  4. Roundtour to a dead end?
11 Posts 6 Posters 1.3k Views 3 Watching
  • HighPeakRiderundefined Offline
    HighPeakRider
    Every time I try to create a round tour it seems to route to a dead end?
    Screenshot example.
    Nomko Nomdenundefined 1 Reply Last reply
    • HighPeakRiderundefined HighPeakRider
      Screenshot example.
      Nomko Nomdenundefined Offline
      Nomko Nomden
      @HighPeakRider
      To me it seems like that road is closed due to some restrictions, roadworks, seasonal closure.
      Can you give us the link to that route, make sure the route is set to public
      | MRA Gold Member |
      | MRA Next + Kawasaki Z650 |
        HighPeakRider
        Nothing to indicate a closure on Google maps and it actually does it twice...
        https://www.myrouteapp.com/routetrack/open/9659158
        Rob Verhoeffundefined Nomko Nomdenundefined 2 Replies Last reply
          Rob Verhoeffundefined Online
          @HighPeakRider It depends on your intentions and how you are planning to make the scenic tour! Are you using the app while already on the motorcycle and ready to ride immediately? Or are you planning the route, for instance, the evening before while sitting at your PC? In both cases, MRA creates one or more routes for you. If you accept the route immediately and start riding directly, you might encounter a loop or be directed down a street only to be turned back. My advice would be to accept the route in the planner (by default, this is a track with just a start and end point). The planner then turns this track into a route with two via-points (start and finish) and multiple shaping-points. After this, check if there are any shaping points in illogical places and move them to a different spot on the route or simply remove them.
          If you you have a gold subscription you can also highlight the traffic overlay to see if there are some traffic issues on your route.
          • Nick Carthewundefined Nick Carthew moved this topic from [App] Problems, Bugs and other Issues on
          • Nick Carthewundefined Online
            The route generator in the website is sub optimal and often the routes require tinkering. The round trip generator in the app is much better. You can be riding a route with just 3 clicks.
            Lynchy67undefined Corjan Meijerinkundefined 2 Replies Last reply
              Lynchy67undefined Offline
              Lynchy67
              @Nick-Carthew
              The TS was actually using a Round Tour.
              In my experience using Round Tours they often contain roads that would require a U Turn.
              I just remove them to create a continuous loop.
              You donโ€™t stop riding when you get old, you get old when you stop riding.
              • Lynchy67undefined Lynchy67
                @Nick-Carthew
                @Lynchy67 said in Roundtour to a dead end?:
                @Nick-Carthew
                Yes, but created on the website. The one built into the app creates them not only more accurately but faster too.
                Lynchy67undefined 1 Reply Last reply
                  @Nick-Carthew
                  Lynchy67
                  @Nick-Carthew
                  Doh! I didn't even realise there was an In App version.
                  I'll get my coat...............
                    @Nick-Carthew the UI / UX of the app is indeed better.
                    It really is however the same roundtour calculations with similar flaws ๐Ÿ˜‰
                      @Corjan-Meijerink said in Roundtour to a dead end?:
                      Maybe I donโ€™t notice the flaws because it creates a round trip so quickly ๐Ÿ˜
                        Nomko Nomden
                        @HighPeakRider
                        To me, it looks like there's no flaw or whatsoever. First of all, at 2 locations a left/right turn was made but the route was followed as it should be (routepoint 18 and routepoint 33).
                        If it was intended to follow the road at routepoint 18, routepoint 19 should be located at a location which follows the route after routepoint 18. Same goes for routepoint 33 and routepoint 34.
                        Even when i turn off seasonal closures, nothing changed on the route.
                        If you could elaborate which direction you prefer from routepoint 18 and routepoint 33, i could have a better look in how this went wrong in MRA.
                        But for now, my conclusion is, is that routepoint 18 and 33 are misplaced and should not been there.
                        | MRA Gold Member |
                        Nomko Nomden
                        HighPeakRider
                        Lynchy67undefined
                        Lynchy67
                        • Problem: Scenic routing ignore setup for avoiding motorways
                          Lluis Arasanzundefined
                          20
                          22
                          392
                        • MRA lagging and freezing on AA
                          Adrian Avramundefined
                        • 1e Online trainingen 2026!
                        • Carpuride et myroute
                        • Vrij rijden
                        • Carpe Iter Caretta
                        • Open route function not working. Unable to transfer routes to Garmin XT2
                          AWDC LAOundefined
