  4. PROBLEME AFFICHAGE DRAPEAU
18 Posts 7 Posters 4.0k Views 1 Watching
  • jollivet  laurentundefined Offline
    jollivet laurent
    bonjour a la création de nouveau parcours
    je n ai plus le drapeau de la France a cote du logo
    de la moto .pourquoi?
    Rob Verhoeffundefined Lynchy67undefined 2 Replies Last reply
    • jollivet  laurentundefined jollivet laurent
      Rob Verhoeffundefined Offline
      @jollivet-laurent In order to display the French flag, your route needs at least one waypoint. Have you placed that waypoint? Can you share your route here? Just make sure the route is public.
      Jack van Tilburgundefined jollivet  laurentundefined 2 Replies Last reply
        Jack van Tilburg
        @Rob-Verhoeff said in PROBLEME AFFICHAGE DRAPEAU:
        To stay in MRA terms; shaping point 🙂
          jollivet laurent
          @Rob-Verhoeff OUI J AI MIS UN POINT
          ET SUR MES PARCOURS PRECEDENT LE DRAPEAU ETAIT PRESENT
            @jollivet-laurent Would you like to share the route here?
              Lynchy67undefined Offline
              Lynchy67
              @jollivet-laurent
              This can happen frequently!
              The fix is to go back into the Route and move the first Via Point slightly.
              It should then show the relevant flag.
              • Lynchy67undefined Lynchy67
                @jollivet-laurent
                Jack van Tilburg
                @Lynchy67 said in PROBLEME AFFICHAGE DRAPEAU:
                Not always.
                Here's an example where moving the first point doesn't work.
                Add a shaping point. does help in this case.
                https://www.myrouteapp.com/en/social/route/8370760?mode=share
                Rob Verhoeffundefined 2 Replies Last reply
                  Not always.
                  @Jack-van-Tilburg That's remarkable! I truly thought that @Lynchy67 had the key to success!
                    Not always.
                    @Jack-van-Tilburg said in PROBLEME AFFICHAGE DRAPEAU:
                    You know what's really strange? Moving waypoint 1 does make the flag appear (I moved the point to some random main road in the inland), but as soon as you put the point back to its original location, the flag disappears again! What a mystery!!!
                      Jack van Tilburg
                      @Rob-Verhoeff
                      I have worked in IT for a long time and have learned that you should not always look for the cause if the workaround is obvious and the disruptive situation does not occur often.
                      The solution in this case is to move the first point or add a shaping point. Adding or moving a shaping point seems to work best.
                      Good enough for me. 😀
                      Lynchy67undefined 1 Reply Last reply
                        @Rob-Verhoeff
                        Lynchy67
                        @Jack-van-Tilburg
                        I moved your last Via Point slightly and that initiated the flag to appear also.
                          @Jack-van-Tilburg
                          Jack van Tilburg
                          Great, so that's the next solution. I'll list them below:
                          Tips for displaying the correct flag in the personal library:
                          Scherm­afbeelding 2023-11-08 om 10.14.04.png Move the first or last waypoint slightly.
                          Or:
                          Scherm­afbeelding 2023-11-08 om 10.14.18.png Move or add a shapingpoint.
                          Too bad the title of this topic is in French. If someone is looking for this problem, finding it is a bit more difficult.
                          Lynchy67undefined Drabslabundefined 2 Replies Last reply
                            Or:
                            Lynchy67
                            @Jack-van-Tilburg
                            Maybe you could create a post in English for this.
                            You are much more prevalent in the forums than me.
                            And I always read all your posts.
                              Or:
                              Drabslabundefined Offline
                              I see more and more german and french language posts in the english forum.
                              These should perhaps be moved to the correct sections, or the forum should include an auto-translator?
                                This is not a language specific section.
                                It's only due to the distribution of our users that Dutch & English are the favorite languages.
                                There is no objection against users giving feedback / asking questions in their own language 😉
                                  Jack van Tilburg
                                  @Lynchy67
                                  Maybe a moderator wil adapt the titel?
                                    Jack van Tilburg
                                    @Corjan-Meijerink said in PROBLEME AFFICHAGE DRAPEAU:
                                    In any case, that's not what I meant.
                                    But for the forum's reference function it would be useful if the title was in English.
                                    • Drabslabundefined Drabslab
                                      @Drabslab said in PROBLEME AFFICHAGE DRAPEAU:
                                      It cannot be long before AI will auto-translate everything into your favorite language 😉
                                      Jack van Tilburg
                                      Drabslabundefined
                                      Lynchy67undefined
                                      Lynchy67
                                      jollivet laurent
                                      • 3 Devices and only 1 using NN.
                                        supergundefined
                                      • Spoken streetnames
                                        GT JWRundefined
                                      • RX routes
                                      • Am I using it wrong?
                                        Kerry Lebelundefined
                                        Kerry Lebel
                                      • Constant herberekenen op CarPlay
                                        Gos Kuusundefined
                                        Gos Kuus
                                        Nick Carthewundefined
                                        1.6k
                                        Steve Jarrellundefined
                                        Steve Jarrell
                                        1.4k
