  3. Beta instructions 🤖Android (Forum)
Scheduled Pinned Locked Moved [App-Beta] The MyRoute-app
21 Posts 14 Posters 2.5k Views 4 Watching
    👋Welcome Tester!
    If your application for the Android Beta of MRA Navigation Next has been approved, you can get started with the instructions below. Do the check below one more time:
    1. Have you signed up for the Android Beta?
      Please take a good look at the e-mail you received from us. Android should be listed under the 'test platform'. Is this correct?
      💚Yes, go to the next question.
      ⛔No, send an email to support@myrouteapp.com and indicate your Android email address so that we can add you.
    2. Has your spot been released?
      You should have received an email from us entitled “Access ticket MRA Navigation Next Beta”. Is this so?
      💚Yes, nice! You can participate.
      ⛔No, your spot has not been released yet. We add new users to the test environment every two weeks.
    Answered yes to all of the above? Then you can continue with the following instructions.
    ⚠️Make sure you have read the above questions carefully to avoid confusion.
    ⚠️Please note: MyRoute-app is developing MRA Navigation Next as part of our one app vision. That means that the Beta of MRA Navigation Next will be held through the well-known “MyRoute-app Mobile” app.
    How to participate in the Beta:
    1. Go to https://play.google.com/apps/testing/com.cloudmax.myrouteapp ;
    2. Follow the instructions on the test page;
    3. Do you see an error message? Then the Android email address you registered is incorrect. In this case, please contact support@myrouteapp.com and provide the correct email address;
    4. Search the Play Store for “ MyRoute-app Mobile ” or go to https://play.google.com/store/apps/details?id=com.cloudmax.myrouteapp . Here you should now see that you are a tester. Wait a minute. Google always takes a little time to process these requests. Here you can install the latest Beta;
    5. Finished!
    Have fun testing!
    ⚖️Conditions for testers
    From this moment you can participate in the beta version. When the Beta ends you will also receive an email from us about the best way to deactivate it. To make good use of the Beta, here are some rules to keep in mind:
    🤷Questions, problems and suggestions
    As a tester you may want to make the most of your opportunities to influence the development of MRA Navigation Next. Which can. You do this by starting discussions and participating in ongoing discussions on the MRA Navigation Next Forum . The MRA team actively watches, writes and reads along.
    💔Note: fragile!
    A Beta is an 'early version' of the final product. This means that not all functionalities may be available yet, the experience varies from version to version and problems may arise during use. Problems, bugs and suggestions are therefore not dealt with via support, but via the forum .
    🙅I don't want to be a beta tester anymore.
    2. Unsubscribe from the test program;
    3. Wait a minute. Google always takes a moment to figure this out;
    4. uninstall the app from your phone;
    5. Search the Play Store for “ MyRoute-app Mobile ” or go to https://play.google.com/store/apps/details?id=com.cloudmax.myrouteapp . Here you should now see that you are no longer a tester. Here you can also download the normal version of MyRoute-app Mobile again;
    6. Finished!
    😱Help! I can't access the Beta.
    Are you unable to participate in the Beta with the above instructions and have you checked whether you have access? Don't worry, you can send us an email at support@myrouteapp.com . Then we will help you on your way again.
    Paul Foster
    Paul Foster
    Paul Foster
    @Timo-Martosatiman-MRA said in Beta instructions 🤖Android (Forum):
    Do I wait before I install the app, Do I install then wait to open it, you say to wait a minute, how do I now I have waited long enough, and which part.
    Paul Foster 1 Reply Last reply
    • Paul Foster Paul Foster
      Paul Foster
      Paul Foster
      Paul Foster
      @Paul-Foster
      OK, I waited before installing, and I have the next beta.
      • Kaffkieker
        Kaffkieker
        Kaffkieker
        wrote on last edited by Kaffkieker
        I did install the version 3.2.4 Beta and made my first steps/trials with this App. Now I read in the forum that a new version 3.2.5 Beta is available, but i can´t update my installation and searching in the Google PlayStore shows 3.2.4 Beta as the actual version?
        Is 3.2.5 for Android not yet available or what is my fault?
        JakoA 1 Reply Last reply
        -6
        • Dave J 0 Dave J 0 referenced this topic on
        • Kaffkieker Kaffkieker
          JakoA
          JakoA
          JakoA
          @Werner-Dahlke Is there a solution to the problem in the meantime? I am also a registered beta user but since version 3.2.4 I don't get any updates via PlayStore. What do I have to do to get the latest beta versions?
          • JakoA JakoA
            @JakoA please contact support 🙂
            • Lynchy67 Lynchy67 referenced this topic on
            • Bart 18
              Bart 18
              Bart 18
              Hi,
              Saterday i applied to the beta version.
