  4. PROBLEME AFFICHAGE DRAPEAU
18 Posts 7 Posters 4.0k Views 1 Watching
  • jollivet  laurentundefined jollivet laurent
    bonjour a la création de nouveau parcours
    je n ai plus le drapeau de la France a cote du logo
    de la moto .pourquoi?
    Lynchy67undefined Offline
    Lynchy67
    @jollivet-laurent
    This can happen frequently!
    The fix is to go back into the Route and move the first Via Point slightly.
    It should then show the relevant flag.
    • Lynchy67undefined Lynchy67
      @jollivet-laurent
      Jack van Tilburg
      @Lynchy67 said in PROBLEME AFFICHAGE DRAPEAU:
      Not always.
      Here's an example where moving the first point doesn't work.
      Add a shaping point. does help in this case.
      https://www.myrouteapp.com/en/social/route/8370760?mode=share
      Rob Verhoeffundefined 2 Replies Last reply
        Not always.
        Rob Verhoeffundefined Offline
        @Jack-van-Tilburg That's remarkable! I truly thought that @Lynchy67 had the key to success!
          Not always.
          @Jack-van-Tilburg said in PROBLEME AFFICHAGE DRAPEAU:
          You know what's really strange? Moving waypoint 1 does make the flag appear (I moved the point to some random main road in the inland), but as soon as you put the point back to its original location, the flag disappears again! What a mystery!!!
            Jack van Tilburg
            @Rob-Verhoeff
            I have worked in IT for a long time and have learned that you should not always look for the cause if the workaround is obvious and the disruptive situation does not occur often.
            The solution in this case is to move the first point or add a shaping point. Adding or moving a shaping point seems to work best.
            Good enough for me. 😀
            Lynchy67undefined 1 Reply Last reply
              @Rob-Verhoeff
              Lynchy67
              @Jack-van-Tilburg
              I moved your last Via Point slightly and that initiated the flag to appear also.
                @Jack-van-Tilburg
                Jack van Tilburg
                Great, so that's the next solution. I'll list them below:
                Tips for displaying the correct flag in the personal library:
                Scherm­afbeelding 2023-11-08 om 10.14.04.png Move the first or last waypoint slightly.
                Or:
                Scherm­afbeelding 2023-11-08 om 10.14.18.png Move or add a shapingpoint.
                Too bad the title of this topic is in French. If someone is looking for this problem, finding it is a bit more difficult.
                Lynchy67undefined Drabslabundefined 2 Replies Last reply
                  Or:
                  Lynchy67
                  @Jack-van-Tilburg
                  Maybe you could create a post in English for this.
                  You are much more prevalent in the forums than me.
                  And I always read all your posts.
                    Or:
                    Drabslabundefined Offline
                    I see more and more german and french language posts in the english forum.
                    These should perhaps be moved to the correct sections, or the forum should include an auto-translator?
                      This is not a language specific section.
                      It's only due to the distribution of our users that Dutch & English are the favorite languages.
                      There is no objection against users giving feedback / asking questions in their own language 😉
                        Jack van Tilburg
                        @Lynchy67
                        Maybe a moderator wil adapt the titel?
                          Jack van Tilburg
                          @Corjan-Meijerink said in PROBLEME AFFICHAGE DRAPEAU:
                          In any case, that's not what I meant.
                          But for the forum's reference function it would be useful if the title was in English.
                          • Drabslabundefined Drabslab
                            @Drabslab said in PROBLEME AFFICHAGE DRAPEAU:
                            It cannot be long before AI will auto-translate everything into your favorite language 😉
                            Jack van Tilburg
                            Drabslabundefined
                            Lynchy67undefined
                            Lynchy67
                            jollivet laurent
                            • 3 Devices and only 1 using NN.
                              supergundefined
                            • RX routes
                            • Am I using it wrong?
                              Kerry Lebelundefined
                              Kerry Lebel
                            • Spoken streetnames
                              GT JWRundefined
                            • Constant herberekenen op CarPlay
                              Gos Kuusundefined
                              Gos Kuus
                              Nick Carthewundefined
                              1.6k
                              Reinhard Punzundefined
                              Reinhard Punz
