plan everything in MRA, export as GPX1.2 and import it into Scenic. Scenic will even show you the original MRA route (blue line) and what it has calculated, allowing you to spot differences and correct them by adding waypoints to “pull” the route back on track to match the MRA one.
              It’s definitely not a Chigee issue. My wife and I both used iPhones (different ones) and had the same low contrast issue, which is the same experience with the Chigee CarPlay. I created a custom colour set in Scenic, as when that got updated to the new Here! SDK it had the same issue. The Scenic personal colour scheme is honoured in CarPlay, meaning I get the same high-contrast whether I use my phone on its own or the Chigee.
              The Chigee is a brilliant display and goes far brighter than the iPhone displays did. They also don’t suffer from the issue where the phone gets too warm and dims the display, making the low contrast even worse.
              Hopefully you have some success until MRA makes the personalisation of colour/road width/font size that allows us all to adapt to our own vision capabilities. My work has highlighted that we all see things differently, and what may be brilliant for one person may be practically unusable for someone else. It’s easy to dismiss other people’s issues with “it works fine for me”, but that doesn’t help anyone.
                It is a weird development but indeed all maps have gotten more pale 😞
                That said, the next app update will have a drastic improvement regarding this topic 😏
                More on that later! 🎉
                  Rob Veerman
                  Rob Veerman
                  Rob Veerman
                  @Corjan-Meijerink OMG, how long will this discussion go on? Let’s go ride our motorcycle. Much admiring the good work the team is doing. Later this year I will be in Iran, using MRA hopefully. WHO cares about the colors of the map? Keep enjoying your ride, whereever you are! Excuses for grammar mistakes, not using my glasses right now.
                  • Rob Veerman Rob Veerman
                    @Rob-Veerman the colours are quite important to be honest 🙂
                    But for the app it will be a discussion of the past soon!
                      Rob Veerman
                      Rob Veerman
                      Rob Veerman
                      @Corjan-Meijerink I sincerely hope so, not because of the colours, but because in plain Dutch: 'het commentaar over de kleuren is in mijn ogen soms een hoop geneuzel'. Waar hebben we het soms over als ik de commentaren lees. Ga als MRA-gebruiker gewoon lekker motorrijden (en ik heb het uiteraard niet over het team dat zijn/haar werk uitstekend verricht). Veel bewondering voor wat jullie doen in zo'n klein team en velen worden bij hun opmerkingen bijna onmiddellijk op hun wenken bediend.Complimenten daarvoor! Maar iedereen mag er natuurlijk zijn eigen mening over hebben: ik begrijp heel goed dat jullie een divers publiek moeten bedienen. Persoonlijk ben ik sinds 2017 een heel tevreden gebruiker. Jullie doen het echt uitstekend!!!
                      • Jörgen
                        @Rob-Veerman Just a friendly reminder. We have once agreed to reply in the same language as the post begins. 🙂
                        • Jörgen Jörgen
                          Rob Veerman
                          Rob Veerman
                          Rob Veerman
                          @Jörgen Request? Yes. Agreed? No. But I am aware of the famous German expression "Ordnung muss sein" (could be translated as 'there must be order'). 😉
                          Jörgen 1 Reply Last reply
                            @Rob-Veerman said in map contrast issues:
                            Nonsense, this is just a friendly gesture towards people who don't speak every language.
                            • Jörgen Jörgen
                              Rob Veerman
                              Rob Veerman
                              Rob Veerman
                              @Jörgen Come on Jörgen, you're sensitive. I was just teasing you a bit using that expression. Don't feel offended.
                                Don´t worry I am not offended, I am a friendly person like Dutch people.
                                • Dae 0 Dae 0
                                  HighPeakRider
                                  HighPeakRider
                                  HighPeakRider
                                  @Dae-0 Thanks, I'd not looked at Senic, but currently it seems to have advantages over MRA.
                                  Direct record in CarPlay, provision of stats for each ride , ave mph, distance, total ride distance etc.
                                  Things I missed on my Triumph which I had in the BMW app.
                                  Will have to see if these get developed in MRA as this also leaves me using multiple apps.
                                  • HighPeakRider HighPeakRider
                                    @HighPeakRider said in map contrast issues:
                                    Stats are available from an MRA tracklog if you tap the icon.
                                    HighPeakRider 1 Reply Last reply
                                      HighPeakRider
                                      HighPeakRider
                                      HighPeakRider
                                      @Nick-Carthew Yes but not the totals?
                                      Not that I've yet used it yet to start collecting any stats yet.
                                      Klaus r 1 Reply Last reply
                                        Klaus r
                                        Klaus r
                                        Klaus r
                                        This is the main reason why I still use my zumo XT for nav.
                                        With customized colours (in the kmtf files) it offers me high contrast readable map even in brigth sun shine.
                                        And the zumo also uses HERE maps ...
                                          More styles incoming! 😏
                                          Rob Veerman
                                          Rob Veerman
                                          Thomas Schäfer
                                          Thomas Schäfer
                                          Dae 0
                                          Dae 0
                                          HighPeakRider
                                          HighPeakRider
                                          Klaus r
                                          Klaus r
                                          Mark Bird
                                          Mark Bird
                                          Sharon Wilson
                                          Sharon Wilson
                                            Rene van Maanen
                                            Rene van Maanen
                                          • _Tracklogs folder nearly empty?
                                          • One crash today
                                          • Tracklogs access at friends and clubs
                                            Mosimann
                                            Mosimann
                                          • Foutmelding bij aanmelden beta planner: klassieke account is al gebruikt voor de loyaliteitsprijs op een ander account
                                          • 6.0 UI in landscape needs pollishing