              The title in the google playstore is MyRoute-app Mobile (beta)
              But the version is 3.2.4 from 15 december 2022. Guess there is something wrong?
              Corjan Meijerink Patrick S0 2 Replies Last reply
              • Bart 18 Bart 18
                Hi,
                @Bart-18 I just processed all the new registrations, you should have received an email with instructions this morning.
                • AlexM
                  AlexM
                  AlexM
                  Hello!
                  I also have version 3.2.4. what can be there
                  • AlexM
                    AlexM
                    AlexM
                    Hello again!
                    I have 2 accounts on my Android. Once my main address and once the email address where I am registered with mra.
                    • AlexM AlexM
                      Hello again!
                      @AMGT, you need to provide your main google-account address to MRA, that can be different from the address with which you are registered to MRA. These things require a support ticket to be opened.
                      • AlexM
                        AlexM
                        AlexM
                        I have done
                        • AlexM AlexM
                          I have done
                          @AMGT if you have issues, contact support@myrouteapp.com
                          • AlexM
                            AlexM
                            AlexM
                            I've already sent an email but haven't gotten a reply yet
                            • HABVEN aka MrMRA HABVEN aka MrMRA referenced this topic on
                            • Bart 18 Bart 18
                              Hi,
                              Patrick S0
                              Patrick S0
                              Patrick S0
                              @Bart-18 said in Beta instructions 🤖Android (Forum):
                              Hi,
                              Same problem here, but I applied allready in november 2022!!!
                              • Patrick S0 Patrick S0
                                Hi,
                                @Patrick-Schoolaert Create a Support ticket for this please.
                                Al Lieberman 1 Reply Last reply
                                  Al Lieberman
                                  Al Lieberman
                                  Al Lieberman
                                  @Nick-Carthew I guess I'm not alone. My beta version is the same: 3.2.4
                                  That's the version on playstore. [link text](link url)
                                  Bob Harvey 1 Reply Last reply
                                  • Al Lieberman Al Lieberman
                                    Bob Harvey
                                    Bob Harvey
                                    Bob Harvey
                                    @Al-Lieberman said in Beta instructions 🤖Android (Forum):
                                    Actually that is not the current version on the playstore.
                                    Let's say you are trying out a new app, you may have an option at top right to "install"
                                    for me, yesterday that option said "UPDATE"
                                    This assumes that in the Play Store you enter to the search box "myroute-app mobile"
                                    Other apps will show at top of result due to paid positioning, ignore them of course and select Myroute-app mobile. Select update.
                                    Also you can see a section in the playstore describing "whats new" and right now that is showing a date of June 5, 2023 for what's new description. It also says the current version is 3.2.16
                                    To see what is currently installed on your cell phone, you can open the app, touch the upper left hamburger menu (3 bars) then in the next page touch the upper right icon that opens your account. Scroll to the bottom of that account page it will show the version number, mine after update says 3.2.16-180
                                    • A Former User?
                                      A Former User?
                                      A Former User
                                      Are we testing MyRoute.app mobile or MRA Navigation? I'm somewhat confused as some posts refer to Navigation and others to mobile. I have the MRA app mobile which when linked to Android auto is pretty basic and MRA Nav which doesn't work with Android Auto. I thought the Nav version was being developed to work with AA.
                                        @Brian-Martin, The new Navigation Next is a module added to the MyRoute-App Mobile app. So yes, beta testers are actually testing MyRoute-App Mobile indeed.
                                        • TorqueRider TorqueRider referenced this topic on
                                        Kaffkieker
                                        Kaffkieker
                                        Patrick S0
                                        Patrick S0
                                        Bob Harvey
                                        Bob Harvey
                                        Bart 18
                                        Bart 18
                                        Al Lieberman
                                        Al Lieberman
                                        AlexM
                                        AlexM
                                        JakoA
                                        JakoA
                                        Paul Foster
                                        Paul Foster
                                        Erik Halmingh
                                        Erik Halmingh
                                        A Former User?
                                        [[global:former-user]]
                                        • Elektrisch rijden
                                          John mq
                                          John mq
                                        • Reizen delen met NIET MRA gebruikers
                                          Albert van den Elsen
                                        • Audio cuttet via Bluetooth
                                          Haug
                                          Haug
                                          35.4k
                                        • Verminkte route op TomTom.
                                          Jacob Waterweg
                                          Jacob Waterweg
                                        • Probably a me thing
                                          Solo1138
                                          Solo1138
                                        • MRA V6.0.0 (531) Download offline maps ?
                                        • Statement on Commercial Clubs
