  4. Phone can't charge as fast as the app uses power
15 Posts 9 Posters 4.8k Views 5 Watching
  • Jörgen
    Hi, I can report that my Oukitel outdoor tablet with 8inch screen runing in full brightness can load the battery normal after changing the USB converter and the USB cable. Before I run also into an empty battery after some hours.
    I guess the bottleneck was more the cable.
    • Jörgen
      A nice little Android App to watch battery Status ist called Power Line. See the small Line on right Side of the Screen.
      Dave J 0 Con Hennekens 2 Replies Last reply
      • Jörgen Jörgen
        @Jörgen thanks for this suggestion. Works really well on my Pixel 6 Pro and I like the simplicity and flexibility of configuration. Good suggestion.
        iPhone 18 Pro
        Stephane 30 1 Reply Last reply
        • Dave J 0 Dave J 0
          Stephane 30
          Stephane 30
          Stephane 30
          Just wanted to add my half penny to this discussion. There are a lot of angry comments about this issue. However, I don't think it's that easy and straightforward. I have been out today for a 6.5 hour tour (including a couple of coffee breaks) and did 130 miles (210 km) using MRA for navigation and tracking simultaneously. I started with 80% charge and arrived back home with 19% - no charger used during the ride. I don't listen to music or play games while riding. I'm using a Pixel 8.
          So far I didn't had any issues with MRA and heavy discharging. A problem could well be the phone setup and/or issues with other apps running in the background.
          This post is probably not helpful to anyone but it's just for the records.
          Moto Guzzi V85 TT. MRA on my Pixel 8 (Android 16) and occasionally a TomTom Rider.
          Kudee 1 Reply Last reply
            @Doug-Robinson
            This is what I found about the HereWeGo app, uses the same map.
            Will using GPS reduce my phone's battery life?
            HERE WeGo uses GPS to work and your phone might deplete more of your battery while you're actively navigating. (This is quite common with apps that depend on your phone settings.) If you feel that our app consumes too much of your battery life, we'd recommend that you check your phone's battery settings and adapt it according to your usage.
            https://here.freshdesk.com/en/support/solutions/articles/24000068332-will-using-gps-reduce-my-phone-s-battery-life-
            @Hans-van-de-Ven-MRA-Master said in Phone can't charge as fast as the app uses power:
            "Not my problem, mate. It's all your fault for not configuring your phone correctly." says HERE.
            • Jörgen Jörgen
              @Jörgen, That app is rather nice, giving continuous information of battery and charging without interfering with the foreground app. However I removed it since it demands full-phone access to everything. Not something I am eager to give away...
              Jörgen 1 Reply Last reply
                @Con-Hennekens Interesting on my Android version all permissions are off?
                • Stephane 30 Stephane 30
                  Kudee
                  Kudee
                  Kudee
                  @Stephane-30 The old APP did not have this behavior, also Here, so i guess that can be fixed
                  • Jörgen Jörgen
                    @Jörgen, I take it this is the one you use?
                    https://play.google.com/store/apps/details?id=com.urbandroid.inline&hl=nl&gl=US
                    A:
                    This app can see where you tap or change what's displayed on the screen.
                    B:
                    Allow PowerLine to have full control over your device? Full control is appropriate for apps that help you with accessibility, but not for most other apps.
                    So it can read the passwords you type, look at the unlock sequence you draw, and probably take passwords out of your Chrome vault too...
                      A:
                      B:
                      Sorry, we are killing this thread.
                      @Con-Hennekens see last sentence.
                      • Jörgen Jörgen
                        @Jörgen said in Phone can't charge as fast as the app uses power:
                        Metoo! 😉
                        But that sentence only indicates that the developer SAYS he is not evil... 😉
                        Kudee
                        Kudee
                        Stephane 30
                        Stephane 30
                          Kevin Bird
                          Kevin Bird
                          20
                          185
                        • Statement on map spinning
                          17
                          36
                          3.5k
                        • Change route color
                        • First time version 6 and AA
                        • Some minor improvements ;-)
