  3. MRA Navigation APP
MRA Navigation APP
59 Posts 8 Posters 44.1k Views 3 Watching
    @Kudee
    Did not work, no roads there
    Kudee
    Kudee
    Kudee
    @Hans-van-de-Ven-MRA-Master Windows or IOS?
    • HABVEN aka MrMRA
      Win 10 Prof
        Strange, you're route....
        @Hans-van-de-Ven-MRA-Master Make sure that the detail level is set to the highest and use a appropriate zoom level.
        Kindly regards
        Reinhard
        Montana 700i and Mac
        • HABVEN aka MrMRA
          #38
          Is set on the highest level and max zoom
          Kudee 1 Reply Last reply
            Kudee
            Kudee
            Kudee
            wrote on last edited by Kudee
            #39
            @Hans-van-de-Ven-MRA-Master Can you Upload the Files somewhere so other Basecamp Users can check?
            • Reinhard-32
              Or set the route to publish and share.
              Kindly regards
              Reinhard
              • HABVEN aka MrMRA
                The problem is that in Basecamp the road is not there.
                  #42
                  @Hans-van-de-Ven-MRA-Master I can check it at my Win10 PC and my iMac pro but I have problems to find the exact location of the missing or not shown road in the map.
                  Kindly regards
                  Reinhard
                  • Reinhard-32 Reinhard-32
                    Kudee
                    Kudee
                    Kudee
                    @Reinhard-32 https://www.myrouteapp.com/route/open/5364210/mobile#43.58887733921692;17.518429756164554;14///
                    On MY Basecamp the Road ist ok 🙂
                    • Reinhard-32
                      #44
                      Thanks for sharing the route. I have open the route in BaseCamp on both machines and found no differences. The gravel road is not there.
                      Then I checked it at Here maps with the same result: The gravel road is not in the Here / Garmin map.
                      When you switch off the track then you can see that the gravel road is not there.
                      HERE Map:
                      Map in BaseCamp on IMac with visible red track:
                      Map in BaseCamp on Mac with invisible track:
                      Kindly regards
                      Reinhard
                      • HABVEN aka MrMRA
                        Same here
                        • HABVEN aka MrMRA
                          I think the conclusion is that Garmin provides different maps in different countries.
                          Reinhard-32 Kudee 2 Replies Last reply
                            @Hans-van-de-Ven-MRA-Master No Hans, I don‘t think so. Here is the creator of the map and sells them to Garmin. Garmin prepared the map for using at garmin sat navs. When you look at the origin here map then yo can see that the discussed road is not there.
                            https://wego.here.com/?map=43.59131,17.52787,13,normal
                            Kindly regards
                            Reinhard
                              Kudee
                              Kudee
                              Kudee
                              Friends, I am embarrassed. This road doesn't exist in Basecamp and I didn't realize it. Shame on me. What I did is imported the track into Basecamp and converted it to a route. Looked at it in Bacecamp and it looks like a route.
                              Now I have loaded the route on my 595, the calculation works and the route can be started.
                              So again checked the Zümo, I do not have OSM maps installed.
                              I am now quite confused, thought I understand it after all these years.
                              Would Garmin now route me on the route even though it does NOT exist on the map?
                              Again, apologies and thanks to all.
                              lg Kudee
                              Translated with www.DeepL.com/Translator (free version)
                              • Nick Carthew
                                The road and route can be seen using the TomTom map in MRA. I thought TomTom was no good for off road 😊 e5c5cc58-45ff-4e51-9e91-c2aafb70de80-image.png
                                  Kudee
                                  Kudee
                                  Kudee
                                  @Nick-Carthew Nick, you miss out the point. Question is if Gamin would route me or not. MRA wouldn't. No problem with OSMand.
                                  Hope i understand it the right way?
                                  lg Kudee
                                  • Kudee Kudee
                                    lg Kudee
                                    @Kudee I was being funny 😁
                                      @Reinhard-32
                                      In @Kudee basecamp NTU map the road is there I believe, but in my NTU map, same version, the road is not there
                                      • Steve Lynch
                                        Steve Lynch
                                        Steve Lynch
                                        #53
                                        If it’s any consolation, Calimoto Premium uses OSM and it can’t route that particular track either. 😳
                                        • Steve Lynch Steve Lynch
                                          Kudee
                                          Kudee
                                          Kudee
                                          @Steve-Lynch OSMand as well 🙄
                                          Kudee
                                          Kudee
                                          Steve Lynch
                                          Steve Lynch
                                            Axel Lange
                                            Axel Lange
                                          • In het kort......
                                          • Route probleem
                                            Jack 13
                                            Jack 13
                                            162
