  4. Bug Web App: veer wordt niet goed meegenomen in gpx
13 Posts 6 Posters 3.9k Views 2 Watching
  • Gerard Wullink Offline
    Gerard Wullink
    I created a 355km route on OSM which was enhanced to 199 soft/shaping points.
    Checking the route against HERE and TomTom did not reveal any issues in difference of routing.
    I exported the route as a gpx1.1 (Track, POI), which contains about 7000 gpx points (20 points/km, a point every 50m).
    The route contains a ferry over the Rine river at Bad Breisig. I deliberately added two points at both banks of the river and mark No. 192 (see picture) as Skip (Overslaan), the "old" way of telling to ingnore the map and draw a straightline from point.
    Now I send the gpx to the participants, which he import as a Route-Track..
    User can use the gpx to export to his GPS device, leaving the claculation to the GPS (and its map, setup, OS version etc).
    Opening the gpx in MRA for editing, and using the HERE MAP creates a different route! It ignores the ferry and heads for a bridge further down the Rhine.
    And there are more differences.
    First thought is that RMA does not import all the gpx track points.
    The reason I imported the exported gpx in RMA again is to see if there are any unpaved roads in it. This cannot be done at the OSM map as soon as Segments are used.
    Can you tell me what is best practice?
    • Create route at OSM incl Segments.
    • Compare to TT and HERE.
    • Export to GPX for participants.
    • How to check for Unpaved roads?
    • Corjan Meijerink Corjan Meijerink moved this topic from [App] Problems, Bugs and other Issues on
    • Gerard Wullink Gerard Wullink
      Herko ter Horst Offline
      @Gerard-Wullink The isn't with MRA itself, but with the HERE map, which doesn't like to route over ferry's for some reason. The work-around is to set a routepoint on both sides of the crossing and then set the one on the "far" side to "Skip".
      Drabslab Gerard Wullink 2 Replies Last reply
        Drabslab Offline
        Drabslab Offline
        @Herko-ter-Horst said in Bug Web App: veer wordt niet goed meegenomen in gpx:
        The speed of a ferry is unknown (and often relatively slow) . I guess that for the route calculaiton, making a detour is always faster than taking the ferry?
        Corjan Meijerink Herko ter Horst 2 Replies Last reply
        • Drabslab Drabslab
          Corjan Meijerink Offline
          @Drabslab spot on πŸ˜‰
          Within the very near future we will support "shortest" routing too which is perfect for these situations. Then HERE will prefer the shorter distance (and thus the ferry). For small ferries, no scheduling information is available, causing the travel time to become infinite - then a detour will by definition be faster, no matter how long the detour is πŸ™‚
          • Drabslab Drabslab
            @Drabslab Except of course it really isn't, at least not for the river crossing ferries in the Netherlands and Germany. In my experience, a crossing (+wait) rarely takes more than 10-15 minutes . Yes, you could be unlucky and see the ferry depart just as you arrive, which means a 15-20 minute wait + a 5-10 minute crossing. But even then it's hardly worth doing a potential 20 km(or more) round trip to use a bridge. Also, if this was the really the case, why do none of the other navigation options in MRA or Google do the same? Do they have information HERE doesn't? To me, this is one of the most annoying aspects of HERE.
              @Corjan-Meijerink "Shortest" routing may work fine in this specific situation, but in most other situation it can be very annoying. For example, on motorways it may take you off and back on the motorway at an exit just to save 10 meters. And in towns it will send you through 30 km zones with dozens of speed bumps instead of around on the main road to save 500m, but adding 5-10 minutes of annoying driving in the process.
              I can't see many situations (other than this specific one to work around a defect in HERE's algorithm) in which "shortest" routing is useful.
                @Herko-ter-Horst "shortest" routing is more intelligent than just that πŸ˜‰
                It does make certain tradeoffs.
                Route calculation from start to destination disregarding any speed information. In this mode, the distance of the route is minimized, while keeping the route sensible. This includes, for example, penalizing turns. Because of that, the resulting route will not necessarily be the one with minimal distance.
                Meaning that
                should not occur πŸ™‚
                Drabslab 1 Reply Last reply
                  Meaning that
                  Drabslab Offline
                  Drabslab Offline
                  @Corjan-Meijerink said in Bug Web App: veer wordt niet goed meegenomen in gpx:
                  should not occur
                  I should be able to find back a practical example where this did occur (but before Next).
                  A river with a road on both sides, and regular bridges crossing it. Depending on the meandering of the river, the navigation sent me over each bridge πŸ™‚ πŸ™‚
                  but there will always be exceptions where the automated calcualtions don't work. That is why the human effort preparing and planning the route remains important (thank the gods for that πŸ™‚ ).
                  • Corjan Meijerink Offline
                    @Drabslab agree. Do not that MRA has not ever yet supported "shortest" mode - so all MRA related examples will be fastest by default.
                    @Herko-ter-Horst Fun thing to now, TomTom actually has another mode: "short". So their "shortest" mode is just as HERE - tries to keep a sensible.
                    Their "short" mode however enforces shortest distances over sensible roads.
                    shortest: Route calculation is optimized by travel distance, while keeping the routes sensible. For example, straight routes are preferred over those incurring turns.
                    short: Route calculation is optimized such that a good compromise between small travel time and short travel distance is achieved.
                    CD130 1 Reply Last reply
                    • Hans van de Ven MR.MRA Hans van de Ven MR.MRA moved this topic from General Discussion on
                      CD130 Online
                      CD130 Online
                      @Corjan-Meijerink Suggestion: it would be cool if we could mix the different preferences (fastest, shortest (, offroad)) in 1 route. That is also possible in Basecamp πŸ˜‰ Then we only have to set it to β€œshortest” at the crossing and we can leave the rest of the route on β€œfastest”.
                      The adventure starts where the plans end | READY TO >> RACE 🧑
                        Gerard Wullink
                        @Herko-ter-Horst "I deliberately added two points at both banks of the river and mark No. 192 (see picture) as Skip (Overslaan)". That what youn mean or am I wrong?
                        Gerard Wullink 1 Reply Last reply
                          Gerard Wullink
                          @Gerard-Wullink said in Bug Web App: veer wordt niet goed meegenomen in gpx:
                          Still the routing goes over the bridge....
                          • TorqueRider Offline
                            TorqueRider Offline
                            @Gerard-Wullink
                            That's correct unfortunately.
                            The "Skip" is only functional in the planner not in Navigation.
                            Gerard Wullink
                            Gerard Wullink
                            • Route Breakdown
                            • Saludo
                            • The slow death of Zumo...
                              671
                            • MRA Touring Romania Group
                            • I can't see Road Closures
                              Lary
                              Lary
