  3. Alert when reaching a Viapoint
30 Posts 7 Posters 12.3k Views 1 Watching
    @Gerd-Heinzmann-0
    Hi Gerry, what kind of navigation device do you use?
    In MRA Navigation Next viapoints will give alerts when apporching. MRA Navigation Next is still under development and will be launchen early 2023
    Gerd Heinzmann 0 Offline
    Gerd Heinzmann 0
    @Hans-van-de-Ven-MRA-Master
    I use a Carpe Iter Tablet (running Android)
    https://carpe-iter.com/carpe-iter-pad/
    • Gerd Heinzmann 0 Gerd Heinzmann 0
      @Gerd-Heinzmann-0
      That's a nice device, do you use MRA Navigation or another app on it?
      Gerd Heinzmann 0 1 Reply Last reply
        @Gerd-Heinzmann-0
        Gerd Heinzmann 0
        wrote on last edited by Gerd Heinzmann 0
        I want to use 'Navigation'
        But if the functionality I have to have is not covered.....
        I there a possibilty to get the Beta Version of 'Next' ?
        Hans van de Ven MR.MRA Corjan Meijerink 2 Replies Last reply
          @Gerd-Heinzmann-0
          Navigation Next is still under development, there is no BETA version at this moment.
            Corjan Meijerink Offline
            @Gerd-Heinzmann-0 The Beta version will be available to all who purchase Navigation Next in the presale or those who have an active Navigation Lifetime subscription.
            We aim to have a first Beta available at the end of this month. As that point in time the feature set will obviously be limited.
              Hello @all
              I want to get an alert when aproaching or arriving at a Viapoint.
              Can anybody tell me where this is described ?
              Thanks, gerry
              Nick Carthew Offline
              @Gerd-Heinzmann-0 said in Alert when reaching a Viapoint:
              Hello @all
              Thanks, gerry
              You could add a POI to act as a visual indication at each of your stops.
              • Tim  Thompson Offline
                Tim Thompson
                The better solution perhaps is for the navigation app to navigate to each of the stops (vias). Not the shapping points (although there are arguments to make this a selectable option). The stops (vias). That means that the distance/time to, next turn, etc. information is displayed for each via. The problem with an "alert" - assuming that it's momentary - is that it can be easily missed (paying attention to the road etc. vs. the nav device). If the nav app is navigating to the next stop (via) you're not going to miss it.
                Right now, this is the main issue that has me still using CoPilotGPS as my main mobile nav app. Hopefully this gets addressed in Next.
                  Hello @all
                  Thanks, gerry
                  Gerd Heinzmann 0
                  @Nick-Carthew said in Alert when reaching a Viapoint:
                  Hello @all
                  Thanks, gerry
                  Nick, that won't help.
                  The Photopoints can be a few meters beside the road. You might have to walk ie.100 m to get there.
                  Without an alert, you miss them.
                  • Tim  Thompson Tim Thompson
                    Gerd Heinzmann 0
                    @Tim-Thompson said in Alert when reaching a Viapoint:
                    Right Tim, for me this is not a crazy feature, nobody ever will need, for me this is essential 👍
                    btw.: CoPilotGPS is no alternative, cause you can't import GPX files (as far as I know)
                    Con Hennekens Tim  Thompson 2 Replies Last reply
                      Yes, as a geocacher I can understand that you would like compatibility for your game in your nav, but
                      such basic functionality simply has to be covered.
                      calling specific game compatibility "basic functionality" obviously is a bit misplaced.
                        Tim Thompson
                        True... You can't import GPX files into CoPilotGPS. You either have to use an app to convert the GPX files to .trp or use a trip/route planner (for example - Furkot) that can export to .trp.
                        What CoPilotGPS will do is navigate to the stops. CoPilotGPS has it faults, but it's actually a pretty functional navigation app. Two display fields (displayed while navigating) are user configurable (on the fly) and can display - amongst other things - distance to next stop, ETA at next stop, time remaing until next stop.
                        I agree that this is an essentional functionality. The nav app needs to either navigate between stops (and/or shaping points) or have a notification/alert that manifest (in an unmistakenly noticeable fashion) well in advance (user configurable distance) and persist until the stop is reached.
                          Tim Thompson
                          @Con-Hennekens said in Alert when reaching a Viapoint:
                          I don't know where geocaching came from... But I can tell you after missing a couple of planned fuel stops out in BFE, you'll be cursing the nav app for such an obvious oversight in capability.
