  4. Phone can't charge as fast as the app uses power
15 Posts 9 Posters 4.2k Views 5 Watching
  • RetiredWingMan Offline
    I decided to move this discussion to a new post.
    Due to the excessive power usage of the app, some people are unable to charge fast enough to maintain the battery level. On hot days the phone can overheat and shut down. I just installed the Quadlock 15 watt wireless charger. I found it only charges at about 6 w (about 1.4 amps at 4.? Volts). When I plugged my phone into a good wall charger it charged at 12.4 watts and the phone said it was fast charging. I don't have any other wireless chargers so I don't know if this is common or a problem with the phone or the wireless charger. I was using Accubattery to monitor the battery usage and charging rate. Does anyone else have wireless chargers? What charging levels do you get?
      Edwin_M did some testing:
      I did some additional testing and I must say that I am dissapointed in the performance of the Quadlock Wireless Charger (with USB connection). It is a very expensive accessory and it is advertised to reach up to 10W with Galaxy devices. (using a good power supply ofcourse).
      And yes the power drain of the MRA next app is still on the high side.
      In short , the wireless charger does not exceed 6W of power supply in my tests.
      Phone is an S24+ .
      Case is a Quadlock Mag Case
      I have the USB connection version of the Wireless charging head. combined with the Motorcycle - Waterproof 12V To USB Smart Adaptor - Quad Lock® Europe - Official Store (quadlockcase.eu)
      I did some testing:
      Checked on phone: Turned of battery protection and checked all battery fast charging options are on. Used an additional quality USB-A to USB-C cable to test (otherwise I'll need to get a lot of covers of of my motorcycle) all fast charge options are enabled
      Without Quadlock: tested directly on the a charger : outcomes: On an USB-A output max 2,4A => 7 W charging second USB-A output with a QC3.0 => 12,5 W.
      3, Quadlock hardware test: used the same cable wired directly on the 12V Quadlock convertor => 12 W
      Quadlock hardware test: used the same cable from the 12V quadlock convertor to the wireless head = 6W
      Quadlock wireless charging head connected to wall charger (as in bullet 2): 1. on QC3.0 port => 6W max via charging head second on normal port max 2,4A resulting in 3,4W max via charging head
      response of Quadlock on results:
      *Our wireless charging head has advertising on our product page to charge at a maximum of 10W, as yours is charging at 5W it still sitting with the expected performance.
      Just to note that you will always have a faster charging speed using a cable as this is not surprising because we can't expect the wireless charge to perform the same.*
      The latter is obvious. But losing 6W over the wireless charging head is dissapointing to say the least.
      (i found that , with a 100 km roundtour, first edit in Routeplanner online) using it as a route from that to navigate with and using Dark mode, the phone was able to charge. In light mode , the drain is too big at the moment.
      Also must state that I am always using Flitsmeister AND youtube music in background as well;
      Samsung S24+ Android , KTM 1290 Super Adventure & Wielrenfietsen
        Phone is an S24+ .
        I did some testing:
        Marinus van Deudekom Do not disturb
        @Doug-Robinson the way I see it
        MRA still uses to mich power. Combined with thé wireless charging head it is Just simply to mich. So thé phone can’t keep up charging.
        Solution fix thé power comcumption caused by Here. I know that Corjan is trying to fix thuis with Garmin but with poor succès.
        Maybe thé solution is finding another card then thé Here. I think Garmin is doing a simple case off protecting it’s own product and have llitle or no interest in MRA, on thé other hand MRA is paying for thé use of Here and therefore must receive a good product.
        Keep up the good work @corjanmeijrink
          @Doug-Robinson
          This is what I found about the HereWeGo app, uses the same map.
          Will using GPS reduce my phone's battery life?
