  4. PROBLEME AFFICHAGE DRAPEAU
18 Posts 7 Posters 4.2k Views 1 Watching
  • jollivet  laurent jollivet laurent
    @Rob-Verhoeff OUI J AI MIS UN POINT
    ET SUR MES PARCOURS PRECEDENT LE DRAPEAU ETAIT PRESENT
    Rob Verhoeff Offline
    @jollivet-laurent Would you like to share the route here?
      bonjour a la création de nouveau parcours
      je n ai plus le drapeau de la France a cote du logo
      de la moto .pourquoi?
      Lynchy67 Offline
      Lynchy67 Offline
      Lynchy67
      @jollivet-laurent
      This can happen frequently!
      The fix is to go back into the Route and move the first Via Point slightly.
      It should then show the relevant flag.
      • Lynchy67 Lynchy67
        @jollivet-laurent
        Jack van Tilburg Offline
        Jack van Tilburg
        @Lynchy67 said in PROBLEME AFFICHAGE DRAPEAU:
        Not always.
        Here's an example where moving the first point doesn't work.
        Add a shaping point. does help in this case.
        https://www.myrouteapp.com/en/social/route/8370760?mode=share
        Rob Verhoeff 2 Replies Last reply
          Not always.
          @Jack-van-Tilburg That's remarkable! I truly thought that @Lynchy67 had the key to success!
            Not always.
            @Jack-van-Tilburg said in PROBLEME AFFICHAGE DRAPEAU:
            You know what's really strange? Moving waypoint 1 does make the flag appear (I moved the point to some random main road in the inland), but as soon as you put the point back to its original location, the flag disappears again! What a mystery!!!
              Jack van Tilburg
              @Rob-Verhoeff
              I have worked in IT for a long time and have learned that you should not always look for the cause if the workaround is obvious and the disruptive situation does not occur often.
              The solution in this case is to move the first point or add a shaping point. Adding or moving a shaping point seems to work best.
              Good enough for me. 😀
              Lynchy67 1 Reply Last reply
                @Rob-Verhoeff
                Lynchy67 Offline
                Lynchy67 Offline
                Lynchy67
                @Jack-van-Tilburg
                I moved your last Via Point slightly and that initiated the flag to appear also.
                • Lynchy67 Lynchy67
                  @Jack-van-Tilburg
                  Jack van Tilburg
                  Great, so that's the next solution. I'll list them below:
                  Tips for displaying the correct flag in the personal library:
                  Scherm­afbeelding 2023-11-08 om 10.14.04.png Move the first or last waypoint slightly.
                  Or:
                  Scherm­afbeelding 2023-11-08 om 10.14.18.png Move or add a shapingpoint.
                  Too bad the title of this topic is in French. If someone is looking for this problem, finding it is a bit more difficult.
                  Lynchy67 Drabslab 2 Replies Last reply
                    Or:
                    Lynchy67 Offline
                    Lynchy67 Offline
                    Lynchy67
                    @Jack-van-Tilburg
                    Maybe you could create a post in English for this.
                    You are much more prevalent in the forums than me.
                    And I always read all your posts.
                      Or:
                      Drabslab Offline
                      Drabslab Offline
                      I see more and more german and french language posts in the english forum.
                      These should perhaps be moved to the correct sections, or the forum should include an auto-translator?
                      • Corjan Meijerink Online
                        This is not a language specific section.
                        It's only due to the distribution of our users that Dutch & English are the favorite languages.
                        There is no objection against users giving feedback / asking questions in their own language 😉
                        • Jack van Tilburg Offline
                          Jack van Tilburg
                          @Lynchy67
                          Maybe a moderator wil adapt the titel?
                            Jack van Tilburg
                            @Corjan-Meijerink said in PROBLEME AFFICHAGE DRAPEAU:
                            In any case, that's not what I meant.
                            But for the forum's reference function it would be useful if the title was in English.
                            • Drabslab Drabslab
                              @Drabslab said in PROBLEME AFFICHAGE DRAPEAU:
                              It cannot be long before AI will auto-translate everything into your favorite language 😉
                              Jack van Tilburg
                              Jack van Tilburg
                              Lynchy67
                              Lynchy67
                              jollivet  laurent
                              jollivet laurent
                              • HERE maps updates
                                12.5k
                                1.4k
                                Alfred Schrittwieser
                                734
                                Bruno 7
                                Bruno 7