                            #17
                            Geocaching is a GPS game and came from the TS that was talking about photo rally which also is a GPS game. So I relate to GPS games 😉
                            Concerning the fuel stops, I never plan those, so I also cannot miss them. I am sure there will be areas on this planet where it is worse, but I never found a fuel station to be more than about 10 to 15km away. My need for coffee is much more urgent than my need for fuel, and most of the times they are easily combined. And if you ride areas where it is worse, it is wise to check your gauge every gasstation you encounter, and don not drive to last liter 😉
                            But it nice to know, like Hans said, alerts will be implemented in Next.
                              Gerd Heinzmann 0
                              Hi, as you might have noticed, I wrote 'for ME it is essential' !
                              I agree, if this feature has not the same relevance for you.
                              My situation is, that I exactly know what I'm looking for. I had that feature (and many more that I miss in MRA) for example with Basecamp and BMW Navigator VI, but BMW Navigator is no longer reliably since the ghosting problem .
                              Now I look for new hardware and software that supports the features I need.
                              With the Carpe I found a good piece of hardware, now I need the software that supports my needs.
                              Back to MRA and my question:
                              The Manual says:
                              All I want is, that what is already described, is implemented in the software!
                              gerry
                                The Manual says:
                                gerry
                                @Gerd-Heinzmann-0, but it IS implemented in software. Maybe not audible, but it does show-up on the map and you can give it a special color to indicate it is a photo rally point. And like Hans says, it will get better in the Next version.
                                • Nick Carthew Offline
                                  Adding a POI not only gives a visual indication but like coloured route points that contain a note, if you touch a POI it will reveal its name which is customisable.
                                    Gerd Heinzmann 0
                                    please read -->
                                    https://forum.myrouteapp.com/post/17472
                                      please read -->
                                      @Gerd-Heinzmann-0, Yes I have read that, but that does not mean it is not implemented. That it is not convenient enough for you is another discussion. Also in Next the alert will probably be generated by a waypoint on the route, so that will most likely also not be a solution for you, even if audible. As far as I am aware Basecamp / Garmin also has no option for waypoint alerts outside the route, but I am not sure of that. Maybe if it would have been implemented like some sort of speed-cam POI. I would hate to get notifications of all kinds of POIs at a distance from my route. Anyway, calling it a "basic functionality that simply has to be covered" is untrue for the vast majority of users, who probably never even heard of photo rally... Geocachers use specific apps for their game, maybe photo rallyers should too?
                                      Gerd Heinzmann 0 Drabslab Tim  Thompson 3 Replies Last reply
                                        Gerd Heinzmann 0
                                        #23
                                        As I said, I had the feature in Basecamp/Garmin and if MRA will not cover this functionality in the near future, I will definitvely use another software.
                                        I assume, you also have never heard of a Photo Rally and it's rules. I'm not talking about all kinds of POIs, I'm not talking of POIs at all. I'm talking about VIA-points and wherever they are, I want to get there to take a Photo.
                                        Basecamp for example leads me to the closest point, that is rideable and in most cases that's the point that the Rallymaster has set. It's that simple.
                                        Why do you think it is soooo extraordinary if I want to be guided to a special Coordinate and get an Alert when I'm there ?
                                          Drabslab Offline
                                          Drabslab Offline
                                          I reached for my keyboard and started TYPING because I do not completely agree with this. To me, MRA should become the one-stop shop for all things navigation, and thus cover as many user requirements as possible.
                                          Where I do agree is that these niche audiences should be served according to their potential customer base size, and according to ease of implementation, which puts them lower on the priority list than the "general" public.
                                          To my understanding the feature is implemented in Navigation as a visible reference on the map. I accept that you prefer an audible message which is in my humble opinion indeed easier when driving.
                                          I don't think that anybody finds this sooooo extraordinary, and it is a very good suggestion. The developers will most likely take it up similar to the audible messages one gets when approaching a speed trap. When implemented it has to be optional because if NEXT would give an audible signal for each and every event someone want to see covered by a sound then we risk riding around with a juke box.
                                          In addition, being useful does not mean that it is important enough to alter the development path of NEXT to give priority to this feature, or worse, to delay NEXT and implement this in a hurry in the current navigation app.
                                          The NEXT roadmap gives an implementation date of the first version by mid 2023. Up to you if this is "near future" enough or not.
                                          Tim  Thompson
                                          Tim Thompson
                                          Gerd Heinzmann 0
                                          Gerd Heinzmann 0
                                            Carl Lee
                                            Carl Lee
                                          • Update 5.2.2 - Quick fix
                                            Jeff Causey
                                            Jeff Causey
                                            1.5k
                                          • Welke instelling
                                            527
                                          • Suggestion: Fully lossless export/import format
                                          • App loopt vast
                                            EMW-motorridders
                                            EMW-motorridders
                                          • vorrei sapere se fosse possibile avere nella traccia del percorso l'indicazione del senso di viaggio come accade nell'app di cui allego foto