          HERE WeGo uses GPS to work and your phone might deplete more of your battery while you're actively navigating. (This is quite common with apps that depend on your phone settings.) If you feel that our app consumes too much of your battery life, we'd recommend that you check your phone's battery settings and adapt it according to your usage.
          https://here.freshdesk.com/en/support/solutions/articles/24000068332-will-using-gps-reduce-my-phone-s-battery-life-
          richtea999 1 Reply Last reply
          • Jörgen Offline
            Jörgen Offline
            Hi, I can report that my Oukitel outdoor tablet with 8inch screen runing in full brightness can load the battery normal after changing the USB converter and the USB cable. Before I run also into an empty battery after some hours.
            I guess the bottleneck was more the cable.
            • Jörgen Offline
              Jörgen Offline
              A nice little Android App to watch battery Status ist called Power Line. See the small Line on right Side of the Screen.
              Dave J 0 Con Hennekens 2 Replies Last reply
              • Jörgen Jörgen
                Dave J 0 Offline
                Dave J 0 Offline
                @Jörgen thanks for this suggestion. Works really well on my Pixel 6 Pro and I like the simplicity and flexibility of configuration. Good suggestion.
                iPhone 15 Pro
                Stephane 30 1 Reply Last reply
                • Dave J 0 Dave J 0
                  Stephane 30 Offline
                  Stephane 30 Offline
                  Stephane 30
                  Just wanted to add my half penny to this discussion. There are a lot of angry comments about this issue. However, I don't think it's that easy and straightforward. I have been out today for a 6.5 hour tour (including a couple of coffee breaks) and did 130 miles (210 km) using MRA for navigation and tracking simultaneously. I started with 80% charge and arrived back home with 19% - no charger used during the ride. I don't listen to music or play games while riding. I'm using a Pixel 8.
                  So far I didn't had any issues with MRA and heavy discharging. A problem could well be the phone setup and/or issues with other apps running in the background.
                  This post is probably not helpful to anyone but it's just for the records.
                  Moto Guzzi V85 TT. MRA on my Pixel 8 (Android 16) and occasionally a TomTom Rider.
                  Kudee 1 Reply Last reply
                    @Doug-Robinson
                    richtea999 Offline
                    richtea999 Offline
                    @Hans-van-de-Ven-MRA-Master said in Phone can't charge as fast as the app uses power:
                    "Not my problem, mate. It's all your fault for not configuring your phone correctly." says HERE.
                    • Jörgen Jörgen
                      @Jörgen, That app is rather nice, giving continuous information of battery and charging without interfering with the foreground app. However I removed it since it demands full-phone access to everything. Not something I am eager to give away...
                      Jörgen 1 Reply Last reply
                        Jörgen Offline
                        Jörgen Offline
                        @Con-Hennekens Interesting on my Android version all permissions are off?
                        • Stephane 30 Stephane 30
                          Kudee Offline
                          Kudee Offline
                          Kudee
                          @Stephane-30 The old APP did not have this behavior, also Here, so i guess that can be fixed
                          • Jörgen Jörgen
                            @Jörgen, I take it this is the one you use?
                            https://play.google.com/store/apps/details?id=com.urbandroid.inline&hl=nl&gl=US
                            A:
                            This app can see where you tap or change what's displayed on the screen.
                            B:
                            Allow PowerLine to have full control over your device? Full control is appropriate for apps that help you with accessibility, but not for most other apps.
                            So it can read the passwords you type, look at the unlock sequence you draw, and probably take passwords out of your Chrome vault too...
                              A:
                              B:
                              Jörgen Offline
                              Jörgen Offline
                              Sorry, we are killing this thread.
                              @Con-Hennekens see last sentence.
                              • Jörgen Jörgen
                                @Jörgen said in Phone can't charge as fast as the app uses power:
                                Metoo! 😉
                                But that sentence only indicates that the developer SAYS he is not evil... 😉
                                Kudee
                                Kudee
                                Stephane 30
                                Stephane 30
                                  287
                                • Google maps and Streetview
                                  Stevedo 6 0
                                  Stevedo 6 0
                                  806
                                  siebo vd berg
                                  siebo vd berg
                                  533
                                • Transport modes?
                                • New Zealand Routes
